Dark Rumblings
Once again, shadows fall to her blade in a clean sweep that rends them into nothing before they can threaten with phantasmal claws!
[17:05] <@Ebiris> roll 1d20+42 whirlwind attack, haste, 3rd level arcane strike, channelled maximised/vivacious shocking grasp, -20 power attack
[17:05] <Rei-chan> Ebiris rolled : 1d20+42 whirlwind attack, haste, 3rd level arcane strike, channelled maximised/vivacious shocking grasp, -20 power attack --> [ 1d20=17 ]{59}
[17:05] <@Ebiris> roll 1d20+42 whirlwind attack, haste, 3rd level arcane strike, channelled maximised/vivacious shocking grasp, -20 power attack crit threat
[17:05] <Rei-chan> Ebiris rolled : 1d20+42 whirlwind attack, haste, 3rd level arcane strike, channelled maximised/vivacious shocking grasp, -20 power attack crit threat --> [ 1d20=1 ]{43}
[17:06] <@Ebiris> roll 2d6+67+6+2d6+60+3d4+1d8 if no crit
[17:06] <Rei-chan> Ebiris rolled : 2d6+67+6+2d6+60+3d4+1d8 if no crit --> [ 2d6=4 2d6=6 3d4=5 1d8=3 ]{151}
[17:06] <@Ebiris> roll 4d6+134+12+2d6+120+3d4+1d8 if crit
[17:06] <Rei-chan> Ebiris rolled : 4d6+134+12+2d6+120+3d4+1d8 if crit --> [ 4d6=16 2d6=8 3d4=5 1d8=6 ]{301}
Avatarlicia: 644+60/644
Active spells: Extended nondetection (CL 32), many moments of prescience (CL 31), epic mage armour (CL 31), extended greater anticipate teleportation (CL 32), extended repelling shield (CL 32), sensual blessing (CL 31), greater heroism (CL 31), recitation (CL 31), dance of the unicorn (CL 31), keen edge (CL 31), foresight (CL 31), ray deflection (CL 32), magic vestment (CL 31), greater magic weapon (CL 31), mass energy immunity (CL 32, cold), mass energy immunity (CL 31, fire), extended latha's sunmantle (CL 32)
Defences: AC 81 (touch 32), CMD 86, spell resistance 46, energy immunity (fire, cold, negative energy), status immunity (polymorph, petrification, disease, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 47), ray deflection, damage reduction 20/-, 20 damage to anything striking in melee
Stat buffs/penalties: +13 armour, +9 shield, +4 morale attack/saves/skills, +3 luck attack/saves, +25 competence perception, doubled crit range, +2 insight AC/reflec, +1 enhancement attack/damage, +8 str, +4 con, -2 dex, +2 natural armour, -1 size.
Sorcerer spell slots: 6/13/12/10/8/8/11/4/5/0/6/4/5/2
Duskblade spell slots: 6/17/17/10/1/4
Quick cast: 1 left.
Shadows fall, slaughtered to the last. A single sweep is sufficient, massacring them. The explosions of unlife barely phase you, no damage whatsoever.
"Syala, are you done?" Latha glances back, as Syala kneels with the defeated shadow. She's murmuring something to him but you can't hear it. The shadow quivers like a bowl of pudding, shaking constantly despite Syala's warm, innocent and serene smile.
Alicia just keeps an eye out while Syala does... whatever it is that Syala does so well. If she needs to take some time on it she considers a being like Lelolim responsible for so much suffering to be worth the effort.
> roll 1d20+67 (+5 circumstane, +15 divine insight invoked via alter reality)
<Rei-chan> Sunshine_Ko rolled : 1d20+67 (+5 circumstane, +15 divine insight invoked via alter reality) --> [ 1d20=10 ]{77}
Syala rises, "I'm done," she says, "What do you want to do with him?"
"Destroy him?" Alicia says the obvious, gesturing for Latha to do the honours as their beacon of sunlight. "What was that about, then?"
> roll 1d20
<Rei-chan> Sunshine_Ko rolled : 1d20 --> [ 1d20=20 ]{20}
Latha's mace slams down, the helpless and held shadow unable to resist. Sunlight engulfs it, a wailing cry as all of it dissolves, leaving behind nothing at all.
"Well struck," she compliments Latha, leading the way back to the junction and turning North from there.
Your return is unopposed, the tide seeming to have passed. You walk to the north, soon coming on an arch with a single heavy stone door blocking the way forward. A soft blue-green light radiates from it, giving it an unearthly glow.
Arcane sight and spellcraft of 56 taking 10.
It's rather nastily trapped, arcane magic as well as a lock deep within, no way to actually get to it as its covered in solid stone. Trying to ghost through won't end well, nor will forcing it - a massive force reprisal.
Alicia holds out her hand and a whip of silver fire arcs out, carving the door apart into rubble before her.
[18:30] <@Ebiris> roll 40d10
[18:30] <Rei-chan> Ebiris rolled : 40d10 --> [ 40d10=234 ]{234}
Disintegrates objects, but damage for anyone standing on the other side. DC 38 ref half.
The door collapses utterly, done in by Silver Fire and magic collapsing into flares of light. Amid the loud din of and collapse of the door is a hallway leading onward and hooking westward, out of sight.
A strange, deep and resonant groan follows, as if a sleeping man was awoken in pain.
Alicia doesn't delay, striding through the ruined doorway and following the passage where it turns to the West.
"Beware," Latha murmurs, as the stones ice over before you, frost rapidly covering everything. The temperature drops to sub zero in a breath, yet all of you endure. A wind begins to blow, starting at a breeze before quickly becoming a powerful gale, trying to check you, trying to force you back.
Alicia doesn't slow down, her large form easily able to stand up to a gale.
Pretty sure I can't fail the fort save, and it needs to be at windstorm tier to even check a large creature.
