Moving on
Started by Anastasia, December 03, 2018, 12:41:47 PM
Generalized Nature, I suppose, for how aquatic creatures perceive things and utilize stealth. Though Planar and Arcana might let me identify specific perception abilities it might have. Once I get close enough to see it, that is.
Gimme an K:N check then.
> roll 1d20+44+15 K:N
<Penuche> Iddy invokes Penuche's magic: < 74 > [d20=15]
Lemme know when I'm close enough to start identifying it, as I have a skill trick that helps.
Okay, and give me a Stealth check. That should've been in the previous post but dur, I am sleepy DM.
> roll 1d20+68+22 Stealth/Cunning Knowledge
<Penuche> Iddy invokes Penuche's magic: < 100 > [d20=10]
You swim ahead as carefully as you can, freedom of movement making it far easier. The cloak of magic around you aids you as you come forward - and about 50ft away you see another flash. A glimpse, another horror seen, bubbles from below rising up around it.
Alyssa tries to angle to keep out of it's way, hoping to put the first one between it and her, and hurries to get within Telekinesis range of the first undetected.
What's TK range for you?
30 ft. Need to find a way to extend that.
With that momentary flash of light, you angle, dim illumination showing the first horror, swimming forward at a slower pace. If it notices you, it shows no sign of it.
Bubbles rise up around you in the meantime from below.
Alyssa sends back to the others, 'There's something below, giving off bubbles. Keep an eye out, I'll have to move faster after I try this.'
Jarem sends back, 'Get out of there, NOW!'
Can I use Dimension Door in the water? And if I time stop, will I be able to move through the water?
You can use it, but your destination has to be able to support you. Solid ground, in other words.
You'd be able to move through the water in time stop.
Alyssa takes a moment to cast time stop!
Time Stop, CL 32
1d4+1 rounds of extra actions.
[blockquote]Rolled 1d4+1 : 4 + 1, total 5[/blockquote]
