Forward
Started by Anastasia, December 27, 2018, 08:15:18 AM
"Right," Debonah agrees, "Pick your poison."
Calleigh makes a face.
'Technically, only Dana and Benyen are likely to die. Unless it's from negative energy. Then we all die the same.' Tryll points out. 'Dana, any chance I could convince you to run to Brightwater and buy some sort of wand or scroll of death ward?'
"You want me to be your page?" Dana retorts, eyes narrow. "...fine. I fucking see why, at least. I'll need to run back so I can gate to and back."
'I could send Calleigh if you don't want to go, but she's easily distracted.' Tryll says.
"Yeah. Be safe,' Dana says and flies off at that, leaving the rest of you behind.
Now what?
Describe the room and all exits or ex-exits please?
Tryll takes a quick moment to reconnoiter.
As noted before, the bottom is a mess of collapsed stone paths. As such, the bottom is quite completely caved in and telling much about it is hard due to this.
You've seen the walls around this place are riddled with small tunnels and passages.
There's no obvious path deeper in, or at least any intact.
Tryll drops through the floor, seeking another way.
Nothing like that. Just more tiny passages by and large.
'Right. We're going back up. Let's try to find the passage the dragons came through.'
How are you intending to look?
Gonna start with eyeballs here first. True Seeing still active yo
Sure. A single Perception check for the searching, Calleigh as well, I'll roll NPCs.
Tryll[blockquote]Rolled 1d2+48 : 1 + 48, total 49[/blockquote]Calleigh[blockquote]Rolled 1d20+41 : 13 + 41, total 54[/blockquote]
> roll 1d20+42 Miranda
<Penuche2> Kotono invokes Penuche's magic: < 56 > [d20=14]
> roll 1d20+38 Benyen
<Penuche2> Kotono invokes Penuche's magic: < 51 > [d20=13]
> roll 1d20+56
<Penuche2> Kotono invokes Penuche's magic: < 58 > [d20=2]
You fly back up to the exit from this massive chasm downwards, having seen not a single place the dragons could have used to emerge from, at least as they were when you fought them.
