Forward
Started by Anastasia, December 27, 2018, 08:15:18 AM
The Heart Finder Ruby is pulling you to the southeast, roughly.
'Onward!' Tryll says, heading Southeast with tentacles trailing.
"Light would help," Benyen calls, as a moment later light fills the cavern, Debonah glowing bright.
"Show off," Dana grins at that, following along.
Marching order? May matter here.
Dana & Benyen up front. Debonah in the middle. Miranda & Calleigh in the rear. Tryll in the middle.
> roll 1d100
<Penuche> Kotono invokes Penuche's magic: < 11 > [d100=11]
You walk a short time, through tight passages and winding paths. You come to a closed in, tight cavern. This cavern is thick with mushrooms - dull gray mushrooms, growing a foot tall from all the stone here.
"Gross! Anyone know what those are?"
K:P checks here, all.
Tryll[blockquote]Rolled 1d20+52 : 2 + 52, total 54[/blockquote]Calleigh[blockquote]Rolled 1d20+40 : 12 + 40, total 52[/blockquote]
> roll 1d20+37 Miranda
<Penuche> Kotono invokes Penuche's magic: < 49 > [d20=12]
> roll 1d20+38 Benyen
<Penuche> Kotono invokes Penuche's magic: < 49 > [d20=11]
> roll 1d20+47 Debonah
<Penuche> Kotono invokes Penuche's magic: < 49 > [d20=2]
Consistent.
Careful: Those are Stone Mushrooms. They can transmute parts of the body to stone that tends to shatter - making them disfiguring to lethal. Touching them or ingesting the spores is not advised, ever, unless you're an earth elemental or similar creature.
Calleigh makes a face, "Wow okay, gross."
"A problem. Burn it," Debonah says, "It'll take a little while, but it's safe."
'Wouldn't that cause bits of mushroom to float into the air?'
"Do you have a better idea?" Debonah asks, "If you do, by all means."
Tryll fires a disintegration beam into the passage, just to see what happens.
Where are you hitting?
