Family Reunion
Started by Anastasia, September 17, 2018, 10:55:20 AM
Alyssa begins chanting, focusing on her blade, Shifting Steel!
Alyssa's Aerial Assembly, CL 32, Duration: 32 rounds.
Generates 1 copy of target weapon per 4 CL, copies gain Dancing Blade.
8 Copies total.
Blades appear as commanded, conjured and created around you. An absolute assembly of them, all around you and ready to strike.
Anything else this round?
They should attack this round, yeah?
Well, you cast it as a standard action or did you quicken it somehow or another?
It's a regular casting, but Dancing makes them automatic. Well, directing them to attack is a free action, and they attack once per round.
Go for it, make your attacks then.
> roll 8#1d20+42+1 ATK
<Kobot> Iddy rolled 8#1d20+42+1 ATK --> [ 1d20=17 ]{60}, [ 1d20=1 ]{44}, [ 1d20=4 ]{47}, [ 1d20=17 ]{60}, [ 1d20=5 ]{48}, [ 1d20=1 ]{44}, [ 1d20=7 ]{50}, [ 1d20=8 ]{51}
Forgot to add Celestial Valor, so that bumps by +4. Bane: Undead also applies= 66, 50, 53, 66, 55, 50, 56, 57.
> roll 8#1d6+3+2d6+2d6
<Kobot> Iddy rolled 8#1d6+3+2d6+2d6 -->
[ 1d6=5 2d6=10 2d6=9 ]{27},
[ 1d6=5 2d6=2 2d6=10 ]{20},
[ 1d6=1 2d6=11 2d6=6 ]{21},
[ 1d6=3 2d6=6 2d6=5 ]{17},
[ 1d6=6 2d6=11 2d6=7 ]{27},
[ 1d6=3 2d6=3 2d6=8 ]{17},
[ 1d6=3 2d6=7 2d6=9 ]{22},
[ 1d6=5 2d6=7 2d6=7 ]{22}
Total: 173
Miss chance on each of those since incorporeal, so gimme a d100 for each one unless you have ghost touch or something similar.
Shifting Steel is ghost touch, so all the copies are too.
Your blows land - some miss and some hit, but you land slices that make it howl in further pain. As it recoils, cut up even more by your bevy of swords...
Anything else this round or are you good, Alyssa?
"Healing!" Emily cries a single word, your wounds instantly mending.
Mass Heal, quickened.
A moment later sunlight is in her hand, a spear of it gathered, "Go!" she adds, hurling it right at the shadow.
> roll 1d20 1 check mostly since rnaged touch
<Kobot> Kotono rolled 1d20 1 check mostly since rnaged touch --> [ 1d20=3 ]{3}
Actually need to do the math. Okay, 41 total which actually misses. Wow.
Yet the spear of sunshine is deflected away, bursting as it reaches the horizon, momentarily banishing the night with day.
Jarem's next, chance to react while I go around and get posts done.
Jarem
HP: 473/473
Aura:
Bonuses: Attack+4 (+4 sacred), Damage+4 (+4 sacred) AC+4 (+4 sacred), Saves+4 (+4 sacred), Skills+0, Checks+0 weapon counts as holy
Resources: Turn Deific Foes 8/8 Smite 2/6 Knight's Challenge 20/20 Law Devotion 1/1
Spells Used:
SLAs Used:
Spells Active: Celestial Valor (CL27)
Notes: Tripping: +12 CMB/CMD on it, free attack on trip, make a DC 32 Fort or be unable to rise for one round.
Emily
HP: 408/408
Aura: Courage 10ft (+4 morale vs fear)
Resources: Dragonfire Wrath 10/10 Channel Energy 13/13 Lay On Hands 30/30 Blinding Speed 25/25
Spells Used: FS: 1 6th, 1 9th, 1 10th Sorc: 1 11th
SLAs Used:
Spells Active:
Notes: Spell shield to reduce damage.
Alyssa gasps as the wonderful feeling of healing, but doesn't let it distract her from the threat.
Jarem chases, determined as his blade gleams with divine power, shield first as...
> roll 1d20+59 (+4 sacred, +8 morale, +5 smite)
<Kobot> Kotono rolled 1d20+59 (+4 sacred, +8 morale, +5 smite) --> [ 1d20=5 ]{64}
> roll 1d20+49 (+4 sacred, +8 morale)
<Kobot> Kotono rolled 1d20+49 (+4 sacred, +8 morale) --> [ 1d20=1 ]{50}
> roll 1d20+44 (+4 sacred, +8 morale)
<Kobot> Kotono rolled 1d20+44 (+4 sacred, +8 morale) --> [ 1d20=18 ]{62}
> roll 1d20+39 (+4 sacred, +8 morale)
<Kobot> Kotono rolled 1d20+39 (+4 sacred, +8 morale) --> [ 1d20=6 ]{45}
> roll 1d20+54 (+4 sacred, +8 morale)
<Kobot> Kotono rolled 1d20+54 (+4 sacred, +8 morale) --> [ 1d20=7 ]{61}
<Kobot> Kotono rolled 1d20+49 (+4 sacred, +8 morale) --> [ 1d20=9 ]{58}
> roll 1d100 vs 1
<Kobot> Kotono rolled 1d100 vs 1 --> [ 1d100=51 ]{51}
> roll 1d100 vs 3
<Kobot> Kotono rolled 1d100 vs 3 --> [ 1d100=65 ]{65}
> roll 1d100 vs 5
<Kobot> Kotono rolled 1d100 vs 5 --> [ 1d100=88 ]{88}
> roll 1d8+68+2d6
<Kobot> Kotono rolled 1d8+68+2d6 --> [ 1d8=8 2d6=7 ]{83}
> roll 1d8+37+2d6
<Kobot> Kotono rolled 1d8+37+2d6 --> [ 1d8=5 2d6=9 ]{51}
> roll 2d6+34+2d6
<Kobot> Kotono rolled 2d6+34+2d6 --> [ 2d6=10 2d6=5 ]{49}
With holy power around his blade, Jarem strikes again. Lightning strikes from the blue, red lightning that rips the shadow apart. "Victory!" Jarem cries as the shadow breaks apart, dissolving in the pale light of the full moon. You've won!
Free act.
Jarem
HP: 473/473
Aura:
Resources: Turn Deific Foes 8/8 Smite 1/6 Knight's Challenge 20/20 Law Devotion 1/1
Spells Used:
SLAs Used:
Emily
HP: 408/408
SLAs Used:
Spells Active:
Alyssa shakes off the ebbing shock of the attack and the curse.
"Jarem, find out if this was part of a larger attack. Emily, go check on the council. I want a report of damages and casualties. We need to find out how Shar got this thing in here and plug that hole."
Alyssa looks around, checking over everything before grabbing Emily by the arm before she leaves. "I'm going to check on my family."
With that last bit, Alyssa uses her Dimension Door ability to start heading for her family's new cottage.
