Salvation (Everyone)
Started by Anastasia, January 03, 2018, 12:56:45 PM
They don't really have a lot of wiggle room here, but Moore moves over to the left regardless.
With everyone else dodging to the left, Afina dodges upwards to the ceiling! If it's some sort of trick or trap at least it won't get everyone.
Jaela figures she needs to extend a bit of trust, at least at first, and dodges left with most of the others.
Adrian tumbles to the wall, while Sylvie moves slower, unhurried. Balyss follows Adrian as a vast claw rips out from the floor behind all of you silently, yet not disturbing the stone at all. It is hellfire red and as big as Hanna, ripping through the space all of you were in before and...
Any of you can AoO it if you like.
My AoOs are more or less worth nothing, so I will pass.
Switching to Gae Bolg, Jaela lashes out!
[20:52] <@Lisa> roll 1d20+53+15+6
[20:52] <Rei-chan> Lisa rolled : 1d20+53+15+6 --> [ 1d20=18 ]{92}
[20:53] <@Lisa> roll 4d8+40+23+11d6+6d6 and 1 negative level
[20:53] <Rei-chan> Lisa rolled : 4d8+40+23+11d6+6d6 and 1 negative level --> [ 4d8=13 11d6=36 6d6=17 ]{129}
Init: +24 (Sign, Grace, AotDP), CHA +2, CL35
HP: 520+20/520 (+54/54 from EotDP)
AC: 95 =76base+2Foresight+3Recitation+5ShieldOfWarding+1Grace+2AotDP+6EMAdifference, 20% miss chance
Touch AC: 89 =70base+2+3+5+1+2+6
Full Attack (Gae Buidhe +7, haste, HW, K:D +5): +51/+51/+46/+41/+36, 1d8+38+3d12 goldenfire
Full Attack (Gae Bolg, GMW, Haste, HW, K:D +5, vs devils only): +53/+53/+48/+43/+38, 4d8+40+11d6 and 1 negative level
Combat: Greater Heroism +4 morale/attack, Good Hope +2 morale/damage, Recitation +3 luck/attack, Celestial Valor +4 sacred attack/damage, *CMT +2 attack/competence, SotDP +2 attack/+3 damage, Divine Might +17 damage: +15 attack, +26 damage
[not used: Divine Favor +3 luck/damage]
Gae Buidhe: The wielder acts outside of fate and destiny, they are immune to divinations (with the exception of detect good, which always reveals an overwhelming aura of good). Luck and insight bonuses to attack rolls, weapon damage rolls and DCs do not apply against attacks on the wielder, while the same bonuses to armor class and saving throws do not apply against attacks the wielder makes. Additional abilities that explicitly manipulate destiny or use it as a tool also fail (the DM's discretion is used to determine abilities that qualify for this).
Spells Active: Contingency CL36, Permanency/Greater Blindsight CL36, Permanency/Mantle of Good CL37, Shield of Warding CL31, Conviction CL31, Sublime Revelry CL31, Foresight CL31, Moment of Prescience CL29, Invisibility Purge CL34, Righteous Halo CL34, Greater Heroism CL34, Fortunate Fate CL34, Good Hope CL34, Heroes Feast CL20, Mass Death Ward CL35, Vision of the Omniscient Eye CL35, Crown of Flame CL35, Sign CL35, Divine Insight CL35, Lore of the Gods CL35, Mind Blank CL17, Epic Mage Armor CL26.
Short Duration Spells: Grace CL34, Celestial Valor CL32, Recitation CL35, Greater Displacement CL29.
Surru Spells: Strength of the Dragon Princess CL 28, Mind of the Dragon Princess CL 28, Agility of the Dragon Princess CL 28, Endurance of the Dragon Princess CL 28, Beauty of the Dragon Princess CL 28, Create Magic Tattoo (+1 CL) CL 24.
Resistances and Immunities: Fire Immunity, Cold Resistance 10, Acid Resistance 20, Electricity Resistance 20, Sonic Resistance 20, Damage Reduction 25/Epic and Evil and Cold Iron, Spell Resistance 37 (49 vs Evil spells/permanent Mantle of Good), Immunity to Disease (normal and supernatural/magical), Immunity to Compulsion effects, Immunity to Petrification, Immunity to Sickened/Nauseated, Immunity to fear and poison/Heroes's Feast, Immunity to dazzled and blinded/Vision of the Omniscient Eye, Never surprised or flat-footed/Foresight, physical damage reduced by half/Sublime Revelry.
