The assault on Salty Pier
He'll let it go and try and follow if possible!
The weapon vanishes a moment later, a scrap of paper drifting into your hand in place of it.
Moore will take the piece of paper to read it!
It reads as follows. 'Interesting! Studying it now, I'll improve it too!'
Moore comes back down to the others. "Well, that was... easier than I thought it would be. I guess we're just waiting to hear back."
Xandra takes the note and takes a breath out, "Improving it, hm?"
"Well," Jetina smiles, "That actually worked. I suppose it is true, deities hear everything in their realm."
"It makes sense." Moore says with a nod. "I think it helps that we're... um... important dignitaries, as it is."
Paste me the stats for Refrain?
Refrain is a small rapier+4, keen. Whenever you use bardic music while holding or wielding Refrain, echos strengthen your music. Your bard level is considered 3 higher to determine the variable effects of your bardic music. Additionally, you may use bardic music an additional three times per day.
It's not long until Refrain reappears, just a few moments later. A note is attached.
You can note there are now four buttons on the lower blade.
Moore will look at the note!
IT reads, 'Added some functions to it. Try them out! Push buttons alone and together.'
Moore shrugs and decides to try pushing the first button first to see what happens, then push the first and second button together.
Huh. The first button causes tiny vents along the rapier to open up, venting hot steam from both sides. It lasts for several seconds before relenting.
The first and second button together causes the rapier to glow with bright light. It doesn't stop glowing.
Xandra looks on, "I fear his definition of improvements is...vast.":
"He is the wonderworker." Moore says. Moore holds the rapier up again, as if to showcase it.
"We are in seek of Oghma, Lord Gond. We need to speak to him about __ and his return." Moore says -- quietly, but with conviction. "You yourself can see His influence on this weapon already."
