Gar-Malleos
Surru's is 37 and Jaela's is 37 but 49 vs. evil stuff
Covers Jaela.
Surru, Canderella and Mei need to make Reflex saves, as Canderella's SR comes up short and Mei lacks it.
> roll 1d20+38+2 Ref
<Rei-chan> Iddy rolled : 1d20+38+2 Ref --> [ 1d20=5 ]{45}
Spell Turning gives me this for 7 rounds from casting:
Moderate School Esoterica (Ex): At 7th level, your long study of your chosen school leads to a breakthrough. You gain an ability from those below based on your chosen school. Each ability is triggered automatically when you cast a spell from your chosen school and lasts for a number of rounds equal to the spell's level (unless otherwise noted).
Abjuration: If you are subject to a spell that has a partial or half effect on a successful save, you suffer no adverse effect if you successfully save.
So you evade and take no damage, Iddy. Good to know.
> roll 1d20+45 Canderella
> roll 1d20+42 Mei
<Rei-chan> Kotono rolled : 1d20+45 Canderella --> [ 1d20=15 ]{60}
<Rei-chan> Kotono rolled : 1d20+42 Mei --> [ 1d20=11 ]{53}
> roll 20d6
<Rei-chan> Kotono rolled : 20d6 --> [ 20d6=64 ]{64}
Half is blocked by elemental immunity, so the other half only gets through thanks to being unholy damage. Halved again for saves, so they only take 16 damage.
Amid all of this the cornugons stay on guard and...
Lava.
Init is Afina (54) > Jaela (48) > Surru (43) > Pit Fiend (40) > Mei (39) > Moore (35) > Canderella = ???2 (30) > ???3 (23) > Lava (0)
Ref, all.
Canderella
HP: 292+36/383
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (CL28), Surraruthru's Stupendous Dragonskin (CL28) Everything But Wisdom of the Dragon Princess (CL28), Create Magic Tattoox2 (CL28), Energy Immunityx4 (CL28), Sublime Revelry (CL31), Mass Death Ward (CL30), Recitation (CL30), Haste (CL27)
Bonuses: +1 morale attack rolls and will saves, immunity to fear and poison, elemental traits, immunity to elemental damage, +10 armor bonus to AC and damage reduction 10/magic, +4 insight to all stats but Wisdom, +1 luck attack rolls, +2 competence attack rolls, halved damage from melee attacks, immunity to pain, immunity to negative energy and energy drain, +2 luck AC/attacks/saving throws, +1 attack rolls haste, +1 attacks, movement speed bonus, +1 reflex saves haste.
Resources Used: 2 9th, 2 10th, 2 11th level spells
Mei
HP: 424+36/502
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (CL28), Surraruthru's Stupendous Dragonskin (CL28) Everything But Wisdom of the Dragon Princess (CL28), Create Magic Tattoox2 (CL28), Energy Immunityx4 (CL28), Sublime Revelry (CL31), Mass Death Ward (CL30), Recitation (CL30), Heavenly Grace (CL26), Haste (CL27)
Heavenly Grace
Epic; 9th
You are protected by the forces of righteousness and safe from death. You are immune to negative energy, energy drain, ability damage and ability drain for 24 hours. Creatures who use these against you suffer 7d6 points of damage each time they do.
Celestial Valor CL31:  +8 sacred bonus to saving throws against fear and calm emotions/crushing despair/similar emotional effects, a +4 sacred bonus to attack rolls, weapon damage rolls, armor class and saving throws, and any weapon they use counts as a holy weapon for the duration, granting 2d6 extra damage against evil targets (doesn't stack if the weapon already has the holy special property).
+16 morale bonus on saving throws against charm and fear effects and a +16 morale bonus on attack and weapon damage rolls for everyone, Afina gets +18 to these bonuses instead.
Everyone also gets +2 to attack rolls and +2 to CL just for being cool and listening.
[19:21] <@Ebiris> roll 1d20+47 evasion
[19:21] <Rei-chan> Ebiris rolled : 1d20+47 evasion --> [ 1d20=8 ]{55}
[14:20] <Nephrite> roll 1d20+40 Surru ref
[14:20] <Rei-chan> Nephrite rolled : 1d20+40 Surru ref --> [ 1d20=15 ]{55}
[14:21] <Nephrite> roll 1d20+52 evasion
[14:21] <Rei-chan> Nephrite rolled : 1d20+52 evasion --> [ 1d20=20 ]{72}
Okay, someone roll for the Jaela, would you?
[14:27] <Nephrite> roll 1d20+73 evasion Jaela
[14:27] <Rei-chan> Nephrite rolled : 1d20+73 evasion Jaela --> [ 1d20=3 ]{76}
All PCs evaded. Okay, NPC time.
