Moving on
Started by Anastasia, December 03, 2018, 12:41:47 PM
In it:
[blockquote]Rolled 1d20+16 : 4 + 16, total 20[/blockquote]
> roll 1d20+12 Ianvasah
<Penuche> Kotono invokes Penuche's magic: < 24 > [d20=12]
> roll 1d20+10 Lightning Sea Horror 1
<Penuche> Kotono invokes Penuche's magic: < 15 > [d20=5]
> roll 1d20+10 Lightning Sea Horror 2
<Penuche> Kotono invokes Penuche's magic: < 28 > [d20=18]
Init is LSH 2 (28) > Ianvasah (24) > Alyssa (20) > LSH 1 (15)
LSH 2 holds. Ianvasah will hold pending your approach. They are currently 200ft away and 90ft down from you. Go.
Alyssa casts a spell!
Haste, CL 32, 32 rounds.
Ianvasah and I are the only ones close enough.
She then heads in!
How far are you moving?
Jarem
HP: 473/473
Aura:
Bonuses: Attack+9 (+5 competence, +4 sacred), Damage+9 (+5 competence, +4 sacred) AC+9 (+5 competence, +4 sacred), Saves+4 (+4 sacred), Skills+0, Checks+0
Resources: Turn Deific Foes 8/8 Smite 4/6 Knight's Challenge 20/20 Law Devotion 1/1
Spells Used: Queen's Movement, Freedom of Movement, Red Knight's Skill.
SLAs Used:
Spells Active: Freedom of Movement (CL32), Red Knight's Skill (CL32), Celestial Valor (CL28)
Notes: Tripping: +12 CMB/CMD on it, free attack on trip, make a DC 32 Fort or be unable to rise for one round.
Emily
HP: 332/408
Aura: Courage 10ft (+4 morale vs fear)
Bonuses: Attack+4 (+4 sacred), Damage+4 (+4 sacred), AC+4 (+4 sacred), Saves+4 (+4 sacred), Skills+0, Checks+0
Resources: Dragonfire Wrath 10/10 Channel Energy 13/13 Lay On Hands 30/30 Blinding Speed 25/25
Spells Used: 1 6th level FS, 4 9th level FS, 1 5th level sorc, 6 7th level sorc, 2 9th level sorc, 1 10th level sorc, 2 13th level sorc
SLAs Used:
Spells Active: Celestial Valor (CL28)
Notes: Spell shield to reduce damage.
Ianvasah
HP: 346/423 (fast healing 3)
Aura:
Bonuses: Attack+5 (+4 sacred, +1 haste), Damage+4 (+4 sacred), AC+5 (+4 sacred, +1 haste), Saves+4 (+5 Ref)(+4 sacred), Skills+0, Checks+0
Resources: Protection Domain 1/1
Spells Used: Healx2.
SLAs Used:
Spells Active: Celestial Valor (CL28), Haste (CL32)
Notes: Has notes for shapeshift on her sheet.
As far as I can. Speed is 80ft now.
Alyssa flies 80ft ahead, now 120ft away and 90ft above the horrors. Ianvasah keeps pace with you as...
Go. The horrors don't seem to be reacting to you two yet.
Can I Dimension Door to them?
There's really nothing solid to support you, since they're in the ocean and the only thing between you and them is open air.
Alyssa continues her approach!
"As fast as you can manage!"
Double movement.
You have 180ft of movement to play with. They are 120ft away and 90 below you. How are you using it to get closer, precisely? Let me know your positioning.
I wanna stay above them, but get as close as I can. If that puts me inside 30ft, then the copies can attack.
So roughly 30ft above them, which just happens to be at the exact limit of your movement?
You descend down, close to the corona of lightning and...
Go ahead and make your attacks if you're going to.
> roll 8#1d20+41+1+4
<Penuche> IronDragoon invokes Penuche's magic: < 56, 57, 52, 56, 52, 50, 55, 62 >
