Dark Rumblings
"Excellent work, Naeys," Alicia approves of both the intelligence gathering and the theatrics of the spell itself. "Can you ask more questions or is it one per casting?"
"Many," Naeys smiles thinly as he gazes at the corpulent daemon, "More than almost any situation would need. It is of the 12th circle, such magic has few limits."
Alicia nods. "In that case ask why they took the Warrior's Spelltome." Be good to know if it's intended to be auctioned off somewhere or hoarded.
The figure before you is dark, lost in shadows. It looms silently as you hear a whispering voice, a mental answer, 'Because its loss will weaken them. It is to be given to another. Let her lament what she will never have.'
"Looks like you'll be following a breadcrumb trail for this one," Marie comments.
"Probably," Alicia agrees. "What of the defences at Sunken Watch?"
Images - of shadows and metallic things, of golems and undead, of the 'loths infesting it. Of vermin, crawling and writhing. So many vermin, so many swarms of them. Ruin swarms, things you know from your previous battles. Of the fire and ice weaving about, immolating and freezing any who dare venture in. Of dark sorcery, infernal chanting echoing amid the corridors of the Sunken Watch.
"Swarms, we'll need to go magic heavy," Syala observes, "Smashing swarms rarely works out for anyone, you need fireballs and sunbursts to dispatch them."
"Think you can spare your avatar?" Alicia asks Syala. "Us two and Latha should be up to the job. Naeys, I believe we're done with that - could I trouble you to deliver it to Dweomerheart? Mystra herself would like to exercise her judgement."
Marie: 515+20/515
Sorcerer spell slots: 6/3/10/8/7/7/6/6/7/2/5/4/2
Avatarlicia: 582+60/582
Sorcerer spell slots: 6/13/12/10/8/9/11/7/6/0/7/6/5/2
Duskblade spell slots: 6/17/17/16/9/4
"It will be done," Naeys agrees, "Though with your permission, I would like to interrogate it on the depths of its arcane skill."
"By all means," Alicia agrees graciously, stepping back towards Marie and Ebony so she can cast an eye over their loot. Which prompts Marie to cough and telekinetically strip anything magical off the arcanaloth and add it to Ebony's pile.
Spellcrafting to ID stuff. Marie can actually roll for it since she's better. Take 10 for 60 on all items.
Alicia burns two of the scrolls with a flash of spellfire.
"I can give these boots to Antenora, I think she'll like them," Marie pipes up.
Alicia nods to that. "I'll secure away the tainted items. Ebony, why don't you take the remaining scrolls and magical ring? If not for yourself then they may be useful to Aurora."
"It will be done," Ebony concurs, taking them and...
Got an immediate next move here?
Marie and Ebony will go back to their previous assignments.
Alicia's avatar, Syala's avatar, and Latha will go attack Sunken Watch.
Alicia's still buffed up from earlier.
She will suggest Latha and Syala each throw up a mass energy immunity to cover us against fire and cold as well as death ward themselves.
Marie can also give them a +22 epic mage armour each before she leaves if they like.
