Moving spheres
Started by Anastasia, October 24, 2018, 09:02:06 PM
"I could tell that was a solid casting," Alicia says. "So this sort of magic can only be defeated with something specialised? I'll try Unbinding next then..." she proceeds to cast that spell, shattering all sorts of containing and binding magic in a large area all around her.
180ft radius burst so it gets a lot.
Avatarlicia: 582+20/582
Active spells: Extended nondetection (CL 32), many moments of prescience (CL 31), extended greater anticipate teleportation (CL 32), extended repelling shield (CL 32), recitation (CL 31), sensual blessing (CL 31)
Defences: AC 65 (touch 32), CMD 80, spell resistance 46, status immunity (polymorph, petrification, disease, energy drain, ability damage, ability drain, mind-affecting, and fear), nondetection (DC 47)
Stat buffs/penalties: +9 shield AC, +3 luck attack/saves, +4 morale attack/saves/skills, +25 competence perception
Perceptions: Darkvision 60, scent, low-light vision, blindsight 60, tremorsense 60, perception +73
Sorcerer spell slots: 6/13/12/11/9/8/10/8/8/7/7/6/7/4
Duskblade spell slots: 6/17/17/16/9/6
Marie: 589+20/589
Active spells: Extended superior resistance (CL 31), epic mage armour (CL 31), extended mind blank (CL 31), greater arcane sight (CL 31), bibliotheca arcana (CL 31), extended nondetection (CL 31), extended repelling shield (CL 31), recitation (CL 31), sensual blessing (CL 31)
Defences: AC 93 (touch 35), CMD 71, spell resistance 45, energy immunity (electricity, negative energy), energy resistance 10 (acid, cold), (petrification, polymorph, form-altering, energy drain, ability drain, ability damage, mind-affecting), protective aura, nondetection (DC 46), ray deflection
Stat buffs/penalties: +15 insight knowledge, +11 shield AC, +3 luck attack/saves, +4 morale attack/saves/skills, +25 competence perception
Perceptions: Darkvision 60, blessed sight 120, see invisibility, greater arcane sight, scent, low-light vision, blindsight 60, tremorsense 60, perception +75
Sorcerer spell slots: 6/10/10/8/9/9/8/8/8/8/8/6/5
Limited SLAs available: Meteor swarm, time stop
There is a loud SNAP-CRACK of power, time bursting out wildly all around you. You feel it but nothing happens as Chrona 42 mentions, "The temporal backlash would be hazardous, if we were all not protected from it."
The loop before you is over, gone as if it never was.
"Something to bear in mind," Alicia agrees, having a look in the no longer looped alleyway to see if it hides anything.
[18:04] <@Ebiris> roll 1d20+73 perception
[18:04] <Penuche> Ebiris invokes Penuche's magic: < 83 > [d20=10]
Lying within the no longer looped area, you can see something metal mostly covered by the sands.
"There," Syala points at it as you see it, a gesture from her removing the sand cover. Here sits a metal orb, smooth and polished, the size of a fist.
"Marie, can you tell us what that is?" Alicia asks so as to give her proxy something to do.
Smiling, Marie walks forward and leans over to examine the metal orb...
Taking 10 for 60 on spellcraft.
The tulani bends over to dig the orb out and hold it up. "This is nice, you can use it to convert weaker spells into a stronger one. It just adds circles together so it's got an efficient rate of exchange, but it only works once per day."
Alicia glances at Chrona, "Unless you have Chronomancy to cheat that limit," she says, opening her portable hole for Marie to put the orb inside. "I saw stairs into a basement of one of the houses, lets try those next?" she then adds to her companions, going to explore that way.
"Exactly," Chrona 42 smiles, "The limits of magic and recovery mean adventurers, especially spellcasters, only have so much power a day. But when time is relative, a day can be relative."
"Only really want to use it for items though, since if you accelerate time to recover your spells you're still stuck waiting that long yourself even if it's an instant for everyone else," Alicia says as they go down.
Modes of perception, Alicia?
Alicia: Perceptions: Darkvision 60, scent, low-light vision, blindsight 60, tremorsense 60, perception +73
Marie: Perceptions: Darkvision 60, blessed sight 120, see invisibility, greater arcane sight, scent, low-light vision, blindsight 60, tremorsense 60, perception +75
Alicia can feel it - the ground vibrating.
Marie can see it, an invisible thing striding forward. A scorpion, growing larger by the moment, currently about Hanna sized and getting bigger by the moment. It's 20ft away and closing in as you come down the stairs.
Where? Is it coming up the stairs at us or is it out on the surface?
It's coming up the stairs at the two of you.
"Giant scorpion coming!" Marie points it out, Alicia readying her sword as her highly attuned senses pick it out as welll!
Alicia wins init
[19:35] <@Ebiris> roll 1d20+16 Marie init, nerveskitter
[19:35] <Penuche> Ebiris invokes Penuche's magic: < 34 > [d20=18]
Marie: 589+20/589
Sorcerer spell slots: 6/9/10/8/9/9/8/8/8/8/8/6/5
