Loot and Artifacts: Gimme!
Can I use the skeleton key on the chest?
Skeleton Key: This brass key can unlock any locked, sealed or barred door or object as if by a knock spell (caster level 25th). At the user's option, objects or doors unlocked with this ring automatically re-lock in one minute's time. No lock needs to be present, the key merely needs to be pressed against the door or object to be opened.
Quote from: Iron Dragoon on May 11, 2019, 03:01:45 AM
First 12 rooms:
What is Living Iron?
Living Iron is as follows:
Living Iron
Living iron appears like any other iron on first glance. When examined, it seems to squirm and writhe in a fluid-like manner. Living iron is said to have a little of the will of Dis within it and is exclusively mined from there. Living iron is suitable for weapons and armor and counts as cold iron. When one ounce is used as an optional material component for a spell that directly creates or invokes iron (wall of iron, iron body and so on), it grants a +3 bonus to the spell's caster level. Any iron created by the spell seems to writhe and slither, like iron slime.
The best use for living iron is creating prosthetic made of iron and constructs made of iron. Prosthetics made of living iron are capable of having full function compared to natural body parts. Constructs made partially of living iron have a pool of life energy to draw from, granting them +2 hit points per hit die. While useful, the expense of living iron means it is rarely seen save in golems made by Dispater.
An ounce of living iron costs 2,000 gold and a pound costs 32,000 gold.
QuoteAnything I can roll to find out if something like Effulgent Epuration would be a solid defense against whatever's guarding Glimmeye?
You could study it, but you'd have ignore that feeling of it being a really bad idea.
QuoteWhat can I do to investigate the strange fragment?
That's up to you. How do you want to investigate it?
QuoteAnd I'm def. working on the spellbook. What do I need to do to start that? Same with the network of tubes and the vials.
Give me K:A twice, once for the tube'n'vials and once for the spellbook.
Quote from: Iron Dragoon on May 11, 2019, 07:10:01 PM
You could try, sure. Will you?
[blockquote]Rolled 1d20+25 : 20 + 25, total 45[/blockquote]
It works. Inside the chest is...
Demmlar: This greataxe+6, celestial bane and unholy power has a base damage of 2d12 and deals x4 damage on a critical hit. Any celestial slain by this weapon explodes in a burst of unholy power, dealing 2d4 damage per hit die of the slain celestial to all good aligned creatures within 120ft. A Reflex save (equal to 10 + slain celestial's hit dice) halves this damage. This weapon is covered in symbols that you can tell are related to the faith of Umberlee.
Can I try the key on the spellbook?
Why not, it's basically a free attempt.
[blockquote]Rolled 1d20+25 : 19 + 25, total 44[/blockquote]
Quote from: Anastasia on May 11, 2019, 07:14:38 PM
Sure. Life's full of adventures borne from bad ideas. Before I do anything directly to it, though, I'd want to get a more general idea of what it is. Any references to it through history or what the symbol is, and then start with if there's any trap/curse magic on it.
I'd say something like K:Geography/Nature/Planes to get even an idea of what it is, came from, or properties are, then more indepth with Detect Magic or some sort of deeper divination of what it is.
K:A (+3 to this if Terrain applies)
[blockquote]Rolled 1d20+45 : 14 + 45, total 59[/blockquote]
[blockquote]Rolled 1d20+45 : 1 + 45, total 46[/blockquote]
Post 1: 416,653
An array of artwork, furnishings, valuable inlays, carpeting and other things of richness and value: 242,403 gold.
Room 1: Shalumafar
1,000 platinum coins: 10000 gold.*
20 gold ingots: 500 gold each, 10000 gold total.*
Music Box made in Mechanus, which plays a melancholy tune when opened: 2,200 gold.*
Room 4: Wylsafir
22,222 gold coins. They're notably all of identical mintage from Dis: 22,222 gold.*
222,222 silver coins. They're notably all of identical mintage from Dis: 22,222 gold.*
2,222 platinum coins and 2 gold coins. They're notably all of identical mintage from Dis: 22,222 gold.*
2 diamonds: 2,222 gold each, 4,444 gold total.*
Room 8: D'ylaran
A writ to Brightwater, worth 12,000 gold and redeemable on demand.*
A writ to Nocturnal, worth 8,500 gold and redeemable on demand.*
Room 10: Myez Windfal
Iron Collar and Chains: 25 gold.*
Room 11: Rosier
Gold and Platinum Chain: 1,400 gold.*
A gold plated human heart: 1,950 gold.*
54,390 gold coins: 54390 gold.*
Silver Chalice, inlaid with dragon fangs: 2,400 gold.*
Post 2: 252,000
Room 17: Gumalakin Manybrood
500 gold ingots: 500 gold each, 250000 gold total.*
Room 19: Lagathos Smothers
Full Body Mirror, made of gold and high quality glass: 2,000 gold.*
room 3: 0
Total value: 668,653
6 way split (Alyssa, Jarem, Emily, Ianvasah, Bastian, Soldiers): 111,442.16gp/ea
For the next post, let me know if any NPCs are interested in any specific items.