<Rei-chan> Kotono rolled : 1d20+45 Canderella --> [ 1d20=8 ]{53}
> roll 1d20+42 Mei
<Rei-chan> Kotono rolled : 1d20+42 Mei --> [ 1d20=3 ]{45}
> roll 20d6
<Rei-chan> Kotono rolled : 20d6 --> [ 20d6=76 ]{76}
Halved, it's not as strong as it was when you were in the previous dead end where it focused. Both made the save.
Fire lashes the party as the walls burst with it, lava attacking again as...
Afina.
Canderella
HP: 290/383
Mei
HP: 422/502
Heavenly Grace
Epic; 9th
Afina continues focusing on the pit fiend to the exclusion of all foes, rushing in and stabbing it several times before darting onwards past it and further down the tunnel another sixty feet!
[19:41] <@Ebiris> roll 1d20+95
[19:41] <Rei-chan> Ebiris rolled : 1d20+95 --> [ 1d20=18 ]{113}
[19:41] <@Ebiris> roll 1d20+95 extra attack as swift with skirmisher boots
[19:41] <Rei-chan> Ebiris rolled : 1d20+95 extra attack as swift with skirmisher boots --> [ 1d20=2 ]{97}
[19:41] <@Ebiris> roll 1d20+90
[19:41] <Rei-chan> Ebiris rolled : 1d20+90 --> [ 1d20=19 ]{109}
[19:41] <@Ebiris> roll 1d20+90 crit?
[19:41] <Rei-chan> Ebiris rolled : 1d20+90 crit? --> [ 1d20=19 ]{109}
[19:42] <@Ebiris> roll 1d4+56+3d6+3d6+4d6+6d6+2d6 and 2 negative levels
[19:42] <Rei-chan> Ebiris rolled : 1d4+56+3d6+3d6+4d6+6d6+2d6 and 2 negative levels --> [ 1d4=3 3d6=13 3d6=9 4d6=11 6d6=21 2d6=6 ]{119}
[19:42] <Rei-chan> Ebiris rolled : 1d4+56+3d6+3d6+4d6+6d6+2d6 and 2 negative levels --> [ 1d4=4 3d6=8 3d6=14 4d6=13 6d6=19 2d6=8 ]{122}
[19:43] <@Ebiris> roll 3d4+168+9d6+9d6+4d6+6d6+2d6 and 6 negative levels
[19:43] <Rei-chan> Ebiris rolled : 3d4+168+9d6+9d6+4d6+6d6+2d6 and 6 negative levels --> [ 3d4=7 9d6=33 9d6=28 4d6=11 6d6=20 2d6=10 ]{277}
Afina 383+52/383
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 29), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), interplanar telepathic bond (CL 26), sublime revelry (CL 31), death ward (CL 31), good hope (CL 30), recitation (CL 30), shield (CL 27), agility of dragon princess (CL 28), endurance of dragon princess (CL 28), beauty of dragon princess (CL 28), magic tattoo (CL 28), magic tattoo (CL 28), energy immunity (acid) (CL 28), energy immunity (sonic) (CL 28), energy immunity (elec) (CL 28), haste (CL 27), planar bubble (CL 27), shadow form (CL 27), celestial valour (CL 31)
defences: AC 111 (touch 71), spell resistance 42, immunity to fire, water, earth, cold, acid, sonic, electricity, disease, poison, fear, mind-affecting, critical hits, negative energy, & death effects, halved damage from melee and ranged attacks, freedom of movement, 50% miss chance
spell slots: 6/9/8/9/5/8/7/6/3/7/7/4/3
Attack: +91 (1d4+52 + various)
Like that you slice through the fiend, your enchanted and holy blade cutting through its body and then throat. It stumbles back and falls, dissolving into obsidian dust. Got him!
Init is Afina (54) > Jaela (48) > Surru (43) > Mei (39) > Moore (35) > Canderella = ???2 (30) > ???3 (23) > Lava (0)
Jaela.
Deprived of the tempting target of the pit fiend, Jaela swoops down upon the humanoid Canderella missed!
