Gar-Malleos
> roll 1d100 vs various
<Rei-chan> Kotono rolled : 1d100 vs various --> [ 1d100=12 ]{12}
That swallows it for you two plus Jaela, who has her 20%. Surru, do you have any going?
No miss chance, but I will steal Neph's idea and cast Greater Mirror Image!
> roll 1d9 as ong as it's not a 1 Surru's okay
<Rei-chan> Kotono rolled : 1d9 as ong as it's not a 1 Surru's okay --> [ 1d9=9 ]{9}
That only leaves Mei and Canderella on the hook for 3 points of vile Strength damage. Both are immune, and additionally, heavenly grace deals 7d6 to him for the effort.
> roll 7d6 smack
<Rei-chan> Kotono rolled : 7d6 smack --> [ 7d6=19 ]{19}
Green fire hits all of you - or would in many cases, but to what end? You do not burn. You do not suffer. None of you do. Instead the pit fiend bursts with holy light, sizzling and crackling as...
Mei is up. She will hold pending Moore getting his normal routine going. Go Moore.
Moore's voice fills everyone with a renewed courage as sacred words empower them!
[13:16] <Nephrite> roll 3d4 nonlethal
[13:16] <Rei-chan> Nephrite rolled : 3d4 nonlethal --> [ 3d4=7 ]{7}
+16 morale bonus on saving throws against charm and fear effects and a +16 morale bonus on attack and weapon damage rolls, Afina gets +18 to the bonus. Everyone gets +2 to attack and +2 to CL of spells.
Moore then swings an arm around and points at the first humanoid!
[13:22] <Nephrite> roll 1d20 ranged touch will do the math if needed
[13:22] <Rei-chan> Nephrite rolled : 1d20 ranged touch will do the math if needed --> [ 1d20=15 ]{15}
[13:22] <Nephrite> roll 1d20+29+16 SR
[13:22] <Rei-chan> Nephrite rolled : 1d20+29+16 SR --> [ 1d20=1 ]{46}
It's Antimagic Ray if it doesn't have SR!
Active Spells: mind blank (CL17), fortunate fate (CL15), planar tolerance (CL7) and greater mage armor(CL5), Superior Resistance (CL 27), True Seeing (CL10), Bibliotecha Arcana (CL27). Sublime Revelry CL31, Mass Death Ward CL30, Good Hope CL30, agility of dragon princess (CL 28), Surraruthru's Stupendous Dragonskin, CL 28, endurance of dragon princess (CL 28), beauty of dragon princess (CL 28), magic tattoo (CL 28), magic tattoo (CL 28), energy immunity (acid) (CL 28), energy immunity (sonic) (CL 28), energy immunity (elec) (CL 28), Foresight (CL27), Harmonize (CL27)
HP: 363(7)(344/415)
AC: 62 (86), 46 (53) touch, 52 (59) flatfooted 20% miss chance, SR 41, 30 resist all to elements
25/32 Bardic music uses 3/3 Refrain
Fort +36 (40), Ref +40 (46), Will +41 (43) (+6 due to Superior Resistance)
+14 to initiative for everyone
Spells:
0th - 4/4 (DC 22)
1st - 7/7
2nd - 7/7
3rd - 7/7
4th - 7/7
5th - 5/6
6th - 6/6
7th - 4/6
8th - 5/5
9th - 1/1
Favored Soul:
0th - 5/5
1st - 9/9
2nd - 9/9
3rd - 8/8
4th - 8/8
5th - 8/8
6th - 5/8
7th - 6/6
8th - 4/4
+1 Luck Bonus on Attack Rolls
Additionally, the below are pre-loaded into the Tapestry for activation as Quiescent Weaving:
Resist Energy, CL 26, Duration 260 Minutes. (4 castings)
Subject gains energy resistance to: Acid, Electricity, Fire, Sonic of 30 points.
[/spoiler]
Make an immediate Fortitude save, -9 penalty.
[13:25] <Nephrite> roll 1d20+46-9 mettle
[13:25] <Rei-chan> Nephrite rolled : 1d20+46-9 mettle --> [ 1d20=4 ]{41}
Crap. Okay, um, what immunities do you have, both natural and from spells?
Immune to mind affecting due to mind blank, death effects/negative energy effects, immune to fear but I think that falls under mind blank... I think that's it.
