Limping return
Started by Anastasia, March 04, 2019, 11:30:10 PM
"I learned my lesson about being greedy!" Moore shouts to Xandra. "Aim for the opening — but I bet we're going to be followed!"
intent will be to try and fly into the passage and keep going!
Acrobatics check, both of you.
[blockquote]Rolled 1d20+16 : 8 + 16, total 24[/blockquote]moore
[blockquote]Rolled 1d20+41 : 7 + 41, total 48[/blockquote]Xandra
Xandra is able to make the turn smoothly, a kick of her wings propelling her head, no longer falling but flying. Moore does the same but misaims, his left shoulder grazing hard against the side of the passage, a jarring pain.
> roll 10d6 half of terminal velocity between turning bleeding off some speed plus it only being a graze Rei-chan
<Rei-chan> Kotono rolled : 10d6 half of terminal velocity between turning bleeding off some speed plus it only being a graze Rei-chan --> [ 10d6=32 ]{32}
Penuche gave you 33 damage instead, so that was the right choice. Anyway, DR does apply to this.
23 then, takes his temp hp to 97.
"Don't stop!" He shouts as he tries to right himself and keep moving!
Since you're not falling now, movement speeds? Just base speed is fine.
Xandra leads the way, flying on with all haste. Cold air buffets you as you rush on, blowing back your hair with the wind. Onward and farther, hurrying town the burrowed-out tunnel. Then you see it - stalagmites and stalactites. They rise up from the ceiling and floor, iced over and blocking the way. You think you could try and weave through them, but it'll be tricky. At least you're sure your small size will help.
"Don't rush too fast!"  He shouts. "Go through them at a measured pace!"
He flies forward but takes it a bit slower to be more careful.
Cutting speed to 40 to try and avoid slamming into anything. Xandra cheats so she can do whatever..
How does Xandra cheat? Serious question, am I missing a relevant ability?
just her natural tendencies to have visions of the future.
Acrobatics check, +4 bonus for slowing down.
oh I'm dumb, the dex aura helps with this. Durrr, blame my still being a little ill!!
[blockquote]Rolled 1d20+33 : 15 + 33, total 48[/blockquote]
Yeah, I'm below the weather today too, I feel you.
Give Xandra a check as well?
[blockquote]Rolled 1d20+54 : 17 + 54, total 71[/blockquote]