[21:55] <@Lisa> roll 1d20+67+39-26 charging smite, 26pa
[21:55] <Rei-chan> Lisa rolled : 1d20+67+39-26 charging smite, 26pa --> [ 1d20=18 ]{98}
[21:57] <@Lisa> roll 12d8+138+96+156+129+4d6
[21:57] <Rei-chan> Lisa rolled : 12d8+138+96+156+129+4d6 --> [ 12d8=39 4d6=20 ]{578}
Init: +18/+22 with Sign
HP: 52+490/490
AC: 83 =75base+2Foresight+3Recitation+1Grace+2cha of the dragon princess, 20% miss chance
AC: 103 =75base+2Foresight+3Recitation+5ShieldOfWarding+1Grace+2cha of the dragon princess+5surru's dragonskin/NA+6epic MA/armor+4sacred, 20% miss chance
Touch AC: 86 =69base+2+3+5+1+2+4
Full Attack (Gae Bolg, GMW, HW, DP +3, haste, K:D +5, *Greater Heroism +4 morale/attack, *Good Hope +2 morale/damage, Recitation +3 luck/attack, *CMT +2 competence/attack, Moore +8 competence/attack, Moore +6 untyped/attack, Moore +16 morale/attack, Moore +16 morale/damage, Moore +4 untyped/damage, SotDP +2 attack/+3 damage, CV +4 sacred attack/damage, Divine Might +16 damage):
53/+53/+48/+43/+38, or +59 AoO, 4d8+40+11d6+4d6 last is goldenfire and 1 negative level, silver+good+anarchic+epic
+39 overall boosts to attack, +43 overall boosts to damage
[not used: Divine Favor +3 luck/damage]
Spells Active: Spell Turning CL26, Contingency CL32, Permanency/Greater Blindsight CL32, Permanency/Mantle of Good CL33, Foresight CL27, Moment of Prescience CL25, Lore of the Gods CL30, Invisibility Purge CL30, Fortunate Fate CL15, Mind Blank CL17, Greater Mage Armor CL7, Planar Tolerance CL7, Heroes Feast CL20, Righteous Halo CL28, Vision of the Omniscient Eye CL30, Greater Heroism CL27, Shield of Warding CL31, Conviction CL31, Crown of Flame CL30, Sign CL30, Divine Insight CL33, Interplanar Telepathic Bond CL26, Sublime Revelry CL31, Mass Death Ward CL30, Good Hope CL30, Epic Mage Armor CL24, Celestial Valor CL31.
Short Duration Spells: Grace CL30, *Moonlight Revelation CL30, Recitation CL30, Haste CL27.
Resistances and Immunities: Fire Immunity, Cold Immunity, Acid Immunity, Electricity Immunity, Sonic Immunity, Damage Reduction 25/Epic and Evil and Cold Iron, Spell Resistance 37 (49 vs Evil spells/permanent Mantle of Good), Immunity to Disease (normal and supernatural/magical), Immunity to Compulsion effects, Immunity to Petrification, Immunity to Sickened/Nauseated, Immunity to fear and poison/Heroes's Feast, Immunity to dazzled and blinded/Vision of the Omniscient Eye, Never surprised or flat-footed/Foresight, physical damage reduced by half/Sublime Revelry, Immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking/Elemental Immunity (Fire).
Spells Left (1-9): 7/9/4/5/8/6/7/4/3
Spells Left (10-12): 6/2/4
DC: 26 + spell level
Saves: conviction +5, shield of warding ref +5, recitation +3, foresight ref +2, haste ref +1, hidden dawn +7, grace ref +1, dex of the dragon princess +2, con of the dragon princess +2
Saves: Fort +72, Ref +73, Will +70
Gae Bolg: GMW, Keen Edge
Gae Trocaire: GMW, Keen Edge
Turning Left: 16/19
-Smite x3
Taking ten for K:A 62, K:N 41, K:R 65, K:P 65, Spellcraft 54
-Consecrate
-Flame Strike x4 (all)
-Twinned Horrid Wilting
-Twinned Quickened Horrid Wilting
Hidden Dawn used with Canderella
Golden Bracers (Hidden Dawn):
Flame Strike at will
Immunity to fire
Save bonuses increase to +7
Init is Afina (54) > Jaela (48) > Surru (43) > Mei (39) > Moore (35) > Canderella = Humanoid (30) > Cornugons (23) > Lava (0)
With a single strike, the humanoid is impaled, barely a cry before it erupts in goldenfire like a volcano, incinerated from the inside out. In an instant nothing is left of him, as...
Surraruthru.
Surraruthru locks eyes on the remaining humanoid and begins chanting a brace of spells!
Assay Spell Resistance, CL 30.
+10 to checks to overcome SR on next spell.
Enervate, CL 26, Maximized via Rod.
> roll 1d20+38+16 Touch ATK
<Serith> Iddy roll for Serith < 61 > [d20=7]
> roll 1d20+26+10 SR Check
<Serith> Iddy roll for Serith < 48 > [d20=12]
4 Negative Levels.
Surraruthru
HP: 359/359 (359 base)
AC: 52+4+2 (Deflection/Morale)
Touch AC: 24, Flat Footed: 57, SR: 37, CMB: 33, CMD: 51
Init: +12, Touch Atk: 38+2 (Morale)
Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body: Fire (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength/Mind/Agility/Endurance/Beauty of the Dragon Princess (CL28), Bibliotheca Arcana (CL28), Create Magic Tattoo (CL24), Create Magic Tattoo (CL24), Energy Immunity: Acid/Cold/Electricity/Sonic (CL26), Epic Mage Armor (CL28), Sublime Revelry CL31, Mass Death Ward CL30, Good Hope CL30, Spell Turning (CL28)
Passive: True Seeing, Detect Magic, +15 to knowledge checks
Candy gives a bonus of +16 to overcome SR which I think stacks with your natural ones, so that should be 64.
