Forward
Started by Anastasia, December 27, 2018, 08:15:18 AM
'Is it? Just sense the air around you. It can't be that different from water, after all.'
"He's right, though," Miranda speaks up, "We're vulnerable if we go down as we are, begging to be ambushed."
'Then one of us will have to scout ahead. Probably myself. Calleigh will stay here. I'll go directly to the source of the darkness and destroy it. Be aware that this will probably draw everything in this place to my position, and possibly yours as well. Debonah, Calleigh, keep watch over them.' Tryll says, renewing his True Seeing.
"Good luck," Debonah bids you, "Fall back if you need to, we'll be ready to attack anything you draw to us."
'Righto.' Tryll says, taking off through the rock and following the magic.
To be clear here, following the magic rather than the chasm, if applicable?
Correct. Helps with not needing to make Hide checks.
Thus you begin to head down into the darkness, following it. As you do...
Perception is highly relevant here since you refreshed true seeing.
[blockquote]Rolled 1d20+48 : 16 + 48, total 64[/blockquote]
After going down towards it, perhaps 200ft? You can hear the swishing of air coming from below.
Tryll approaches cautiously!
Deeper below, you see them rising in long circles around the sloping path down. Two shadowy dragons, one on each side, ascending higher and higher. They're more shadow than solid, darkened and black even amid the shadows here.
Any sign of the source of the darkness?
Tryll follows the lines, then, skirting the edges of the room!
