Gar Malleos II (Tryll, Surraruthru)
Started by Anastasia, January 08, 2018, 10:22:29 PM
> roll 1d20+57 Spellcraft: Serith
<Serith> Iddy roll for Serith < 69 > [d20=12]
HP: 691+54=745+18
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (fire) (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength of the Dragon Princess (CL28), Mind of the Dragon Princess (CL28), Agility of the Dragon Princess (CL28), Endurance of the Dragon Princess (CL28), Beauty of the Dragon Princess (CL28), Create Magic Tattoo (+1 luck ATK) (CL24), Create Magic Tattoo (+2 comp ATK) (CL24). Create Magic Tattoo (+1 CL/ML) (CL24), Energy Immunity (all elements) (CL26), True Seeing (CL30), Inertial Armor (CL30)
Bonuses: +4 insight to STR/Dex/CON/Int/CHA, +1 luck to ATK, +2 comp to ATK, +1 CL/ML, Energy Immunity, +1 morale to ATK & Will, Immune to Fear, +18 armor to AC (applies to incorporeal), 18 temp HP
Negative Conditions: 25% spell failure 1 hr
Resources Used: 45/789
HP: 345+54=399+18
There's little magic in this particular area - burnt away, perhaps. You'd have to go deeper to tell much.
"This way is the closest I can figure out. We'll need to get closer for me to be certain."
Surraruthru heads towards the source of magic!
You were here before, where in Gar Malleos are you heading to?
Tryll and Calleigh keep pace! Calleigh urges Simmer and Jetina along.
Well we never made it to the nexus or really traced the ley lines when we were here, so I'll try to follow the magic as best I can while trying to follow our original path. I believe that was over the lava and into some stone walls?
You proceed past where you fought the barricades and the Nessians - and that's when a deep groan sounds, followed by a bitter blast of unearthly cold. Only your protections stop it, Jetina shivering, "Ugh, what happened here?"
"Hell fucked everything up, as usual," Simmer grouses, rubbing her bare shoulders.
Ahead is the path to where the fire field was and its dead and, as well as the branching path to Gar Malleos proper.
Surraruthru searches for the thread of magic he was following to see where it branches off to.
"The magic I'm sensing takes us into the field there. Be wary, the lava there seemed to be directed or alive. Who knows how the destruction of the nexus effected that magic and warped it. It could be that the cold we're experiencing could be the result."
Surraruthru continues to follow the magic!
Thus you advance - and ahead the field is gone. A great chasm resides here, and rising from it is a palace of ice. It stands in the void in defiance of gravity, and atop its gate stands a familiar figure. It is a classical devil, fire red skin and standing around 10 feet tall. He's broad and lean, a smirk firmly planted on his face. He wears rich finery of green and gold, elegant and immaculate. A length of heavy chain serves as a bracelet on his right wrist. He carries no visible weapon.
Standing atop the gate's battlements is Taelfagn, the Duke of Destiny. "Welcome, Aurora," he declares, "Welcome to this fated hour."
Perceptions, y'all? Note anything like true seeing as well.
True Seeing and Detect Magic. I do plan to cast Greater Arcane Sight ASAP.
The figure radiates magic. You are out of range of true seeing affecting him, however.
