Gar-Malleos
Mei is hit and Canderella is not.
> roll 6d6+20
<Rei-chan> Kotono rolled : 6d6+20 --> [ 6d6=18 ]{38}
> roll 25d6 sneak attack
<Rei-chan> Kotono rolled : 25d6 sneak attack --> [ 25d6=88 ]{88}
Sneak attack is nulled since elemental bodies all around.
The shoulder tackle is hard but not overwhelming, hitting just where it should -yet your elementally refined bodies withstand it as...
Jaela.
Init is Afina (59) > Moore (52) > Nessian 1 (48) > Jaela (39) > Mei (37) > Cornugons (36) > ??? = Canderella (29) > Surraruthru = Nessian 2 (28) > Lava (0)
Canderella
HP: 383/383
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (CL28), Surraruthru's Stupendous Dragonskin (CL28) Everything But Wisdom of the Dragon Princess (CL28), Create Magic Tattoox2 (CL28), Energy Immunityx4 (CL28), Sublime Revelry (CL31), Mass Death Ward (CL30), Recitation (CL30), Haste (CL27)
Bonuses: +1 morale attack rolls and will saves, immunity to fear and poison, elemental traits, immunity to elemental damage, +10 armor bonus to AC and damage reduction 10/magic, +4 insight to all stats but Wisdom, +1 luck attack rolls, +2 competence attack rolls, halved damage from melee attacks, immunity to pain, immunity to negative energy and energy drain, +2 luck AC/attacks/saving throws, +1 attack rolls haste, +1 attacks, movement speed bonus, +1 reflex saves haste.
Resources Used: 2 9th, 2 11th level spells
Mei
HP: 464/502
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (CL28), Surraruthru's Stupendous Dragonskin (CL28) Everything But Wisdom of the Dragon Princess (CL28), Create Magic Tattoox2 (CL28), Energy Immunityx4 (CL28), Sublime Revelry (CL31), Mass Death Ward (CL30), Recitation (CL30), Heavenly Grace (CL26), Haste (CL27)
Heavenly Grace
Epic; 9th
You are protected by the forces of righteousness and safe from death. You are immune to negative energy, energy drain, ability damage and ability drain for 24 hours. Creatures who use these against you suffer 7d6 points of damage each time they do.
Celestial Valor CL31:  +8 sacred bonus to saving throws against fear and calm emotions/crushing despair/similar emotional effects, a +4 sacred bonus to attack rolls, weapon damage rolls, armor class and saving throws, and any weapon they use counts as a holy weapon for the duration, granting 2d6 extra damage against evil targets (doesn't stack if the weapon already has the holy special property).
+16 morale bonus on saving throws against charm and fear effects and a +16 morale bonus on attack and weapon damage rolls for everyone, Afina gets +18 to these bonuses instead.
Everyone also gets +2 to attack rolls and +2 to CL just for being cool and listening.
"I credit you with surviving this long," Jaela tells the Nessian, as she does what she does best.
[21:19] <@Luiza> roll 1d20+53+39
[21:19] <Rei-chan> Luiza rolled : 1d20+53+39 --> [ 1d20=9 ]{101}
[21:20] <@Luiza> roll 1d20+48+39
[21:20] <Rei-chan> Luiza rolled : 1d20+48+39 --> [ 1d20=1 ]{88}
[21:20] <@Luiza> roll 1d20+43+39
[21:20] <Rei-chan> Luiza rolled : 1d20+43+39 --> [ 1d20=19 ]{101}
[21:20] <@Luiza> roll 1d20+43+39 crit?
[21:20] <Rei-chan> Luiza rolled : 1d20+43+39 crit? --> [ 1d20=13 ]{95}
[21:20] <@Luiza> roll 1d20+38+39
[21:20] <Rei-chan> Luiza rolled : 1d20+38+39 --> [ 1d20=9 ]{86}
[21:21] <@Luiza> roll 4d8+40+11d6+4d6+43 and 1 negative level
[21:21] <Rei-chan> Luiza rolled : 4d8+40+11d6+4d6+43 and 1 negative level --> [ 4d8=22 11d6=37 4d6=16 ]{158}
[21:21] <Rei-chan> Luiza rolled : 4d8+40+11d6+4d6+43 and 1 negative level --> [ 4d8=18 11d6=37 4d6=11 ]{149}
[21:21] <Rei-chan> Luiza rolled : 4d8+40+11d6+4d6+43 and 1 negative level --> [ 4d8=15 11d6=34 4d6=18 ]{150}
[21:23] <@Luiza> roll 12d8+120+11d6+4d6+129+9d6 and 3 negative levels
[21:23] <Rei-chan> Luiza rolled : 12d8+120+11d6+4d6+129+9d6 and 3 negative levels --> [ 12d8=46 11d6=36 4d6=10 9d6=40 ]{381}
Ending the turn in Gambit. Will counterspell with chain dispel if needed twice.
