Finding Calley
Is that it...? ...
Yes, ... that is it exactly, isn't it.
Moore grins from his place on the ground and makes a gesture.
Permanent Image, he's casting it over Xandra and Jetina and making as many of duplicates of them, all making noises appearing to cast spells as can fit in that square. Including off the ground and other things. It's going to be a lot of noise and magical effects in that area!
He's got 20-ft. cube + one 10-ft. cube/level and at level 30 so that's 320 ft of Xandras and Jetinas.
He's also refreshing Inspire Greatness for the temporary HP again on everyone.
[blockquote]Rolled 8d10 : 10, 10, 1, 10, 10, 7, 8, 7, total 63[/blockquote]
I can't make an edit in the post without the dicebot angrily telling me I'm a cheater, so just to add he's trying to also make it look like the spells are getting to the efreet and company with the illusion, if that matters and the asshole doesn't just break that spell too. Hopefully since it isn't hostile it just works though!
Where exactly is the spell laid relative to them?
More or less in between them as a starting point.
By them I meant the worm and baddies, to be perfectly clear here.
Dur, my bad.
Oh, so... uh... I'll try and explain this as best as I can. so he's got 320 feet to use, so he's using like, say, 250 feet for the copies, then the rest of the 70 feet to go across the room and sparkle all over them, so it's probably like all around whatever the front end is, if that makes sense?
Gotcha.
You cast your spell - and the efreet raises his hand anew, more spellfire flowing around him. "You think you can overcome this? Hah! Nothing can hide from me!"
"Just wait," Kaja snarls back.
Anything else this turn?
Does it matter that it's a spell-like ability and not an actual spell? Also, I'm really disappointed that non-hostile effects are getting absorbed by this!
No, I have nothing else to do on this turn.
It does not, unfortunately. OOC, I like what you're trying here, you're just not managing to get around the asshole's armor.
Kaja pauses, Cresiel stepping forward and charging.
Kaja holds to let Creisel deal with the AoO.
> roll 1d20+100 (+24 various, +10 ???, +5 ???, +8 ???)
<Rei-chan> Kotono rolled : 1d20+100 (+24 various, +10 ???, +5 ???, +8 ???) --> [ 1d20=8 ]{108}
> roll 6d8+58
<Rei-chan> Kotono rolled : 6d8+58 --> [ 6d8=28 ]{86}
No improved grab, size differences matter here.
Cresiel charges in shield first, pushing past the worm as it bites his side. He ignores the injury, already knitting together as he brings his hammer up and...
> roll 2d6+36+2d6+7d6
<Rei-chan> Kotono rolled : 2d6+36+2d6+7d6 --> [ 2d6=9 2d6=5 7d6=27 ]{77}
WHAM! A direct hit, the worm taking it in the body. Scales crack from the blow, blood oozing out as...
Kaja in the next post, chance to react since combat posts are long.
Add mass valiant fury, +6 str/con and haste bonus attack.
Cresiel
HP: 700 (68)/700 (fast healing 11, regeneration 17)
Spells Active: Haste (CL30), Surge of Hope (CL30), Celestial Valor (CL31) Mass Energy Immunity (Fire) (CL31), Mass Death Ward (CL31), Fortunate Fate (CL31), Divine Agility (CL31)
Bonuses: +18 morale attack rolls, weapon damage rolls, saves vs charm/fear, +8 attack rolls, +3 fort saves, +12 morale to saves, +12 dodge to AC, fast healing 11, +1 attack rolls, +1 attacks on full attack, +1 ref, movement speed boost, +4 morale attack rolls, weapon damage rolls, saving throws, ability checks, skill checks, immunity to fear, +8 sacred vs negative emotion, +4 sacred attack rolls, armor class, saving throws, weapon damage rolls, immunity to fire, +10 enhancement agility.
Resources Used: Burst of Glory, Divine Agility,
Xandra
HP: 521+40/521 (fast healing 11)
Spells Active: Haste (CL30), Surge of Hope (CL30), Celestial Valor (CL31) Mass Energy Immunity (Fire) (CL31), Mass Death Ward (CL31), Fortunate Fate (CL31), Jetina's Deathlessness (CL31)
Bonuses: +18 morale attack rolls, weapon damage rolls, saves vs charm/fear, +8 attack rolls, +3 fort saves, +12 morale to saves, +12 dodge to AC, fast healing 11, +1 attack rolls, +1 attacks on full attack, +1 ref, movement speed boost, +4 morale attack rolls, weapon damage rolls, saving throws, ability checks, skill checks, immunity to fear, +8 sacred vs negative emotion, +4 sacred attack rolls, armor class, saving throws, weapon damage rolls, immunity to fire, immune to negative energy, energy drain, ability damage, ability drain, poison, paralysis and stunning, half of damage is nonlethal damage
Kaja
HP: 453 (62)/515 (fast healing 11)
Resources Used: 1 dervish dance
Jetina
HP: 412 (67)/478 (fast healing 11)
In total:
Attack: +31
Weapon damage: +22
AC: +16 (4 sacred, 12 dodge)
Saving throws: +16 (4 sacred, 12 morale)
Fast Healing 11
Moore can't do much but pray for this to keep working!
