Home again
Started by Anastasia, January 23, 2019, 12:52:34 PM
Yet everyone is looking around in the chaos, some throwing around spells of fire or evil, hate and cold and a dozen other powerful things.
> roll 1d100 see if anyone gets lucky vs 90+
<Kobot> Kotono rolled 1d100 see if anyone gets lucky vs 90+ --> [ 1d100=81 ]{81}
Yet in those frantic, chaotic moments, none of the blind shots come too close to you - a few within 10ft, but none touching you.
I believe I just slew Temparkus. Keep going!
That was pretty good, every demon weaker than a vrock just got killed, another amazing barrage should clear out those as well!
"Come on, you're not even trying!" the illusory Marie taunts as she casts again, another swarm of projectiles, less than before but still enough to blot out the sky for a moment as they blast out in every direction from her projected image!
Amazing barrage
[20:08] <@Ebiris> roll 1d3+31
[20:08] <Kobot> Ebiris rolled 1d3+31 --> [ 1d3=1 ]{32}
She follows this up by blasting off more magic missiles, still focusing these on greater demons within her range.
Magic missile with enlarge/quicken/twin/repeat/entangle/fell drain.
[20:09] <@Ebiris> roll 1d20+39 magic missile SR
[20:09] <Kobot> Ebiris rolled 1d20+39 magic missile SR --> [ 1d20=12 ]{51}
[20:09] <@Ebiris> roll 2d4+4 and entangled/2 negative levels
[20:09] <Kobot> Ebiris rolled 2d4+4 and entangled/2 negative levels --> [ 2d4=8 ]{12}
Marie: 608/608
Active spells: Extended superior resistance (CL 32), extended mind blank (CL 32), greater arcane sight (CL 32), extended repelling shield (CL 32), bibliotheca arcana (CL 32), extended nondetection (CL 32), epic mage armour (CL 32), sensual blessing (CL 32), extended ray deflection (CL 32), greater invisibility (CL 32)
Defences: AC 94 (touch 36, vs incorporeal 69), CMD 78, spell resistance 46, energy immunity (electricity), energy resistance 10 (acid, cold), status immunity (petrification, polymorph, form-altering, energy drain, ability drain, ability damage, mind-affecting) protective aura, nondetection (DC 47)
Stat buffs/penalties: +11 shield AC, +15 insight knowledge, +25 competence perception
Perceptions: Darkvision 60, blessed sight 120, see invisibility, blindsight/tremorsense 60, scent, greater arcane sight, perception +71
Sorcerer spell slots: 6/7/10/9/7/8/8/8/5/6/6/4/2
Limited SLAs available: heal, meteor swarm, time stop
Missiles and projectiles fly true, slaughtering yet more demons. They're dropping by the dozens, a chaotic zone of massacre as the stronger surviving ones either rage about or flee. Dying demons are trampled by the attackers and retreaters alike, all chaos before Marie, seemingly undetected and safe as she's wrapped in her illusions. Are there no demons here strong enough to find her?
You'd expect the strongest demons would be at the front, not back here. But you'd also expect someone really strong waiting to handle the expected counter they'd make to shut these portals down. Marie will keep wreaking havoc but she'll preserve her magic for a bit now as she flies around, echoed by her illusory decoy, throwing righteous smites at unlucky clusters of demons with impunity.
Gimme Perception here, Marie?
[16:16] <@Ebiris> roll 1d20+71
[16:16] <Penuche2> Ebiris invokes Penuche's magic: < 84 > [d20=13]
You don't see any greater threats - just greater demons throwing attacks at open air, while others retreat. There's-
"RALLY!" A single word like lightning rips through the demons, focusing them in an instant. A voice from somewhere to your side, a savage snarl, "Find her and rip her apart!"
"I'm over here!" Marie's decoy calls, turning and sending a volley of magic missiles at the owner of that voice!
Twinned/repeat/enlarge/entangling/fell drain magic missile and quickened/twinned/repeat/enlarge/entangling/fell drain magic missile.
[16:38] <@Ebiris> roll 1d20+39 magic missile SR
[16:38] <Penuche2> Ebiris invokes Penuche's magic: < 42 > [d20=3]
[16:39] <@Ebiris> roll 1d20+39 magic missile SR #2
[16:39] <Penuche2> Ebiris invokes Penuche's magic: < 53 > [d20=14]
[16:39] <@Ebiris> roll 16d4+32 and 2 negative levels and entangled for first set
[16:39] <Penuche2> Ebiris invokes Penuche's magic: < 68 > [d4=1,3,1,4,4,1,1,3,1,3,1,4,2,4,2,1]
[16:39] <@Ebiris> roll 16d4+32 and 2 negative levels and entangled for second set
[16:39] <Penuche2> Ebiris invokes Penuche's magic: < 63 > [d4=2,1,1,1,1,3,2,2,3,1,2,2,4,2,2,2]
Marie: 608/608
Sorcerer spell slots: 6/5/10/9/7/8/8/8/5/6/6/4/2
Do you have anything that pierces a shield effect for magic missiles?
Yes.
Overpowering Missile
... In addition, a force missile mage's Magic Missiles might penetrate Shield spells and Brooches of Shielding. Against such protections, the force missile mage makes a caster level check with a DC equal to the caster level, in the case of Shield, or DC 20, in the case of a brooch.
Can just use her SR rolls for those, though she loses 2 points from spell penetration which wouldn't apply. So 40 and 51.
A tall balor armored lightly, looming like a sheer mountain of hate. Missiles fly forth and a shimmering barrier appears to block them. Yet the missiles hit it and the barrier tinkles and shatters, flying through them and peppering the balor. He growls low, a whip brandished as he cries, "No retreat!" Energy crackles around him, clinging to him and surely keeping him entangled within it.
Anything else this turn or was that all of it?
Standard and swift used up, all done.
Immediately Shanazel looks around and...
> roll 1d20+33
<Penuche2> Kotono invokes Penuche's magic: < 37 > [d20=4]
CL on nondetection?
The balor produces a small glass ball, dashing it on the ground. Colorful mists rise up and to the sky, of every color of the rainbow. Moments later a luminous, glowing rain of rainbow colored paint begins to fall, "Eyes about," Shanazel barks, "Eyes about!"
Demons all about begin to look around as...
Go.
