Gar-Malleos
I'm heading off with the others and staying in Gambit.
Hurrying along and leaving zombies behind you, you come to a T intersection. In both directions you see cell doors opening, with doors at the end of each tunnel, as well as one straight ahead.
Go ahead and choose what you're doing for the moment, all. You're out of init, but going to attack will put us right back into it. Moving may not automatically, depending on the choices you make.
Afina disintegrates the door dead ahead!
[18:53] <@Ebiris> roll 1d20 1 check
[18:53] <Kobot> Ebiris rolled 1d20 1 check --> [ 1d20=11 ]{11}
Afina 383+52/383
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 29), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), interplanar telepathic bond (CL 26), sublime revelry (CL 31), death ward (CL 31), good hope (CL 30), recitation (CL 30), shield (CL 27), agility of dragon princess (CL 28), endurance of dragon princess (CL 28), beauty of dragon princess (CL 28), magic tattoo (CL 28), magic tattoo (CL 28), energy immunity (acid) (CL 28), energy immunity (sonic) (CL 28), energy immunity (elec) (CL 28), haste (CL 27), planar bubble (CL 27), shadow form (CL 27), celestial valour (CL 31)
defences: AC 111 (touch 71), spell resistance 42, immunity to fire, water, earth, cold, acid, sonic, electricity, disease, poison, fear, mind-affecting, critical hits, negative energy, & death effects, halved damage from melee and ranged attacks, freedom of movement, 50% miss chance
spell slots: 6/9/8/9/4/8/2/6/2/6/7/3/3
Attack: +92 (1d4+55 + various)
The door crumbles. It leads to a stairway going down.
And that's the way Afina leads their merry little troupe!
The group hurries downstairs. Yet as you step forward...
Jaela, dispel on the moonlight revelation.
[21:09] <@Lisa> roll 1d20+40
[21:09] <Kobot> Lisa rolled 1d20+40 --> [ 1d20=1 ]{41}
Okay. Anyone with epic ranks in Spot, please make a Spot check. Also note if you have true seeing or other illusion busting.
I have blindsight 200 along with all-around vision and see invisible/ethereal
[19:12] <@Ebiris> roll 1d20+70 spot
[19:12] <Kobot> Ebiris rolled 1d20+70 spot --> [ 1d20=18 ]{88}
DC 75 to see through an illusion
Afina 383+52/383
spell slots: 6/9/8/9/4/8/3/6/2/6/7/3/3
I have True Seeing also. Using some of my Greater Improv points. Take 10 for 75.
Ahead you can see the stairs are an illusion. Slightly more rundown stairs are beneath them, pitted and worn.
Afina stops. "Don't think this is the way..." she pauses and looks back and forth. Is there any sign that one of left or right routes is more travelled than the other?
Spot or search or survival?
We'll call it Survival.