Jetina will need to get ready to heal, likely...
Kaja races in, "Take down the worm!" he roars, blade dancing out and...
> roll 1d6+68+2d6
<Rei-chan> Kotono rolled : 1d6+68+2d6 --> [ 1d6=2 2d6=5 ]{75}
Another slice into the worm, bleeding it now, making the beast rock back and forth before it begins to ascend, "No chance!" Kaja snaps, blade dancing out again.
It's AoO bait.
> roll 1d20+76 (+31 Moore, +1 haste) Cresiel AoO
<Rei-chan> Kotono rolled : 1d20+76 (+31 Moore, +1 haste) Cresiel AoO --> [ 1d20=19 ]{95}
> roll 1d20+76 (+31 Moore, +1 haste) Cresiel AoO crit?
<Rei-chan> Kotono rolled : 1d20+76 (+31 Moore, +1 haste) Cresiel AoO crit? --> [ 1d20=17 ]{93}
> roll 1d20+86 (+31 various) Gem AoO
<Rei-chan> Kotono rolled : 1d20+86 (+31 various) Gem AoO --> [ 1d20=7 ]{93}
> roll 6d6+108+2d6
<Rei-chan> Kotono rolled : 6d6+108+2d6 --> [ 6d6=20 2d6=7 ]{135}
> roll 1d6+68+2d6
<Rei-chan> Kotono rolled : 1d6+68+2d6 --> [ 1d6=2 2d6=9 ]{79}
Nice timing.
The worm is sliced deeply into anew, Kaja striking. At the same time Cresiel brings his hammer down on the same point, tear propelled ahead. A clean cut! Blood sprays as the worm is severed, bottom half writhing and gushing blood, head falling to the ground. The enemy lands there, "No mercy!" The pit fiend snaps as...
Init is Moore (53) > Kaja (52) > Cresiel (48) > Distorted Woman (42) > Worm = Human = Pit Fiend = Efreet (17) > Jetina = Xandra (16)
Baddies are up, more in the next post with the distorted woman going. Chance to react.
"You can never kill hope!" Moore shouts. "Go ahead and try -- you'll just lose, brought down against by one of Aurora's heroes, just like Lifasa, just like Taelfagn!"
Let's see if he can goad them into attacking him. :)
Worth a shot.
Landing in a crouch, the disfigured woman withdraws another shuriken from her body and aims, right at her as she steps back, behind the rest of them.
> roll 1d20+86 (+24 ??? (various condensed), +3 ???, +8 ???, +1 ???)
<Rei-chan> Kotono rolled : 1d20+86 (+24 ??? (various condensed), +3 ???, +8 ???, +1 ???) --> [ 1d20=10 ]{96}
> roll 1d2+39+2d6
<Rei-chan> Kotono rolled : 1d2+39+2d6 --> [ 1d2=1 2d6=9 ]{49}
> roll 1d100 vs 20
<Rei-chan> Kotono rolled : 1d100 vs 20 --> [ 1d100=19 ]{19}
Your luck is turning.
The shuriken flies for your neck, yet it simply blurs through you. No wound! Your cloak - did it ever pick a time to phase you perfectly.
Meanwhile the worm continues to writhe, already the bleeding stopping. New flesh is rising up rapidly, a foot of neck already having regrown. Amid this the human brings his hands together and grimaces, intoning in Infernal, "Great Duke of Purity, reveal the weakness of their flesh!" Beams fly at Jetina and Xandra, who...
<Rei-chan> Kotono rolled : 1d20+70 (+24 ??? (various condensed), +1 ???, +4 ???, +1 ???) touch AC Xandra --> [ 1d20=20 ]{90}
> roll 1d20+70 (+24 ??? (various condensed), +1 ???, +4 ???, +1 ???) touch AC Jetina
<Rei-chan> Kotono rolled : 1d20+70 (+24 ??? (various condensed), +1 ???, +4 ???, +1 ???) touch AC Jetina --> [ 1d20=7 ]{77}
> roll 1d20+70 (+24 ??? (various condensed), +1 ???, +4 ???, +1 ???) touch AC Xandra Crit checkski
<Rei-chan> Kotono rolled : 1d20+70 (+24 ??? (various condensed), +1 ???, +4 ???, +1 ???) touch AC Xandra Crit checkski --> [ 1d20=9 ]{79}
ACs?
I'm not really going to bother searching for the numbers because their ACs aren't even that high, so it hits them both. They're both immune to negative energy if it matters.
> roll 17d6+3d6+1d6+2d6 Jetina
<Rei-chan> Kotono rolled : 17d6+3d6+1d6+2d6 Jetina --> [ 17d6=64 3d6=11 1d6=4 2d6=7 ]{86}
> roll 17d6+3d6+1d6+2d6 Xandra
<Rei-chan> Kotono rolled : 17d6+3d6+1d6+2d6 Xandra --> [ 17d6=67 3d6=16 1d6=3 2d6=4 ]{90}
Need Fort saves from both of them. Damage adjustments in the next post.
