Salvation (Everyone)
Started by Anastasia, January 03, 2018, 12:56:45 PM
"Ready," Adrian says, glancing over at Jaela. "Got anything to make me stab things better longer term?"
"It's time," Sylvie agrees.
"Ready!" Calleigh cheers.
HP: 691+54=745
Spells Active: Mind Blank (CL 15), Fortunate Fate (CL 13), Planar Tolerance (CL 7), Greater Mage Armor (CL 5), True Seeing (CL 32), Inertial Armor (CL 32), Strength of the Dragon Princess (CL 28), Mind of the Dragon Princess (CL 28), Agility of the Dragon Princess (CL 28), Endurance of the Dragon Princess (CL 28), Beauty of the Dragon Princess (CL 28), Create Magic Tattoo (CL 24), Tyche's Touch (CL 17), Recitation (CL 35)
Bonuses: +18 armor to AC (applies to incorporeal touch), Dragon Princess Bonuses, +4 sacred to saves, +2 luck to AC/saves/attack
Resources Used: 157/789, 2 charges of Paragon's Fortune.
HP: 345+54=399
Resources Used: 0/45, Hope, 68/800 Astral Legion Psicrown, 38/50 Wand of Cure Critical
"Let's go with the Triune's blessing," Jaela states at Adrian's request, recasting Recitation for everyone's benefit. "I've got your back if anything specialized comes up, Adrian."
Recitation CL35, +2 luck to AC/attack/saving throws or +3 if you're a glorious Triune worshipper.
Init: +24 (Sign, Grace, AotDP), CHA +2, CL35
HP: 520+20/520 (+54/54 from EotDP)
AC: 95 =76base+2Foresight+3Recitation+5ShieldOfWarding+1Grace+2AotDP+6EMAdifference, 20% miss chance
Touch AC: 89 =70base+2+3+5+1+2+6
Full Attack (Gae Buidhe +7, haste, HW, K:D +5): +51/+51/+46/+41/+36, 1d8+38+3d12 goldenfire
Full Attack (Gae Bolg, GMW, Haste, HW, K:D +5, vs devils only): +53/+53/+48/+43/+38, 4d8+40+11d6 and 1 negative level
Combat: Greater Heroism +4 morale/attack, Good Hope +2 morale/damage, Recitation +3 luck/attack, Celestial Valor +4 sacred attack/damage, Divine Might +17 damage: +11 attack, +23 damage
[not used: CMT +2 competence/attack, SotDP +2 attack/+3 damage, Divine Favor +3 luck/damage]
Gae Buidhe: The wielder acts outside of fate and destiny, they are immune to divinations (with the exception of detect good, which always reveals an overwhelming aura of good). Luck and insight bonuses to attack rolls, weapon damage rolls and DCs do not apply against attacks on the wielder, while the same bonuses to armor class and saving throws do not apply against attacks the wielder makes. Additional abilities that explicitly manipulate destiny or use it as a tool also fail (the DM's discretion is used to determine abilities that qualify for this).
Spells Active: Contingency CL36, Permanency/Greater Blindsight CL36, Permanency/Mantle of Good CL37, Shield of Warding CL31, Conviction CL31, Sublime Revelry CL31, Foresight CL31, Moment of Prescience CL29, Invisibility Purge CL34, Righteous Halo CL34, Greater Heroism CL34, Fortunate Fate CL34, Good Hope CL34, Heroes Feast CL20, Mass Death Ward CL35, Vision of the Omniscient Eye CL35, Crown of Flame CL35, Sign CL35, Divine Insight CL35, Lore of the Gods CL35, Mind Blank CL17, Epic Mage Armor CL26.
Short Duration Spells: Grace CL34, Celestial Valor CL32, Recitation CL35, Greater Displacement CL29.
Surru Spells: Strength of the Dragon Princess CL 28, Mind of the Dragon Princess CL 28, Agility of the Dragon Princess CL 28, Endurance of the Dragon Princess CL 28, Beauty of the Dragon Princess CL 28, Create Magic Tattoo (+1 CL) CL 24.
Resistances and Immunities: Fire Immunity, Cold Resistance 10, Acid Resistance 20, Electricity Resistance 20, Sonic Resistance 20, Damage Reduction 25/Epic and Evil and Cold Iron, Spell Resistance 37 (49 vs Evil spells/permanent Mantle of Good), Immunity to Disease (normal and supernatural/magical), Immunity to Compulsion effects, Immunity to Petrification, Immunity to Sickened/Nauseated, Immunity to fear and poison/Heroes's Feast, Immunity to dazzled and blinded/Vision of the Omniscient Eye, Never surprised or flat-footed/Foresight, physical damage reduced by half/Sublime Revelry.
Old: Cold Immunity, Acid Immunity, Electricity Immunity, Sonic Immunity; You are immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking/Elemental Body.
