Elemental Movements
Started by Anastasia, September 17, 2018, 10:51:14 AM
Moore appears with the others and takes a quick glance around.
"All right, let's go. We're going to encounter resistance, but we'd encounter that no matter what we do." Moore says as he takes to the air.
Aim is to just fly high over the gates -- expecting people to stop them and am not too concerned about it.
Oh, Kaja needs to fly, so... Moore will give him Air Walk, which lets him walk through the air as if he could fly, I think.
Sure thing. Let's hit init here and begin with that.
Absolutely.
Everyone gets +15 to Init.
[23:00] <Nephrite> roll 1d20+38 Moore
[23:00] <Penuche> Nephrite invokes Penuche's magic: < 54 > [d20=16]
[23:01] <Nephrite> roll 1d20+20 Jetina
[23:01] <Penuche> Nephrite invokes Penuche's magic: < 26 > [d20=6]
[23:01] <Nephrite> roll 1d20+21 Xandra
[23:01] <Penuche> Nephrite invokes Penuche's magic: < 27 > [d20=6]
> roll 1d20+30 Cresiel
<Rei-chan> Kotono rolled : 1d20+30 Cresiel --> [ 1d20=13 ]{43}
> roll 1d20+30 Kaja
<Rei-chan> Kotono rolled : 1d20+30 Kaja --> [ 1d20=3 ]{33}
> roll 1d20+8 guards
<Rei-chan> Kotono rolled : 1d20+8 guards --> [ 1d20=19 ]{27}
Init is Moore (54) > Cresiel (43) > Kaja (33) > Xandra = Guards (27) > Jetina (26)
Open.
"We're going up and over. If they want to fight us, they'll do it up there where we have a better vantage point. I expect we'll get some form of heavy resistance eventually." Moore explains to the others. "Once we're inside, we'll activate the beacon so they can't easily get reinforcements in or out, but I imagine the other forces will keep anyone significant from us."
He gestures to allow Kaja to fly as well as he takes off!
Air Walk on Kaja per my previous mention and he'll fly 60 ft up and forward.
Cresiel follows right behind you, shield at the ready as he takes your side. Kaja's right behind them, jogging along lightly.
Xandra and guards.
"Alarm! Alarm yellow, alarm yellow," The guards shout, scimitars readied, shields held as well.
Go Xandra and then Jetina.
Jetina and Xandra fly up as well!
Jetina will double move since her speed is only 30.
Everyone is in the air now. Ahead is the college proper, if you fly 40ft more ahead and over the walls.
What exceptional types of vision do you have, Moore?
You see a hazy ripple above the walls, rising straight up, higher and higher. A sort of defense you know from Aurora - walls of force. High enough to go beyond the 120ft limit of true sight. It begins just as you advance on, shimmering into place. From what you see it isn't arching like a tome - just a tall wall going up and up and up.
I believe you have an item and aren't using greater true seeing, which removes that range limit. If I'm wrong, correct me. Otherwise, your go.
You are correct.
Moore gestures to try and remove at least part of the wall so they can proceed!
He's using Magic Disjunction -- do you need a CL or dispel check or does it just... get rid of it? I'm not entirely sure from the text on Wall of Force.
Assuming it just works, he's just aiming for an area of the wall near to them for them to use.
[blockquote]Rolled 1d20+20 : 3 + 20, total 23[/blockquote]
The cap on it is +30, not +20.
Oh, whoops. I doubt a 33 does it anyway, but that's what it'd be.