Energy types from Energy Immunity, also Elemental body gives you immunity to crits and flanking.
immunity to pain from sublime revelry, poison from heroes feast, fear doesnt come from mind blank iirc
And also those things.
Thanks.
The beam hits the first of the humanoids, causing them to crash to the ground in a heap.
> roll 2d6
<Rei-chan> Kotono rolled : 2d6 --> [ 2d6=6 ]{6}
Amid a crash as he falls to the ground, Mei fills all of you with holy power.
+52 temp HP to all allies.
Canderella and ????2 are up.
As the first humanoid falls, Canderella smiles. "My, what a spot you've found yourselves in," she says, snapping her fingers as lightning rains down.
> roll 1d20 SR roll, academic here unless she 1s
<Rei-chan> Kotono rolled : 1d20 SR roll, academic here unless she 1s --> [ 1d20=6 ]{6}
Canderella's Sudden Thunderbolts, looking to wipe out the cornugons and lay some pain on the others.
> roll 20d6
<Rei-chan> Kotono rolled : 20d6 --> [ 20d6=87 ]{87}
> roll 1d20+10 humanoid 1
<Rei-chan> Kotono rolled : 1d20+10 humanoid 1 --> [ 1d20=11 ]{21}
> roll 1d20+30 humanoid 2 evasion
<Rei-chan> Kotono rolled : 1d20+30 humanoid 2 evasion --> [ 1d20=5 ]{35}
> roll 1d20+24 cornugons
<Rei-chan> Kotono rolled : 1d20+24 cornugons --> [ 1d20=20 ]{44}
The humanoids are zapped, both crying out as they're struck. The cornugons endure with only minor injuries, as the pit fiend raises his blade. The lightning crackles right into it, electricity as well as green fire now surging through it.
Init is Afina (54) > Jaela (48) > Surru (43) > Pit Fiend (40) > Mei (39) > Moore (35) > Canderella = ???2 (30) > ???3 (23)
Then all is fire and lightning, as the spell like abilities of the cornugons hit home.
> roll 1d20+28 SR check
<Rei-chan> Kotono rolled : 1d20+28 SR check --> [ 1d20=10 ]{38}
Hits/misses on SR? If you missed go ahead and roll ref.
Canderella
HP: 292+52/383
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (CL28), Surraruthru's Stupendous Dragonskin (CL28) Everything But Wisdom of the Dragon Princess (CL28), Create Magic Tattoox2 (CL28), Energy Immunityx4 (CL28), Sublime Revelry (CL31), Mass Death Ward (CL30), Recitation (CL30), Haste (CL27)
Bonuses: +1 morale attack rolls and will saves, immunity to fear and poison, elemental traits, immunity to elemental damage, +10 armor bonus to AC and damage reduction 10/magic, +4 insight to all stats but Wisdom, +1 luck attack rolls, +2 competence attack rolls, halved damage from melee attacks, immunity to pain, immunity to negative energy and energy drain, +2 luck AC/attacks/saving throws, +1 attack rolls haste, +1 attacks, movement speed bonus, +1 reflex saves haste.
Resources Used: 2 9th, 2 10th, 2 11th level spells
Mei
HP: 424+52/502
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (CL28), Surraruthru's Stupendous Dragonskin (CL28) Everything But Wisdom of the Dragon Princess (CL28), Create Magic Tattoox2 (CL28), Energy Immunityx4 (CL28), Sublime Revelry (CL31), Mass Death Ward (CL30), Recitation (CL30), Heavenly Grace (CL26), Haste (CL27)
Heavenly Grace
Epic; 9th
You are protected by the forces of righteousness and safe from death. You are immune to negative energy, energy drain, ability damage and ability drain for 24 hours. Creatures who use these against you suffer 7d6 points of damage each time they do.
Celestial Valor CL31:  +8 sacred bonus to saving throws against fear and calm emotions/crushing despair/similar emotional effects, a +4 sacred bonus to attack rolls, weapon damage rolls, armor class and saving throws, and any weapon they use counts as a holy weapon for the duration, granting 2d6 extra damage against evil targets (doesn't stack if the weapon already has the holy special property).
+16 morale bonus on saving throws against charm and fear effects and a +16 morale bonus on attack and weapon damage rolls for everyone, Afina gets +18 to these bonuses instead.
Everyone also gets +2 to attack rolls and +2 to CL just for being cool and listening.
pings off Afina's SR 42
Since they aren't here or not posting, could someone look up Surru and Jaela's real quick?
