All That Glitters
Started by Anastasia, April 30, 2018, 09:49:45 PM
Moore turns around to look at what's making the noise! He has a terrible feeling he knows what it is, though...
"Behind us!" Xandra calls as you whirl. The Eye of Shar is moving once more, glowing with a deep, malevolent darkness.
Back to init. Roll, y'all.
[23:35] <Nephrite> roll 1d20+36
[23:36] <Serith> Nephrite roll for Serith < 49 > [d20=13]
> roll 1d20+29 Cresiel
<Serith> Kotono roll for Serith < 47 > [d20=18]
> roll 1d20+20 Xandra
<Serith> Kotono roll for Serith < 38 > [d20=18]
> roll 1d20+25 Eye of Shar
<Serith> Kotono roll for Serith < 45 > [d20=20]
Init is Moore (49) > Cresiel (47) > Eye of Shar (45) > Xandra (38)
Open Moore.
"So let's try something stronger!" Moore shouts as he throws his hands out to try a disjunction this time!
Rolling against +30 because that's his caster level. Not sure what level it should be rolled at if there is one for that spell.
[23:50] <Nephrite> roll 1d20+30 please eat a dick shar
[23:50] <Serith> Nephrite roll for Serith < 40 > [d20=10]
I do also still have a swift and a movement, so I'll take those after seeing whatever this does.
Unfortunately Shar's all out of dicks.
Your dispel hits the Eye of Shar and nothing seems to happen, no visible reaction.
Can I tell if it failed or if it succeeded and just hasn't seemed to have any visible impact?
You aren't sure, but no visual response or obvious sign is usually a sign of failure or of subtle magic being dispelled.
Okay. He's going to hope it did something!
"It should be somewhat weakened from before, but make sure you don't let it touch you if possible!" Moore shouts to the others. He flies up and away from the others to try and make it less easy for the Eye to have a target. "Just use whatever magic you have and we'll have to see if that does something!"
As Cresiel begins to heal, he continues to hold his position aganist the Eye, turning around and praying, "Oh glorious Sealtiel, let your light shine against the wicked."
Bolt of Glory.
> roll 1d100 vs 50 miss chance
<Kobot> Kotono rolled 1d100 vs 50 miss chance --> [ 1d100=19 ]{19}
But this time the bolt is knocked away, distorted into a thin needle that whizzes by it harmlessly. As this happens an earth elemental, human sized, erupts from the ground...and grazes the Eye, gone instantly. As this happens...
The Eye of Shar is up
The Eye again glides towards Cresiel, relentless as...
> roll 1d20+40 touch AC Cresiel
<Kobot> Kotono rolled 1d20+40 touch AC Cresiel --> [ 1d20=19 ]{59}
> roll 1d20+40 Cresiel fort
<Kobot> Kotono rolled 1d20+40 Cresiel fort --> [ 1d20=9 ]{49}
> roll 80d6+10d6
<Kobot> Kotono rolled 80d6+10d6 --> [ 80d6=287 10d6=34 ]{321}
Owwie.
Another touch as Cresiel holds the line. Entire gaping hunks of him are gone, bleeding profusely onto the ground. As his blood darkens and shadows in contact with it, Cresiel somehow stays standing, even though most of his abdomen and chest are but a memory.
Xandra and Moore. Go ahead and go as I work up Xandra's go, Moore.
Cresiel
HP: 127/680
Spells Active: Tyche's Touch (CL30),
Bonuses:
Resources Used: Mass Death Ward, Burst of Gloryx3, Heal 29/30 holy fury.
Xandra
HP: 510/510
Bonuses:
Resources Used: 1 11th level charge, 1 12th level charge.
Mass Conviction (+4 morale bonus to saving throws) (CL19) (190m)
Mass Surefooted Stride (can move through difficult terrain with no penalty. What??? they might run into it) (CL30, 30m)
Surge of Hope (CL30) (30m) (+4 morale bonus on attack rolls, ability checks, skill checks, and weapon damage rolls) (it does saving throws too but that's really pointless with conviction)
Life's Grace (CL19)x2 (Cresiel, Xandra) (19m) (protects against ability drain and all that jazz, armor is treated as ghost touch)
[23:32] <Nephrite> roll 18d4 nonlethal
[23:32] <Serith> Nephrite roll for Serith < 44 > [d4=2,4,2,2,2,4,1,4,1,3,3,3,2,3,1,4,2,1]
He'll bolster the three of them with Inspire Heroics for +12 morale bonus to save (doesn't stack with conviction but it's only temporary) and a +12 dodge bonus to AC. This lasts a total of 60 rounds, i.e. 10 minutes.
Right before they leave he'll also cast Haste.
Cresiel will drop Mass Death Ward, CL 27th. He'll drop Shield of Warding on himself for +5 sacred Reflex and AC.
Moore will also toss in a Superior Resistance to both Xandra and Cresiel. (+6 resist bonus to saves) (CL30)
+16 morale bonus on saving throws against charm and fear effects and a +16 morale bonus on attack and weapon damage rolls
Recitation, (+2 luck bonus to AC, attack rolls and saves.)
Moore flies over to Cresiel and puts a hand on him.
"It is not your time yet. Get far away from it, it shouldn't be able to move that far. I can handle this thing." He says quietly.
Heal, 150 restored to Cresiel.
As Cresiel's wounds heal, Xandra eyes the Eye before her. She gestures, stepping back to the side carefully and...
<Kobot> Kotono rolled 1d100 vs 50 miss chance --> [ 1d100=6 ]{6}
A scything blade of force hits the Eye of Shar, yet is deflected away, torn apart like paper.
Cresiel is up in the next post.  Adding his healing from you now.
Cresiel
HP: 277/680
Bonuses:
Xandra
HP: 510/510
Bonuses:
Resources Used: 2 11th level charge, 1 12th level charge.
[/quote]
Sorry. Remember, if I do a split post and just don't reply, I probably brainfarted it. Smack me in nagging. Coming up in the next post for real now.
Cresiel simply heals and falls back at your command, as...
Divine succor 27/30 and heal for 220 healing total.
As Cresiel dodges, the Eye whirls on Moore, drifting towards him with stunningly rapid flight.
> roll 1d20+40 touch AC Moore
<Kobot> Kotono rolled 1d20+40 touch AC Moore --> [ 1d20=15 ]{55}
Does that hit you, Moore?
Cresiel
HP: 497/680
Bonuses:
Xandra
HP: 510/510
Bonuses:
[/quote]