Init: +18/+22 with Sign
HP: 490/490
AC: 83 =75base+2Foresight+3Recitation+1Grace+2cha of the dragon princess, 20% miss chance
AC: 103 =75base+2Foresight+3Recitation+5ShieldOfWarding+1Grace+2cha of the dragon princess+5surru's dragonskin/NA+6epic MA/armor+4sacred, 20% miss chance
Touch AC: 86 =69base+2+3+5+1+2+4
Full Attack (Gae Bolg, GMW, HW, DP +3, haste, K:D +5, *Greater Heroism +4 morale/attack, *Good Hope +2 morale/damage, Recitation +3 luck/attack, *CMT +2 competence/attack, Moore +8 competence/attack, Moore +6 untyped/attack, Moore +16 morale/attack, Moore +16 morale/damage, Moore +4 untyped/damage, SotDP +2 attack/+3 damage, CV +4 sacred attack/damage, Divine Might +16 damage):
53/+53/+48/+43/+38, or +59 AoO, 4d8+40+11d6+4d6 last is goldenfire and 1 negative level, silver+good+anarchic+epic
+39 overall boosts to attack, +43 overall boosts to damage
[not used: Divine Favor +3 luck/damage]
Spells Active: Spell Turning CL26, Contingency CL32, Permanency/Greater Blindsight CL32, Permanency/Mantle of Good CL33, Foresight CL27, Moment of Prescience CL25, Lore of the Gods CL30, Invisibility Purge CL30, Fortunate Fate CL15, Mind Blank CL17, Greater Mage Armor CL7, Planar Tolerance CL7, Heroes Feast CL20, Righteous Halo CL28, Vision of the Omniscient Eye CL30, Greater Heroism CL27, Shield of Warding CL31, Conviction CL31, Crown of Flame CL30, Sign CL30, Divine Insight CL33, Interplanar Telepathic Bond CL26, Sublime Revelry CL31, Mass Death Ward CL30, Good Hope CL30, Epic Mage Armor CL24, Celestial Valor CL31.
Short Duration Spells: Grace CL30, *Moonlight Revelation CL30, Recitation CL30, Haste CL27.
Resistances and Immunities: Fire Immunity, Cold Immunity, Acid Immunity, Electricity Immunity, Sonic Immunity, Damage Reduction 25/Epic and Evil and Cold Iron, Spell Resistance 37 (49 vs Evil spells/permanent Mantle of Good), Immunity to Disease (normal and supernatural/magical), Immunity to Compulsion effects, Immunity to Petrification, Immunity to Sickened/Nauseated, Immunity to fear and poison/Heroes's Feast, Immunity to dazzled and blinded/Vision of the Omniscient Eye, Never surprised or flat-footed/Foresight, physical damage reduced by half/Sublime Revelry, Immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking/Elemental Immunity (Fire).
Spells Left (1-9): 7/9/4/5/8/6/8/6/3
Spells Left (10-12): 6/2/4
DC: 26 + spell level
Saves: conviction +5, shield of warding ref +5, recitation +3, foresight ref +2, haste ref +1, hidden dawn +7, grace ref +1, dex of the dragon princess +2, con of the dragon princess +2
Saves: Fort +72, Ref +73, Will +70
Gae Bolg: GMW, Keen Edge
Gae Trocaire: GMW, Keen Edge
Turning Left: 17/19
Taking ten for K:A 62, K:N 41, K:R 65, K:P 65, Spellcraft 54
-Consecrate
-Flame Strike x4 (all)
-Twinned Horrid Wilting
-Twinned Quickened Horrid Wilting
Hidden Dawn used with Canderella
Golden Bracers (Hidden Dawn):
Flame Strike at will
Immunity to fire
Save bonuses increase to +7
Jaela's blows are inexorable on the wounded fiend. It tries to block, yet its magic is gone. Jaela stabs into it again and again, whirling about as it explodes into ash. Not a speck touches her as it is gone with a wail of fury, leaving behind only another victory - and an iron ring, clattering to the ground.
Mei. She holds for someone to get in close with her and glaive them. Cornugons.
As the cornugons advance, a storm of lightning bolts hit the party, to no avail.
Lightning immunity for all negates.
The cornugons stop after an advance, beginning to chant, before everything shatters around them and - !!!
> roll 1d20+32 vs your SRs
<Rei-chan> Kotono rolled : 1d20+32 vs your SRs --> [ 1d20=12 ]{44}
Let me know if any of you have the SR to negate that.
Can't I counterspell them?
That is a very good point. Of course you can, go for it.
[22:00] <@Luiza> roll 1d20+35
[22:00] <Rei-chan> Luiza rolled : 1d20+35 --> [ 1d20=19 ]{54}
HP: 52+490/490
Spells Left (1-9): 7/9/4/5/8/6/8/5/3
Turning Left: 16/19
-Consecrate
Immunity to fire
With a bark of magic from Jaela, a single ragged word, the spell collapses. It fizzles out, the cornugons gasping as one as...
Spot check, Afina. You're the only one who might make the DC.
[20:03] <@Ebiris> roll 1d20+70
[20:03] <Rei-chan> Ebiris rolled : 1d20+70 --> [ 1d20=11 ]{81}
You note the faintest waver in the air above Jaela's head, a thin and emaciated darting out with a snake's speed, going for her neck.
