Added Light Of The Seven Heavens to the collection.
Our scheduled resumption date is the week of January 17th. So pursuant to that, what days are good for people right now?
Barring meetings and stuff, any day should be fine for me.
Mondays are busy for me, but I'm good otherwise.
I will be back in the office on Thursdays and Fridays but can phone post those days. Any other day is preferred, but I can make the other two work too.
Okay. Our days will be Tuesday, Wednesday and Friday for B6. I'd like the day off of Thursday in between and it gives me flexibility if I need to reschedule Wednesday or Friday.
Okay, anything I need to do for any of you? General callout while I'm doing DM stuff.
I think I'm good, we've got our various goals and things to do.
Proposed spell 1:
Blade of the Nosferatu
Transmutation
Level: Sor/Wiz 10
Components: V,
Range: Touch
Target: Weapon touched
Duration: 1 minute/level (D)
When you cast this spell, a wave of blood coats your weapon and drips, though the blood vanishes before touching the ground.
A weapon enchanted with this spell deals an extra 1d8 per caster level (15d8 maximum) points of damage to any living creature it hits, and you heal damage equal to this amount. The wounds inflicted by this weapon persist for 1 additional round, dealing half of the original damage in that round and healing you.
Proposed spell 2:
Superior Ability Hamstring
Transmutation
Level: Sor/Wiz 15
Components: V, S, M
Range: Touch
Target: One touched living creature
Duration: Special, see text
Saving Throw: Will special, see text
Spell Resistance: Yes
You permanently remove one extraordinary or supernatural ability of your choice from the target creature. You must know of the ability you wish to remove, either from seeing it, experiencing it, with a Knowledge check or some other means. If the creature succeeds on the Will check, the ability is instead suppressed for 1 round per caster level.
If used against a creature with spellcasting, one spell per 4 caster levels is removed from their prepared spells at random. If used against a creature with spell charges, one charge per 4 caster levels is removed instead.
Oozes, constructs or undead are immune to this spell.
Realm posts are up. I plan to update these after each adventure unless it doesn't make sense to for whatever reason.
I'll update these after sessions generally or before them, but don't expect quick replies.
Got two starting posts up, will get the other two in the morning. Got unanticipatedly sleepy.
Node updates will be tonight, overslept this morning.
Crossposting this from Alyssa's realm thread.
Twomind
Transmutation
Level: Sor/Wiz 5
Components: V, S
Range: Personal
Target: You
Duration: 10 minute/level
You create a second mind that thinks just like your normal mind. Any skill check that is purely thought based (such as a Knowledge check) gains a +2 bonus due to your expanded mind, as if it benefited from aid another, but this is only a side effect. Should you suffer Intelligence, Wisdom or Charisma ability damage or drain, your second mind is not affected and retains your full ability. This allows you to ignore such damage for the spell's duration. Once the spell's duration expires you suffer the effects of that damage or drain as normal.
