Contact
Started by Anastasia, January 31, 2019, 12:54:36 PM
So I'm not actually sure how to roll Init in my current situation! Is this: http://archive.wizards.com/default.asp?x=dnd/glossary&term=Glossary_dnd_negativelevel&alpha=
Correct? If so, I believe that means Moore's init should be 1d20+41 (his usual initiative) -30?
[23:41] <Nephrite> roll 1d20+41-30
[23:41] <Penuche> Nephrite invokes Penuche's magic: < 22 > [d20=11]
[23:42] <Nephrite> roll 1d20+21 Xandra
[23:42] <Penuche> Nephrite invokes Penuche's magic: < 40 > [d20=19]
If my understanding is correct, the actual aura should still be functioning, but Moore's the one with the penalties.
> roll 1d20+13 marilith
<Penuche> Kotono invokes Penuche's magic: < 16 > [d20=3]
Go Xandra and Moore.
Xandra's holding for Moore, and now this is going to get technical.
If Moore uses Time Stop (just go with it), would he, Xandra, Jetina and Kaja continue to fall during it, while the marilith would not?
Yes, assuming everyone is in a time stop they can all move as normal.
Okay. Then Xandra holds for Moore's turn.
On Moore's turn, he activates his boots of temporal acceleration, which gives us 2 turns of Time Stop.
I am writing this all out assuming that there wouldn't be something mechanical stopping this from working. If there is, let me know and I will revise. He has time to give the item to Xandra if he needs to.
Time Stop Turn 1: Moore uses Vul'lath's Relief to open a Gate to Celestia, and hopefully we all just fall through it back there.
Time Stop Turn 2: ?????
Time stops and Xandra exhales heavily, "Are we far enough?" she asks the moment it does.
She's asking that before anything else, in case that impacts you.
We're outside the blizzard, right?
You're falling and making headway, but still in the blizzard.
Okay. Rats, I thought it was stated we were out of the blizzard earlier. Well, that's okay, I'll just revise it a little bit.
"I don't... think so. We have to get outside the blizzard." Moore says.
This is kind of an OOC cheating question, but does Xandra have any large-scale distraction spells? I know those are normally illusions, but can you think of anything? Wall of Stone, that sort of thing?
EDIT: Also, for SLAs, would I be correct in assuming I'm treated as Character level 2 for the purposes of spell effects, or do I still have my caster level? Permanent Image in particular.
Her distractions tend to be of the fatal type, unfortunately.
Yes, your CL is currently nuked.
Take 10 on K:P for 91-30 = 61, do Mariliths normally have true seeing? I'm going to try and by tricky here, so I'd like as much information as I can have.
Well, there goes that idea.
Okay, Round 1 of Time Stop is now using his Sending Stone.
'Cresiel, met Orcus. Need help immediately. Miracle, if possible.'