Old: Cold Immunity, Acid Immunity, Electricity Immunity, Sonic Immunity; You are immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking/Elemental Body.
Original:
Spells Left (1-9): 10/9/9/7/9/9/8/7/8
Spells Left (10-12): 8/6/4
Current:
Spells Left (1-9): 4/3/4/2/6/7/8/4/6
Spells Left (10-12): 6/0/4
Saves: conviction +5, recitation +3, hidden dawn +7, celestial valor +4 : +19; eotdp fort +2 (2); shield of warding ref +5, foresight ref +2, haste ref +1, grace ref +1, aotdp ref +2 (11).
Saves: Fort +73, Ref +74, Will +71
Gae Bolg: GMW, Keen Edge
Gae Trocaire: GMW, Keen Edge
Gae Buidhe: Keen Edge
Turning Left: 17/20
-Smites x1
-Mountainous Fire summons
-Channeled twinned Bolt of Glory into Gae Buidhe
-Bead of Karma
-True Strike x2
-Time Stop x1
-Spell Turning x1
-Foresight x1
-Moment of Prescience x1
Taking ten for K:A 60 (64), K:N 39 (44), K:R 64 (69), K:P 64 (69), Spellcraft 54 (69)
Hidden Dawn used with Balyss
Golden Bracers (Hidden Dawn):
Flame Strike at will as an SLA
Sunburst at will as an SLA
Immunity to fire
Save bonuses increase to +7
Goldenfire damage on weapon damage rolls, natural attacks and spells and spell-like abilities with the fire descriptor rises to +6d6, unlimited range as long as on same plane.
Goldenfire Spell [Epic, Exalted]
Prerequisite: Searing Spell, con 25, must worship Lathander or another of the House of Nature
Benefit: A goldenfire spell ignores the immunity and resistance to fire of creatures affected by the spell. Evil creatures take 50% more damage from a goldenfire spell and suffer a -7 penalty to the saving throw, if applicable. The spell gains the good descriptor if it does not already have it. Any spell modified with goldenfire gains a sacrifice component of 1 point of Constitution damage. A goldenfire spell uses up a spell slot 3 levels higher than the spells's actual level.
I'm not sure how much I'll be around today, so let me get a post out now in case circumstances conspire against me.
Second line just to make sure the top line isn't missed.
Anyway, Balyss will pass and Sylvie will pass. Adrian will strike.
> roll 1d20+54 (+1 morale, +2 luck)
<Rei-chan> Kotono rolled : 1d20+54 (+1 morale, +2 luck) --> [ 1d20=10 ]{64}
> roll 2d6+44+9d6
<Rei-chan> Kotono rolled : 2d6+44+9d6 --> [ 2d6=6 9d6=37 ]{87}
Jaela and Adrian are fast as the others dodge, slicing into the claw - for little effect, hellfire fizzling out as the claw fades back into the ground.
"Typical. Cowardly, safe and annoying," Adrian says, "Wouldn't expect anything less of Hell."
Balyss
HP: 416/416
Adrian
HP: 385/385
Sylvie
HP: 397/397
Immunity to fire
Tyche's Touch (as a reminder, that's a +4 sacred bonus to saves, then +3 and so on until expended, CL17)
Casting on self and party: Mass Death Ward CL35
Recitation CL35, +2 luck to AC/attack/saving throws or +3 if you're a glorious Triune worshipper.
[/quote]
[16:54] <@Ebiris> roll 1d20+49 spellcraft
[16:54] <Rei-chan> Ebiris rolled : 1d20+49 spellcraft --> [ 1d20=8 ]{57}
Was that like a conjured hand via spell or a creature using an earth-glide sort of ability?
It was a spell, a variant of the hand spells that are well known.
Is it one that allows indirect targetting?
Does the tunnel extend in a straight line beyond Afina's 200 foot blindsight where a devil could theoretically be standing and see us?
[17:01] <@Ebiris> roll 1d20+12 DC 20 int check to notice scrying sensor
[17:01] <Rei-chan> Ebiris rolled : 1d20+12 DC 20 int check to notice scrying sensor --> [ 1d20=13 ]{25}
It seems to work by being pointed in a general direction and striking. It has some crude targeting, not coming up until it until conditions set by the caster.
The tunnel is a spiral and thus it does not, Afina.
