Treasure Ship Hunt
Started by Anastasia, May 18, 2018, 10:02:52 PM
Spending 1/12 inspiration.
> roll 1d20+17+6+9 Fort Save/Sup. Res./Cunning Insight
<Serith> Iddy roll for Serith < 42 > [d20=10]
Alyssa Songsteel
HP: 288/288
AC: 57.
Init: +11.
Inspiration: 1/12
Spells Active: Magic Vestment (CL29) Heart of Fire (CL29), Heart of Air (CL29), Create Magic Tattoo (SR/Spellcaster Level/Attack) (CL29/25/21), Elemental Body (CL29), Mind Blank (CL29), Bibliotheca Arcana (CL29), Energy Immunity: Cold/Acid (CL29), Energy Immunity: Electricity (CL25), Energy Immunity: Sonic (CL22) Many Moments of Prescience (CL29), Epic Mage Armor (CL29), Heroics (CL30), Dragonskin (CL30), Spell Turning (CL30), Sonic Weapon (CL30), Dolorous Blow (CL30), Greater Mirror Image (9 Images) (CL30), Greater Arcane Sight (CL30), Dancing Blade (CL30), Improved Blink (CL30)
Bonuses: +10 Ground Speed (HoF), +10 Fly Speed (HoA), SR 19 (CMT), +1 Caster Level (CMT), +1 Luck Attack (CMT), +15 Insight Bonus to Knowledge checks (BA), +20 Armor Bonus (EMA), +5 Armor Bonus/Shield (MV), +4 Initiative (Heroics), +5 NA (DS)
> roll 5d10
<Serith> Kotono roll for Serith < 23 > [d10=2,8,1,9,3]
Halve this.
OW! As you appear you feel a sharp pain, parts of your body stinging from the teleport. That -hurt-!
Make your blade's attacks.
> roll 1d20+25 ATK 1
<Serith> Iddy roll for Serith < 30 > [d20=5]
> roll 1d20+25 ATK 2
<Serith> Iddy roll for Serith < 38 > [d20=13]
> roll 1d20+25 ATK 3
<Serith> Iddy roll for Serith < 40 > [d20=15]
> roll 1d20+25 ATK 4
<Serith> Iddy roll for Serith < 35 > [d20=10]
Forgot Greater Magic Weapon, +5 to all of those. So the results are: 35/43/45/40.
ATK 1: > roll 1d10+5+1d6+1d6 Desiccating Sure Strike Heavy Flail +Sonic Weapon
<Serith> Iddy roll for Serith < 16 > [d10=1][d6=6,4]
ATK 2 (add +2d6 if this thing can prepare arcane spells): > roll 2d6+5 Magebane Shattermantle Greatsword
<Serith> Iddy roll for Serith < 15 > [d6=5,5]
> roll 2d6 Magebane
<Serith> Iddy roll for Serith < 6 > [d6=3,3]
ATK 3 Crossive Eager Rapier (Auto-confirm Crit via Dolorous Blow, second 1d6 is Corrosive): > roll 2#1d6+5+1d6
<Serith> Iddy roll for Serith < 13, 12 >
ATK 4 (Silver): > roll 1d4+5
<Serith> Iddy roll for Serith < 6 > [d4=1]
Alyssa Songsteel
HP: 288/288
AC: 57.
Init: +11.
Inspiration: 1/12
It's immune to crits, so reroll the crit damage for normal? Mechanically it's an ooze and they're immune to them from the ooze type.
> roll 1d6+5+1d6  Crossive Eager Rapier
<Serith> Iddy roll for Serith < 9 > [d6=1,3]
Blow after blow hits the Living Filth. It's strong - your weapons struggle to damage it, but the sonic bursts and particularly the desiccating weapon seem to injure it a bit, the latter sucking the liquid right out of it or close enough.
Jarem.
Jarem merely points his blade to the air, "Mistress of Tactics, strike down those unworthy!" From above a massive bolt of lightning hits, slamming into the Living Filth.
Wrath of the Heavens.
> roll 20d10
<Serith> Kotono roll for Serith < 114 > [d10=1,9,1,10,1,8,8,2,10,8,6,6,1,9,5,9,3,5,6,6]
> roll 1d20+22 Fort
<Serith> Kotono roll for Serith < 33 > [d20=11]
The shock makes the Living Filth vibrate all over, wildly shaking from the blast as...
Minions.
Fire, ice, lightning. The elements are sent in a volley at the ooze, striking the Living Filth all over.
> roll 1d20+12 Reflex
<Serith> Kotono roll for Serith < 14 > [d20=2]
The Living Filth is battered by all of them - frozen, shocked, burned and more. An array of brilliant colors light of the grimy, sickening muck around you as the Living Filth writhes, before starting to swim and flow down and away, retreating at a fast clip.
Withdraw action. Alyssa, go. It's 240ft away now after withdrawing to avoid any AoOs.
Jarem
HP: 462/462
Spells Active:
Bonuses:
Resources Used: Wrath of the Heavens
Forgot to roll the 1d4 for Dimension Door cooldown:
> roll 1d4
<Serith> Iddy roll for Serith < 1 > [d4=1]
Are Oozes legal for Nerve Overload?
Creatures without nerves or who do not feel pain are immune to this spell.
They are not. They have no nerves. Also, isn't that a cleric only spell, so how did you get it?
By searching for transmutation and not noticing the cleric part. Will fix.
Alyssa starts casting a spell!
Haste, CL 30, Duration: 30 rounds.
Up to 30 creatures, so everyone in the party.
When making a full attack action, a hasted creature may make one extra attack with any weapon he is holding. The attack is made using the creature's full base attack bonus, plus any modifiers appropriate to the situation. (This effect is not cumulative with similar effects, such as that provided by a weapon of speed, nor does it actually grant an extra action, so you can't use it to cast a second spell or otherwise take an extra action in the round.)
A hasted creature gains a +1 bonus on attack rolls and a +1 dodge bonus to AC and Reflex saves. Any condition that makes you lose your Dexterity bonus to Armor Class (if any) also makes you lose dodge bonuses.
All of the hasted creature's modes of movement (including land movement, burrow, climb, fly, and swim) increase by 30 feet, to a maximum of twice the subject's normal speed using that form of movement. This increase counts as an enhancement bonus, and it affects the creature's jumping distance as normal for increased speed.
Multiple haste effects don't stack. Haste dispels and counters slow.
With her new speed, Alyssa will fly after the thing!
100ft movement per round, flying.
You have a telepathic bond up, right?
Nope, couldn't quite fit it.
That it this round then?
Fire support stops as the creature flees away, even farther as it still outspeeds you. It's getting well away by now, harder and harder to see in the muck.
Go.
Alyssa waits for the others to catch up, unwilling to be drawn out by herself more than necessary.
