Moving on
Started by Anastasia, December 03, 2018, 12:41:47 PM
5 rounds, go for it.
1st round:
Move action: Go towards the nearest monster, with-in telekinesis range, and inspect it for anatomy weaknesses, such as gills (assuming skill check call here so will pause rest of actions).
Didn't you already  make a check to identify them back when you first saw them? Go check for that and paste it.
I didn't get much info out of it, and it was done at a distance. Was hoping to get more.
Quote from: Iron Dragoon on December 12, 2018, 05:05:25 PM
> roll 1d20+44+5 K:A/Tale Keeper
<Penuche> Iddy invokes Penuche's magic: < 61 > [d20=12]
Quote from: Anastasia on December 12, 2018, 10:08:51 PM
They look like a cross between something like a leviathan and a dragon. You aren't sure what they are, but they're moving fast.
The creature's body is strong and powerful - no obvious weaknesses that you see. The horn is a natural target, however.
No mouths or gills or anything?
It has a maw and gills, yes.
If any of this doesn't work with distances or whatever, let me know and I'll modify as need be. Just want to get as much done as I can.
1st round:
Standard action: Move and lodge a shrunken boulder into the gills of the creature.
2nd round:
Move/standard action: Move in close enough to the second creature to do the same with another shrunken boulder.
3rd round:
Move action: Move down towards the bubbles to investigate.
Standard action: Cast Arial Assembly.
4th round:
Move action: Continue down towards bubbles to investigate.
Standard action: Cast-
Dolorous Blow (Reach, Chain, Echoing), CL 32, 32 Rounds.
Threat Range doubled, critical threats automatically confirm.
5th round:
Move Action: Continue down towards bubbles to investigate/skill check to identify whatever it is if I'm close enough to see it.
Standard Action: Cast -
Greater Teleport, CL 32
Return to the group.
The two boulder placements go without incident.
You descend down and down and down. Deeper in as you weave magic, moving like a blur. You reach the bottom - and see a vast, hole-riddled ground from which bubbles come. Ground that is not muddy and sea weed laden, but rough and scaly. It stretches for farther in all directions than your light illuminates.
As she teleports back to the others, she relays, 'Whatever's causing those bubbles might be a larger one of these monsters. The sea floor is muddy, hole ridden, and overgrown with sea plants... But I saw scales as well.'
Okay, clarity time since this is important:
It is explicitly not muddy and sea weed laden, but rough and scaly.
Ohh, I read that as 'the ground that isn't muddy and sea weed laden, is rough and scaly.' Gotcha, I'll fix.
As she teleports back to the others, she relays, 'Whatever's causing those bubbles is likely a much more massive one of these monsters. I went down to investigate the bubbles and all I saw was scales as far as the light could go.'
'Then we found the source, maybe?' Emily speaks up, hopefully.
'I'm surprised they aren't attacking,' Jarem sends back, 'Unless they're not as perceptive down here as I'd think.'
'Really?' Emily banters back, 'Maybe they're just not that perceptive?'
'It could be any number of things. They could be top predators here with no competition, so they never learned caution. They could feel ultimately safe this close to whatever the larger one down there is. Of note, if this does turn into a fight, I've placed a couple shrunken boulders in their gills. They should be wedged in securely, so if you hit them with a dispel or disjunction, they'll return to their original sizes and cause some serious problems for them. If we want to make use of them before they dislodge, we need to decide quickly. Jarem, you're in command.'
'Then we do it like this,' Jarem says, 'We send something down at the big one like the fist of the Red Knight smashing heretics. We fly up the moment we loose and get the hell out of the water. Ideally they chase and charge, they're likely predisposed to it if they're that good at headlong charges. Once they surface and we're safely in the air, we throw everything we can before the big one can mount a defense or retreat, kill it. We aren't going to win by staying in the water if it's as strong as it is big, so we lure it out and crush it.'
