Finding Calley
Jetina blocks with her shield, lightning crackling around it but not through it. The bolts slowly retreat, but the door's full of them now.
"Bad idea!" Jetina says, staring carefully. "You alright, Moore?"
"I'm fine. I have an idea." He says with a smile as he gestures!
Greater Stone shape, idea is to close up the door as much as possible while still giving Jetina line of sight to the trap itself. Also pulling up several smaller walls of stone in in front to hopefully absorb some of the excess lightning that comes out.
I am fine just taking the two follow-up dispel checks as results if you want since I'm still intending to keep dispelling it. Up to you on that, though.
How small a hole is left there?
Let's say about a square that's about 2 feet wide and 2 feet tall. He's banking on the dispel shutting it down long enough that he can get rid of the stone again and then grab the thing!
The next dispel comes, more lightning. A single bolt manages to lance out of the viewing window, which...
> roll 1d100
<Kobot> Kotono rolled 1d100 --> [ 1d100=10 ]{10}
Goes right for Moore.
> roll 1d20+30 vs SR
<Kobot> Kotono rolled 1d20+30 vs SR --> [ 1d20=17 ]{47}
Ref. Great idea, godawful luck.
I admit, I would have to laugh if Moore died to one errant lightning bolt.
[13:26] <Nephrite> roll 1d20+60 evasion
[13:26] <Kobot> Nephrite rolled 1d20+60 evasion --> [ 1d20=8 ]{68}
Guh! Moore zips to the side, avoiding the flash of white. Ozone is thick in the air after that, tickling his nose.
"Don't worry about me, a little lightning can't kill me. Keep going!" Moore says, encouraging Jetina!
Crossing my fingers that 46 is enough!
39 first, though.
Jetina braces and casts again, this time a massive storm crackling in there, thunder pounding you as the walls of stone begin to crack, current running through them, leaving glowing ripples of melting stone within it.
"Don't give up!" Moore shouts. "I can make more barriers if that one gets destroyed!"
A cast - and this time the thunder lessens and stops, "Got it," Jetina calls, "HURRY!"
> roll 1d4
<Kobot> Kotono rolled 1d4 --> [ 1d4=1 ]{1}
Moore darts in to grab the rod!
If he needs to, he'll do another Greater Stone Shape, but if not he'll just barrel through whatever's left from the melted door.
Switching aura to dex in case he has to do something quick here!
[14:00] <Nephrite> roll 1d20+13+15+15 (+greater improv, marshal aura) dex check
[14:00] <Kobot> Nephrite rolled 1d20+13+15+15 (+greater improv, marshal aura) dex check --> [ 1d20=7 ]{50}
Guh! You're fast as a bolt, darting in and getting the rod out just in the nick of time, barely avoiding lightning. Got it!
