Treasure Ship Hunt
Started by Anastasia, May 18, 2018, 10:02:52 PM
I figured it was some sort of Slaad. If I could confirm that, that's what I'm looking for.
It probably is, but it could be something froggy and unrelated. A ribbit just isn't a lot to go off of.
"... I have a feeling that was a Slaad of some sort. Be on the watch."
She goes back to inspecting the place, trying to figure out what's to be done here with the distortion, inspecting the crystal.
As you slowly study the crystal, you glance up and see it. At the same time Jarem's moving, "Down!" he calls, shield out and rushing to your position. A stream of ghostly, gnawing piranhas are darting right towards you, dozens and dozens all coming at you.
Can I identify if this is actually dangerous or just some weird apparition thing?
Alyssa uses her Dimension Door ability to teleport herself and Jarem away and out of danger, to the other side of the crystal.
Oh boy. Make a Spellcraft check.
> roll 1d20+42 Spellcraft
<Serith> Iddy roll for Serith < 62 > [d20=20]
Teleporting next to this sort of distortion? Probably not wise. The magic immediately collapses, only a quick control by Alyssa stopping it from scrambling her and Jarem like eggs. Jarem meanwhile shoves you aside, taking the assault head on and...
> roll 1d20+37 evasion
<Serith> Kotono roll for Serith < 53 > [d20=16]
Jarem's shield holds, devouring ghost piranha's deflected away. They split around him and loop back, the stream quite long indeed. It comes, perhaps 30ft away and just visible through the fog. A frog-like humanoid, a dull white color, the same as the mists here. It ribbits again as the ghosty piranha swirl around it, as...
Init.
> roll 1d20+11 init
<Serith> Iddy roll for Serith < 17 > [d20=6]
Alyssa Songsteel
HP: 288/288
AC: 57.
Init: +11.
Inspiration: 1/12
[spoiler]Spells Active: Magic Vestment (CL29) Heart of Fire (CL29), Heart of Air (CL29), Create Magic Tattoo (SR/Spellcaster Level/Attack) (CL29/25/21), Elemental Body (CL29), Mind Blank (CL29), Bibliotheca Arcana (CL29), Energy Immunity: Cold/Acid (CL29), Energy Immunity: Electricity (CL25), Energy Immunity: Sonic (CL22) Many Moments of Prescience (CL29), Epic Mage Armor (CL29), Heroics (CL30), Dragonskin (CL30), Spell Turning (CL30), Sonic Weapon (CL30), Dolorous Blow (CL30), Greater Mirror Image (9 Images) (CL30), Greater Arcane Sight (CL30), Dancing Blade (CL30), Improved Blink (CL30)
Bonuses: +10 Ground Speed (HoF), +10 Fly Speed (HoA), SR 19 (CMT), +1 Caster Level (CMT), +1 Luck Attack (CMT), +15 Insight Bonus to Knowledge checks (BA), +20 Armor Bonus (EMA), +5 Armor Bonus/Shield (MV), +4 Initiative (Heroics), +5 NA (DS)
[/spoi
> roll 1d20+5 Jarem
<Serith> Kotono roll for Serith < 13 > [d20=8]
> roll 1d20+12 frog man
<Serith> Kotono roll for Serith < 19 > [d20=7]
Init is Frog Man (19) > Alyssa (17) > Jarem (13)
Frog Man opens.
The stream of piranha flies forth. looping around and around in a helix, before coming right at you.
Reflex.
> roll 1d20+20+6 Ref Save
<Serith> Iddy roll for Serith < 37 > [d20=11]
> roll 20d6 halve this
<Serith> Kotono roll for Serith < 82 > [d6=5,5,3,4,6,4,1,6,6,6,4,1,2,6,4,5,6,1,6,1]
Force damage.
OW. You dodge to the side by ghostly fish still gnaw against your shoulder and ribs, drawing blood. You can't see the frog-man, slaad or not, well from here. With the mists, you'd need to get closer, they're hiding him quite well.
Go.
Alyssa flies towards the thing, stopping close enough to get a good view of it before she begins casting a spell!
Summon Monster 7: Fire Elemental, Huge.
Duration: 30 rounds.
Alyssa Songsteel
HP: 247/288
AC: 57.
Init: +11.
Inspiration: 1/12
You fly 10ft forward, 30ft away now. The mists do not clear, clinging to it instead. It doesn't seem to be going away. You could continue to get closer if you want or cast now.
Is this something my True Seeing would beat?
