A New Beginning
Started by Anastasia, April 30, 2018, 09:59:30 PM
If I augment it, it gets crazy high. But the saved amount doesn't change.
Oops, it's 22d6
[blockquote]Rolled 20d6 : 1, 4, 5, 4, 3, 3, 5, 1, 2, 4, 2, 2, 5, 6, 3, 3, 2, 3, 4, 3, total 65[/blockquote]
> roll 1d20+15 Fort
<Serith> Kotono roll for Serith < 22 > [d20=7]
A big hunk of the foot is just gone as Ebony rises, flames burning around her. She bows her head and chants, "Symbol of locking the seven gates, come together and begone!"
Dismissal.
> roll 1d20+12 this is not an elemental's good save, usually
<Serith> Kotono roll for Serith < 15 > [d20=3]
With a moaning crackle of flame, all the heat vanishes, cast back to whence it came. Only a flame-charred room remains, no obvious doors about - but no elemental, either. You won!
Free act.
Ebony
HP: 570/570
Spells Active:
Bonuses:
Resources Used: 1 5th level bard spell, 1 5th level sorcerer spell, 1 8th level sorcerer spell.
"Is it over? Is the hand-foot fire guy gone?" Calleigh asks, poking out of the ceiling.
'Yes.'
"Yay!" she cheers, "Good job!"
Ebony dusts herself off, "Onward, we have a genocidal fire elemental to quench. But thank you, nonetheless."
'Yes, please. Let's finish this up.' Tryll looks for the way forward.
[blockquote]Rolled 1d20+47 : 1 + 47, total 48[/blockquote]
Amid all the burnt-ness and ruin, Tryll notices the outline of what may be a door on the far southern wall.
Tryll attempts to pry it open with telekinesis!
Which function of the ability, to be clear?
I'm taking liberties. 2/5 of our PCs are gods. I'm epic. I'm a paragon. I have:
Quote-Telekinetic Force (Su): An unbodied can use telekinetic force as a standard action that does not provoke attacks of opportunity. Manifester level 4th. The save DC is Charisma-based.
Paragon: Expanded - Instead of using a measured amount of force, Tryll can choose to cleverly apply overwhelming strength in battle. Once per encounter as a standard action, Tryll can use mental force to imitate the Telekinetic Maneuver against another creature. Treat this power as having been augmented to his current manifester level. This power cannot be augmented further.
I'm trying something new. If two of our PCs can be gods, I can use my brain to pry open a door.
Yeah, I'm fine with it, I just wanted to know for DMy reasons and things that may be in play beyond Tryll's current perception, that's all.
With a push of telekinetic power, the door is opened. A flash of burning fire gushes out, charring none of you from your position safely far away. It looks like it leads into a hallway that quickly hooks to the left, curving out of sight.
Groovy, thanks.
"Dramatic and thematic! Drathematic?" Calleigh ponders.
'Quite.' Tryll says, heading through the door.
Ebony arches an eyebrow, but says nothing.
The path ahead is carved of solid stone and smoothed over, a glassy sheen over it. LIght comes from the occasional torch, no smoke coming from them. It goes to a single door at the end of the passage.
You can notice a tripwire about 25ft from the door, kept low on the ground. Your true seeing also lets you see a bevy of invisible wires above and around it.
'Tripwires, both visible and not. Hm. Let's have a look at what they trigger.' Tryll skims the walls, phasing partially to see what awaits them.
