Dark Rumblings
Marie follows up with her stronger and more righteous smite to ensure there's no survivors!
[19:56] <@Ebiris> roll 1d20+31 righteous smite SR
[19:56] <Kobot> Ebiris rolled 1d20+31 righteous smite SR --> [ 1d20=13 ]{44}
[19:56] <@Ebiris> roll 20d6
[19:56] <Kobot> Ebiris rolled 20d6 --> [ 20d6=72 ]{72}
DC 32 will half
"Thank you, Marie," Alicia says, leaving it now and going back into that North hallway to try opening the door to the East.
Marie: 515+20/515
Sorcerer spell slots: 6/9/10/8/7/7/6/6/7/7/6/4/3
Avatarlicia: 706+60/706
Sorcerer spell slots: 6/13/12/10/9/9/11/8/7/4/7/6/6/4
Duskblade spell slots: 6/17/17/16/9/4
The survivors are obliterated to the last, Ebony adding to Marie, "You've grown so strong."
Ahead is a large room - full of massive sacs, bulging and pulsing. Thin, semi-transparent veins run between them, a dark liquid within. As you stare they begin to gather magic and...!!!
Init, go ahead and go and we'll roll it if Alicia isn't enough.
"I have, but I shouldn't let it go to my head! I didn't get here alone," Marie smiles back at Ebony as they go along.
Alicia starts off by lighting up the room, a ball of sunlight erupting in the middle of it!
Sunburst SLA
[20:18] <@Ebiris> roll 1d20+31 sunburst SR
[20:18] <Kobot> Ebiris rolled 1d20+31 sunburst SR --> [ 1d20=11 ]{42}
[20:18] <@Ebiris> roll 6d6 damage to non-undead
[20:18] <Kobot> Ebiris rolled 6d6 damage to non-undead --> [ 6d6=25 ]{25}
DC 41 ref half, blinded if save fails
> roll 1d20+12
<Kobot> Kotono rolled 1d20+12 --> [ 1d20=18 ]{30}
Sunlight bursts in - pressuring sacs, bursting some and others burn. Yet some remain as...
Init.
[20:25] <@Ebiris> roll 1d20+11 Marie init
[20:25] <Kobot> Ebiris rolled 1d20+11 Marie init --> [ 1d20=19 ]{30}
Alicia will use her remaining swifts if the sacs manage to beat Marie.
> roll 1d20+8 sacs
<Kobot> Kotono rolled 1d20+8 sacs --> [ 1d20=14 ]{22}
> roll 1d20+8 Ebony
<Kobot> Kotono rolled 1d20+8 Ebony --> [ 1d20=14 ]{22}
Init is Alicia (Maxed) > Marie (30) > Sacs = Ebony (22)
#261
"I'll finish it," Marie says, holding a hand out as a loud crackle erupts with an electric blue arc lancing out from her fingertips to explode one of the sacs before a multitude of secondary lightning bolts cascade around the room to hit the rest!
Empowered chain lighting
[20:29] <@Ebiris> roll 1d20+31 chain lightning SR
[20:29] <Kobot> Ebiris rolled 1d20+31 chain lightning SR --> [ 1d20=9 ]{40}
[20:30] <@Ebiris> roll 20d6 primary target
[20:30] <Kobot> Ebiris rolled 20d6 primary target --> [ 20d6=68 ]{68}
[20:30] <@Ebiris> roll 10d6 secondary targets
[20:30] <Kobot> Ebiris rolled 10d6 secondary targets --> [ 10d6=40 ]{40}
102 damage to primary, 60 to secondaries.
EDIT: 51 damage to secondaries, ignore the 10d6. I forgot how the spell works, it just does half the damage of the main one, not a fresh roll with half the dice.
> roll 1d20+12
<Kobot> Kotono rolled 1d20+12 --> [ 1d20=6 ]{18}
Lightning crackles and fire burns, many of the sacs ablaze or burst - but insects still scurry, veins still pump fluids deeper within it.
Was Alicia going to use her swifts? A little screwy with init but it's Supreme Init so I'll give you latitude.
"Persistent little things, aren't they?" Alicia clucks her tongue, causing a burst of kaleidoscopic colour to ripple through the room with ruinous results.
Quickened radiant assault.
[20:44] <@Ebiris> roll 1d20+31 radiant assault SR
[20:44] <Kobot> Ebiris rolled 1d20+31 radiant assault SR --> [ 1d20=12 ]{43}
[20:44] <@Ebiris> roll 15d6
[20:45] <Kobot> Ebiris rolled 15d6 --> [ 15d6=44 ]{44}
[20:45] <@Ebiris> roll 1d4 debuff duration
[20:45] <Kobot> Ebiris rolled 1d4 debuff duration --> [ 1d4=3 ]{3}
DC 30 will half, dazed if save fails, dazzled otherwise.
Marie: 515+20/515
Sorcerer spell slots: 6/13/12/10/9/9/11/8/7/3/7/6/6/4
> roll 1d20+12
<Kobot> Kotono rolled 1d20+12 --> [ 1d20=2 ]{14}
The light purifies the wicked, burning away the veins and scorching away what remains. In the aftermath is ruin, walls coated with burst sacs and the floor thick with dead insects. Victory!
Free act. The room's a mess so doing something about that would help getting a clue what's up in it.
Rather than spend time cleaning up one room when they have a whole cathedral to cleanse, Alicia turns and opens the matching door to the West, expecting more of the same.
It is a long hallway to the west, with a single door to the south about midway. Here deep frescoes are untouched, while from the ceiling the hang. The dead, hung like criminals. Tiny sacs bulge all over their bloated bodies, baby insects and vermin crawling about them. The bodies sway gently back and forth, as if caught in the afternoon breeze.
This room should solidify your SOP for dealing with things like this, be it an unlimited SLA or something else, so go ahead and elaborate that.
https://imgur.com/JHWsRXb
Alicia and Marie share a nod before magic erupts in the room, a righteous smite from the eladrin bursts with holy light, matched by the radiance of the noon sun from the avatar's sunburst!
Sunburst and Righteous Smite SLAs used.
[17:33] <@Ebiris> roll 6d6 sunburst damage
[17:33] <Kobot> Ebiris rolled 6d6 sunburst damage --> [ 6d6=18 ]{18}
[17:33] <@Ebiris> roll 20d6 righteous smite damage
[17:33] <Kobot> Ebiris rolled 20d6 righteous smite damage --> [ 20d6=58 ]{58}
DC 32 will half on the smite, DC 41 ref half on the sunburst, blinded on failure for either.
No need.
Between cleansing sunlight and holy power, the way ahead is cleared. Vermin are obliterated and all that lies ahead is sundered bodies freed of insects.
"We don't have time to give them proper rites, it will have to wait until we've stabilised the dimensional rift," Alicia says of the bodies, nonetheless consecrating this hallway as she walks along and opens the door to the South midway.