Chance to shout a warning or use an immediate, if you have one.
'Jaela, duck!' Afina warns telepathically.
> roll 1d20+71 (+20 ???, +3 ???, +1 ???)
<Rei-chan> Kotono rolled : 1d20+71 (+20 ???, +3 ???, +1 ???) --> [ 1d20=13 ]{84}
Normal AC? Regardless of anything else, that stops it from being a potential ambush.
Jaela jerks aside as it appears, a cloak around it fizzling away. It is tall, spindely and with six spider's legs from its back. Humanoid, with skin stretched too tightly across its body, male. A demented grin is on its face, hellish iconography scar-burned into its nude body. It has four eyes, two burnt into its forehead, all four facing Jaela.
Mei promptly steps in, glaive in hand as she looks to shred the horror apart.
> roll 1d20 touch ACs against it, this is mostly obligatory 1 checking
<Rei-chan> Kotono rolled : 1d20 touch ACs against it, this is mostly obligatory 1 checking --> [ 1d20=13 ]{13}
> roll 1d20 touch ACs against it, this is mostly obligatory 1 checking haste bonus attack
<Rei-chan> Kotono rolled : 1d20 touch ACs against it, this is mostly obligatory 1 checking haste bonus attack --> [ 1d20=7 ]{7}
> roll 1d20 touch ACs against it, this is mostly obligatory 1 2
<Rei-chan> Kotono rolled : 1d20 touch ACs against it, this is mostly obligatory 1 2 --> [ 1d20=6 ]{6}
> roll 1d20 touch ACs against it, this is mostly obligatory 1 3
<Rei-chan> Kotono rolled : 1d20 touch ACs against it, this is mostly obligatory 1 3 --> [ 1d20=6 ]{6}
> roll 1d20 touch ACs against it, this is mostly obligatory 1 4
<Rei-chan> Kotono rolled : 1d20 touch ACs against it, this is mostly obligatory 1 4 --> [ 1d20=20 ]{20}
> roll 1d20 touch ACs against it, this is mostly obligatory 1 4 crit?
<Rei-chan> Kotono rolled : 1d20 touch ACs against it, this is mostly obligatory 1 4 crit? --> [ 1d20=7 ]{7}
> roll 15d6+7+3d6+2d6+2d6
<Rei-chan> Kotono rolled : 15d6+7+3d6+2d6+2d6 --> [ 15d6=58 3d6=12 2d6=7 2d6=8 ]{92}
<Rei-chan> Kotono rolled : 15d6+7+3d6+2d6+2d6 --> [ 15d6=53 3d6=9 2d6=4 2d6=8 ]{81}
<Rei-chan> Kotono rolled : 15d6+7+3d6+2d6+2d6 --> [ 15d6=37 3d6=8 2d6=7 2d6=2 ]{61}
<Rei-chan> Kotono rolled : 15d6+7+3d6+2d6+2d6 --> [ 15d6=46 3d6=10 2d6=3 2d6=2 ]{68}
> roll 30d6+14+5d6+2d6+2d6
<Rei-chan> Kotono rolled : 30d6+14+5d6+2d6+2d6 --> [ 30d6=95 5d6=15 2d6=8 2d6=10 ]{142}
Init is Afina (59) > Moore (52) > Nessian 1 (48) > Jaela (39) > Cornugons (36) > Spider-Thing = Canderella = Mei (29) > Surraruthru = Nessian 2 (28) > Lava (0)
As Mei slices into that horror, Canderella turns and flips her hair back, "Bye," she says, as sudden thunderbolts rain down on all the enemies.
> roll 1d20+42 Canderella throwing some thunder
<Rei-chan> Kotono rolled : 1d20+42 Canderella throwing some thunder --> [ 1d20=5 ]{47}
> roll 20d6
<Rei-chan> Kotono rolled : 20d6 --> [ 20d6=69 ]{69}
<Rei-chan> Kotono rolled : 1d20+39 Nessian 2 --> [ 1d20=13 ]{52}
> roll 1d20+28 cornugons
<Rei-chan> Kotono rolled : 1d20+28 cornugons --> [ 1d20=10 ]{38}
> roll 1d20+34 spider-creature improved evasion
<Rei-chan> Kotono rolled : 1d20+34 spider-creature improved evasion --> [ 1d20=15 ]{49}
The spider-thing dodges, twisting out of the way of the sudden thunderbolt. The Nessian reaches up and grabs it, crushing it in his clawed fist. The cornugons are not so lucky, hit and dodging - but it's sitll too much. They begin to s hatter, deep groans as they turn to black glass, ruined. Got them!
Init is Afina (59) > Moore (52) > Nessian 1 (48) > Jaela (39) > Spider-Thing = Canderella = Mei (29) > Surraruthru = Nessian 2 (28) > Lava (0)
Surru and Nessian 2 are up. Go Surru.
Canderella
HP: 383/383
Resources Used: 2 9th, 1 10th, 2 11th level spells
Mei
HP: 464/502
Heavenly Grace
Epic; 9th
