Moving on
Started by Anastasia, December 03, 2018, 12:41:47 PM
Complete Adventurer I think?
It's cloak of the sea. Gimme a d100?
[blockquote]Rolled 1d100 : 17, total 17[/blockquote]
Okay, you can get all of that. Anything else, mostly setting up for tonight.
Uhh.. telepathy maybe? Nothing off the top of my head.
Thus everyone gets together, spells cast as desired and...
Go ahead and set up, you're prepared as you wished to be.
"Alright. We all ready? Jarem, you're in command, did you want anything else before we head off?"
Alyssa puts the shrunk boulders in her pouch and checks over her equipment.
"Yeah," Jarem says, "In case we can't communicate, this means retreat by any means." Jarem slashes his hand against his throat. "We're going into terrain where the enemy has the advantage. Underwater I may not be able or in a position to call out a command, so if I do that, get out of there. Teleport if possible and it's safe to do so. Preferably together but use your judgment of a situation is that bad that going it alone is the only reasonable option for you."
Alyssa nods.
"Ianvasah, Emily? Anything from either of you? If not, let's get going."
Ianvasah's reply is to shift into water elemental form.
Emily bows her head, "No, I: think I'm okay. We're hunting Sharrans," she looks up with a smile, "Let's go out and smite them all."
Alyssa raises an eyebrow at the assumption of Sharrans, but decides to let it lay for now; it might provide motivation at the moment and she doesn't need a teammate mulling over allegiances, but the assumption will have to be addressed later.
"Okay, let's get going then."
With that, Alyssa takes to the air and heads for the water, entering as it gets deep enough!
Do y'all have a particular place in mind for that? Jarem does, but he's willing to listen to suggestions here if you have any.
Not personally. I put him in charge for a reason, so let him do is thing.
FAir enough.
Roughly between the two points of coastal invasion Jarem leads you into the cold waters. Immediately you find the waters are dark with night's gloom, though at least warm enough not to bring a chill to you. With magic flowing through him, Jarem is able to clearly be heard, "We're going to need a light source and it's going to make us stand out. Can any of you do anything about that?"
"Give me a moment.."
Alyssa calls on the Spellpool to provide her what she needs!
Ghost Lantern, CL 32, 320 minute duration.
Bright Illumination in 20-ft, shadowy illumination in another 20 ft. Light is only visible to self and 1 creature per 3 caster levels.
Targets: Party.
