The depths of Ice
Started by Anastasia, August 20, 2018, 01:33:26 PM
"Here we go again," Benyen calls, the party following, sliding down the icy tunnel and into the snow - gah! The snow slashes and cuts at the party as you're already going, no chance to avoid it as a thousand tiny ice razors lash at you all.
> roll 1d20+22 touch AC
<Rei-chan> Kotono rolled : 1d20+22 touch AC --> [ 1d20=5 ]{27}
Touch ACs?
Tryll is incorporeal. Is it a force effect?
[blockquote]Rolled 1d100 : 87, total 87[/blockquote]
Okay, no luck on incorporeal dodging. Touch ACs?
Tryll missed, Calleigh hit, Dana missed, Benyen hit, Miranda hit, Debonah missed.
> roll 8d4 slashing damage, cold damage omitted as irrelevant as it won't beat cold res
<Kobot> Kotono rolled 8d4 slashing damage, cold damage omitted as irrelevant as it won't beat cold res --> [ 8d4=20 ]{20}
20 damage to all hit, DR does apply.
Guh! The snow takes a toll as you slide down, muffled curses as the party goes through. Sliding fast and faster yet, you go down the tube, deeper and deeper. Ahead is a U shaped dip that goes upward a bit, like a natural ramp - and as you're racing down, you can't see what it leads to from here, be it a blind fall or more tube.
Dana
HP: 597/597 (fast healing 2)
Aura:
Resources: Rage 1/1 Offensive Chain 3/3 Defensive Chain 3/3 Defensive Stance 9/9 Protection Devotion 1/1 Bulwark 3/3 Haste 10/10
Spells Used: Power Points 421/457
SLAs Used:
Spells Active: Attune Form (CL5), Psionic Freedom of Movement (CL31)
Notes: Triggers frost blood on a slashing or piercing melee attack.
Miranda
HP: 400/405
Aura: Courage 10ft (+4 morale vs fear)
Resources:
Spells Used:
SLAs Used:
Notes: Favored enemy applies to attack rolls. No real resource issues with anything she does, can function all day.
Benyen
HP: 502 (87 frostburn)/609 (fast healing 3)
Negative Conditions: Hypothermia (Exhausted)
Aura: Magic Circle Against Evil 10ft (Protection from Evil), Courage 10ft (+4 morale vs fear)
Bonuses: Attack+0, Damage+0 AC+0, Saves+0, Skills+0, Checks+0 Resistance to cold 30.
Resources: Smite Evil 20/21 Channel Energy 13/13 Lay On Hands 60/60 Remove Disease 1/1 (week) Incarnum Overload 1/1 Servant of the Heavens 1/1 +5 One Attack On FA 1/1 (rnd) Take 10 On One Attack (rnd) 1/1 Rage 2/2 Hell Striker Takeover 1/1 (mth) Dimension Door 3/3
Spells Used:
SLAs Used:
Spells Active: Attune Form (CL5), Resist Energy (Cold) (CL35)
Notes: Typical smite bonus damage is 27*2=54+6=60. 60+12=72*2=144 on charge.
Debonah
HP: 873/873
Aura:
Bonuses: Attack+6 (insight), Damage+6 (insight), AC+6 (insight), Saves+0, Skills+0, Checks+0
Resources: +5 One Attack On FA 1/1 (rnd) Take 10 On One Attack (rnd)
Spells Used: Power Points: 718/742
SLAs Used:
Spells Active: Attune Form (CL5), Psionic Freedom of Movement (CL35), Debonah's Mental Awakening (CL35)
Notes: Should pretty much use rapidshot full attacks or swarm of arrows in any round she makes ranged attacks.
'Applying brakes. Brace for impact.' Tryll says, manifesting a wall of ectoplasm at the bottom of the turn.
I'm going to rule conditions warrant a Concentration check.
[blockquote]Rolled 1d20+46 : 10 + 46, total 56[/blockquote]
The wall appears just in time, a serious of wet thumps sounding as the party slams into it. Fortunately it's soft enough that any damage isn't a concern, but you're now covered in slime.
Miranda grunts and extricates herself from the wall, "It's like running headlong into a gelatinous cube, only without the acid burning."
"Non-burny slime is fun!" Calleigh says, slinging some slime onto Dana.
Splat! Right off the back of Dana's shoulder, getting her to turn, smiled head to toe. "Yeah, fuckin' great," she grumbles.
Debonah emerges and says, "Lower the wall and we can go see what's ahead."
Benyen snickers at that and grins, but keeps his mouth shut.
