Guilding
Started by Anastasia, July 17, 2018, 11:24:54 AM
> roll 1d20+43+15 K:P/Bibliotheca
<Serith> Iddy roll for Serith < 70 > [d20=12]
The Quasi Elemental Plane of Radiance is between Fire and the Positive Energy Plane. It is a place of pure light and energy, blinding to normal creatures who end up there.
- Without protection, creatures are blinded here.
- It's largely void of matter, being pure light, but islands of material exist.
- Light magic is much stronger here and darkness magic is far more difficult.
- Most of the natives are adapted to it, so be careful.
Largely it's a no-man's land, not a lot of forces invested in it. Various entities related to light have interests here, but by and large it's a wild frontier. This means it's largely neutral overall, though good has several places it's strong in, as light and good are strongly linked. As such, it's valued for being a neutral ground to sort all sorts of things out without being observed.
So just that planar protect spell is all that's needed?
I don't have that in my spell book. Does the guild have it that I can learn?
Sure, it's a common planar spell.
I shall learn it! Or rather, what level is it? I can leave a slot open and spellpool it. On my phone at lunch with family so my referencing abilities are limited.
It depends on which one you want, there's a few. Check the SC.
Planar Tolerance, level 5 spell seems to fit the bill best.
Then you have it. Anything else? Need to prep spells?
#206
Just that I think? That spell will last 32 hours, so. Just to cover basis, lemme post buffs again. I've separated them between everyone and self only buffs.
Everyone:
Create Magic Tattoo: +1 Spellcaster Level, CL 32, Duration: 24 Hours.
+1 spellcaster level.
Magic Vestment +5 (Shield), CL 23, Duration 23 Hours.
+5 armor bonus to armor/shield. (+2 via Mind over Matter: Total bonus +7)
Create Magic Tattoo: Spell Resistance 28, CL 31, Duration: 24 Hours.
Spell resistance equal to 10 + 1 per three caster levels.
Create Magic Tattoo: +1 Luck to Attack, CL 24, Duration: 24 Hours.
Greater Magic Weapon: Shifting Steel +5, CL 32, Duration: 32 Hours.
enhancement bonus on attack and damage rolls of +5
Heart of Air, CL 32, Duration: 32 Hours.
+10 enhancement bonus on Jump checks, and if you have a fly speed, that speed gains a +10-foot enhancement bonus.
Mind Blank, CL 32, Duration: 24 Hours.
This spell protects against all mind-affecting spells and effects as well as information gathering by divination spells or effects. Mind blank even foils limited wish, miracle, and wish spells when they are used in such a way as to affect the subject's mind or to gain information about it. In the case of scrying that scans an area the creature is in, such as arcane eye, the spell works but the creature simply isn't detected. Scrying attempts that are targeted specifically at the subject do not work at all.
Self Only:
Elemental Body (Fire), CL 32, Duration: 32 Hours.
You have the benefits of the attune form spell (page 17) with respect to the appropriate element.
You are immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking. You gain darkvision out to 60 feet.
Bibliotheca Arcana, CL 32, Duration: 24 Hours.
+15 insight bonus to all knowledge checks and may make knowledge checks untrained. Perfect recall of memory and anything heard/read. Speak all languages.
Energy Immunity (Cold), CL 32, Duration: 24 Hours.
Immunity to Cold.
Energy Immunity (Electricity), CL 28, Duration: 24 Hours.
Immunity to Electricity.
Energy Immunity (Acid), CL 32, Duration: 24 Hours.
Immunity to Acid.
Energy Immunity (Sonic), CL 28, Duration: 24 Hours.
Immunity to Sonic.
Many Moments of Prescience (3 uses), CL 32, Duration: 32 Hours.
This spell is identical to moment of prescience, 3 uses. The insight bonus equals your caster level (maximum +30).
Epic Mage Armor, CL 32, Duration: 32 Hours.
This spell is identical to mage armor, except that it grants a +20 armor bonus to armor class. (+2 bonus via Mind over Matter: Total bonus +22)
Alyssa Songsteel
HP: 294/294
AC: 57.
Spells Active: Magic Vestment (CL21), Heart of Air (CL30), Create Magic Tattoo (SR/Spellcaster Level/Attack) (CL29/25/21), Elemental Body: Fire (CL30), Mind Blank (CL30), Bibliotheca Arcana (CL30), Energy Immunity: Cold/Acid (CL30), Energy Immunity: Electricity/Sonic (CL26), Many Moments of Prescience (CL30), Epic Mage Armor (CL30)
Bonuses: +10 Fly Speed (HoA), SR 19 (CMT), +1 Caster Level (CMT), +1 Luck Attack (CMT), +15 Insight Bonus to Knowledge checks (BA), +22 Armor Bonus (EMA), +7 Armor Bonus/Shield (MV), +1 Caster Level (Ioun Stone)
Okay, I may adjust Emily and Jarem's spells a bit for this, please hold.
Oops, forgot about this one:
Everyone:
Planar Tolerance (Radiance), CL 32, Duration: 32 hours.
Gain temporary respite from the natural effects of a specific plane.
One more thing I really should have mentioned: Do you want Jarem or Emily to provide any spells?
