The sylvan library
Started by Anastasia, October 30, 2018, 01:25:21 PM
On you fly. The fog is thicker, but you can see some gold and red trees, leaves surely ready to fall. Some sort of clearing, the mists thick here. "It's safe to come down, there's books," Jarem calls back up.
Then a split second later...
> roll 1d20+48 Ianvasah Perception
<Penuche> Kotono invokes Penuche's magic: < 62 > [d20=14]
"The trees are alive, male! On guard!" Ianvasah shouts, as...
Init. You can't tell what's going on with this thick fog that's inhibiting things, but a combat situation is developing.
> roll 1d20+7+9 Init
<Penuche> Iddy invokes Penuche's magic: < 30 > [d20=14]
> roll 1d20+5 Jarem
<Penuche> Kotono invokes Penuche's magic: < 10 > [d20=5]
> roll 1d20+9 Emily
<Penuche> Kotono invokes Penuche's magic: < 16 > [d20=7]
> roll 1d20+12 Ianvasah
<Penuche> Kotono invokes Penuche's magic: < 16 > [d20=4]
> roll 1d20 ??? 1
> roll 1d20 ??? 2
<Penuche> Kotono invokes Penuche's magic: < 11 > [d20=11]
<Penuche> Kotono invokes Penuche's magic: < 1 > [d20=1]
> roll 1d20 ??? 3
<Penuche> Kotono invokes Penuche's magic: < 17 > [d20=17]
Init is Alyssa (30) > ???3 (17) > Emily = Ianvasah (16) > ???1 (11) > Jarem (10) > ???2 (1)
Open.
Alyssa flies forward and down, looking for the threat!
It's a grove with several bookshelves built in between the trees, as well as a few in the trees. You barely have a chance to see that - 30ft ahead two trees are ambling forward, while 20ft to the left a third is.
"C'mon, bros," The tree on the left calls, "Let's bash them around!" No faces on these trees, how it spoke isn't immediately obvious.
Alyssa responds in Sylvan, "Professor Roundtree sent us to find Professor Tinsel! We're not trespassing or stealing!"
"Hah!" The tree calls back, "We know! We just want a good fight!"
"Okay!"
Alyssa tries to launch one of them into the air with her telekinesis!
Which function of TK, Alyssa?
Fling Skyward. First time use of it ever, so let's test it out.
> roll 1d20+13
<Penuche> Kotono invokes Penuche's magic: < 20 > [d20=7]
DC?
DC 22. Also, I forgot I had it prepped with Chain, does that mean I can toss both of them?
Are you sure that DC's right? It seems low for your spells.
It's 10+level+Stat, right?
10+7+9=26 (I think I forgot to factor in magic item int boost).
10 + Spell level + Int mod, yes.
And sure you can arc it at the second one as well.
> roll 1d20+12
<Penuche> Kotono invokes Penuche's magic: < 25 > [d20=13]
The two cry out as they're flung into the air, hurtling up and into the fog, high enough not to be seen nor immediately fall back down.
"Bros!" The third treant cries, before scowling, "Youuuuu!" A pine cone falls from its branches, hovering before hurtling right at you and...
> roll 1d20+28
<Penuche> Kotono invokes Penuche's magic: < 37 > [d20=9]
Touch AC?
