Rising higher
Started by Anastasia, August 23, 2018, 12:44:45 PM
Oh, why not? Perception.
It's a floor. A well cleaned stone floor, no sign of anything or scent of much of anything.
Wood whimpers nonetheless. "Miss you..." A soft voice murmurs sadly, one you swear comes from Wood.
Moore glances over at Wood, then at the floor. "Where is it coming from?"
Wood sniffs the ground again, then intently looks to the end of the hall, a door leading outside there.
"Come on." Moore says as he goes to open the door!
It opens to the edge of the courtyard, nothing too unusual there.
Wood looks up towards the light above and whimpers sadly.
"Is that where she is?" Moore asks quietly.
Another whimper. Be strong, Wood. Your master loves you.
Moore smiles and gives him a good petting. "Don't worry. I'll make sure you see each other again when it's time."
Wood pants again at that petting, as...
Okay, refresh me on your plans to help out with the Seira end of anti slavery efforts.
I believe our role is to be a safehouse and to help ferry them around as needed. I think we're also to act as a strike team against anywhere while she's Doing Her Thing.
I do also need to dedicate some time to officially sending her the information I got from Calley.
Go ahead and compose that message in that case, we'll start with that.
Okay.
Lady Seira,
Enclosed in this letter are copies of the research I've done on Calley's 'blueprints'. We had some idea that it was a ritual, but I believe it leads to the location of 21, or is in at least part of finding it. I think, somehow or another, Sylvie imparted this knowledge to him, though somehow or another he doesn't truly understand what it is.
In what I've found, there are are apparently 777 pieces to this ritual, of which so far I have located 1.
I will keep you appraised if there are any further pieces of information I happen across, but thought this information would be of some use to you and Sylica.
He'll make duplicates of all his work so far along with it and put it all together. He probably ought to just go deliver it himself so as to avoid any problems with the delivery.
Okay, I'll toss you over there then. Locking this thread.