Original:
Spells Left (1-9): 10/9/9/7/9/9/8/7/8
Spells Left (10-12): 8/6/4
Current:
Spells Left (1-9): 4/3/4/2/6/7/8/4/6
Spells Left (10-12): 6/0/4
Saves: conviction +5, recitation +3, hidden dawn +7, celestial valor +4 : +19; eotdp fort +2 (2); shield of warding ref +5, foresight ref +2, haste ref +1, grace ref +1, aotdp ref +2 (11).
Saves: Fort +73, Ref +74, Will +71
Gae Bolg: GMW, Keen Edge
Gae Trocaire: GMW, Keen Edge
Gae Buidhe: Keen Edge
Turning Left: 17/20
-Smites x1
-Mountainous Fire summons
-Channeled twinned Bolt of Glory into Gae Buidhe
-Bead of Karma
-True Strike x2
-Time Stop x1
-Spell Turning x1
-Foresight x1
-Moment of Prescience x1
Taking ten for K:A 60 (64), K:N 39 (44), K:R 64 (69), K:P 64 (69), Spellcraft 54 (69)
Hidden Dawn used with Balyss
Golden Bracers (Hidden Dawn):
Flame Strike at will as an SLA
Sunburst at will as an SLA
Immunity to fire
Save bonuses increase to +7
Goldenfire damage on weapon damage rolls, natural attacks and spells and spell-like abilities with the fire descriptor rises to +6d6, unlimited range as long as on same plane.
Goldenfire Spell [Epic, Exalted]
Prerequisite: Searing Spell, con 25, must worship Lathander or another of the House of Nature
Benefit: A goldenfire spell ignores the immunity and resistance to fire of creatures affected by the spell. Evil creatures take 50% more damage from a goldenfire spell and suffer a -7 penalty to the saving throw, if applicable. The spell gains the good descriptor if it does not already have it. Any spell modified with goldenfire gains a sacrifice component of 1 point of Constitution damage. A goldenfire spell uses up a spell slot 3 levels higher than the spells's actual level.
Thus you step out into the gates and...
For a moment all is light. Bright light.
Then you stand in a cavern. A cavern with walls alive with currents of power, pulsing through them - slowly, erratically. The path lies ahead, winding on into the darkness and around a corner.
The air is thick with magic, making all of your skins crawl.
Help me.
A beat of power.
Help me.
A beat of power.
Help me.
A beat of power.
Quiet but audible, each time power pulses, you hear a wordless voice beg you.
Balyss
HP: 416/416
Adrian
HP: 385/385
Sylvie
HP: 397/397
Immunity to fire
Tyche's Touch (as a reminder, that's a +4 sacred bonus to saves, then +3 and so on until expended, CL17)
Casting on self and party: Mass Death Ward CL35
"Whoa!" Calleigh says, holding her head, "That's weird!"
"The world itself begs for aid," Afina murmurs, her enhanced senses taking in their surroundings. The direction to go is fairly obvious, following those currents of power, and Afina takes point flying down the passageway.
Afina 383+20/383
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), interplanar telepathic bond (CL 26), strength of dragon princess (CL 28), mind of dragon princess (CL 28), agility of dragon princess (CL 28), endurance of dragon princess (CL 28), beauty of dragon princess (CL 28), magic tattoo (CL 24), magic tattoo (CL 24), magic tattoo (CL 24), energy immunity (sonic) (CL 26), energy immunity (acid) (CL 26), sublime revelry (CL 27), tyche's touch (CL 17), death ward (CL 35), recitation (CL 35)
defences: AC 102 (touch 64), spell resistance 42, immunity to fire, water, earth, cold, sonic, acid, disease, poison, fear, mind-affecting, critical hits, negative energy, and death effects, 25% spell failure
spell slots: 5/9/10/5/3/1/9/4/6/1/1/4/2
Moore nods to Afina as he flies along with her. "This is it, hm..."
"Help is here at long last," Jaela is all too happy to tell their ailing world.
"Sorry it took so long," Adrian adds, Gaelach out. "We're not leaving until this is finished."
"The world cries," Balyss murmurs, running her hand along the side of the wall. "Once, a gnome took an entire unborn world's power for his own, perverted all the processes of reality and struck out. I wonder if it cried as well?"
'Report,' Tepen sends to all those who still have the link up, 'Hell has renewed its offensive against all positions. Be advised.'
Oh, presumably we took all the sigils out of the vault and someone has them in their bag of holding now, right?
'Bunker down and fight defensively then,' Afina sends back to Tepen. 'We'll try and finish it on our end.'
I'll do it, I can store them fairly reliably.
Down you walk.
'Understood,' Tepen sends back. 'Good luck.'
Ahead is a large, wide and winding path. It winds around and around, a spiral wrapping down.
Afina's supernaturally potent hearing can pick up faraway footsteps from further down the spiral. Somethings' coming.
Any details about numbers or size/weight from the footsteps?
