Also flavor topic is a todo tonight. For the Yuths.
Be a few in case anyone's waiting on me, I have to add proxy template to Donald.
Note to self: Don't use Rumbling in names in the future. It trips myself and Neph up.
Since my avatar is her own person I decided she would have Greater Arcane Sight Permanency'd. Otherwise, poor Amaryl will eventually get drowned by all the telepathy links.
Sure, just note the change, not a big deal.
Moore's thread is amazing right now, by the way. I'm having a blast with the sign language.
23:16 <Lucille> BTW, where can't I teleport? In the fortress?
23:16 <Lucille> Since I could presumably teleport across Avernus at the same time Alicia gates in
23:17 <Lucille> This isn't blocked?
23:17 <Lucille> Also, would Lixer know where I teleported to?
Quick note while I remember, Ebony will be given proxy status for going to Langersun since she's an epic outsider. So keep that in mind for statting her. She'll get the Silver Fire SDA.
Quote from: Ebiris on May 08, 2018, 07:22:48 PM
Okay, I'll note that when I put together her block and stuff.
Quote from: Corwin on May 08, 2018, 05:18:40 PM
Anywhere that's not dimensionally locked, astrally severed or otherwise barricaded against teleportation. Any random chunk of Avernus is probably okay, locations are dicier.
Hell Striker trivia: Hell Striker isn't talkative for a magic weapon, but it does speak up sometimes. Usually when something is obviously wrong or it has a bad feeling. Example: When Alicia need a splash of cold water in Malcanthet's realm. It also never had a channel to actual deity it knows will listen, so that's also a thing.
Quote from: Corwin on May 09, 2018, 01:45:19 AM
Generally not, though he could use magic to track you down or similar means, which in turn would contest with your defenses and so on and so forth.
Catching up on other threads again!
QuoteI'm keeping track of the spells for this, don't worry. That makes 7, by the way. Who knew regular Plane Shift might ever be useful!
Greater plane shift was Jaela's second favorite spell for a reason.  :)
That is very true, Cor.
> roll 4#1d8 Ebony
<Kobot> Kotono rolled 4#1d8 Ebony --> [ 1d8=1 ]{1}, [ 1d8=5 ]{5}, [ 1d8=5 ]{5}, [ 1d8=4 ]{4}
