Towertop
Started by Anastasia, March 14, 2019, 12:21:56 PM
No, but something is interdicting scrying at least.
Edge of that radius then.
Did you determine what the radius on that was to do so?
Don't think so. We got a model of the place, but I think that's it. We can try throwing a gate at it and seeing. Alyssa should be able to make a decent guess at the range considering her spellcraft and general knowledge checks, and her personal experience with the teleport beacon, though.
Most likely, a teleport block covers the building or a range of 1 mile. It's not iron cast, exceptions exist, but those would be the most likely outcomes.
We'll go on that general assumption.
Okay and where are you aiming at, then? Back to that question, there's two possibilities and possibly more and you don't specify.
I mean, in line with the slave pins? There's the problem of is this a 360 degree environment or something? I can't really be super specific here other than just to say the best path to it.
Then just give me relative distance you're aiming for? By the building? A mile away? Ten miles? 1000ft? Give me something to latch onto here.
1.25 miles. I said the edge of the assumed teleport block radius.
Okay, in the future just give me flat numbers when possible to eliminate ambiguity, especially as I said, you weren't sure and had a few probably distances. That assumes something that I know you don't know, so isn't a viable answer for me to work with.
Fog.
Fog is the first thing you see when you at last step through. It's a bit chilly but nothing terrible, but thick fog blocks everything ahead out to about 60ft. Fortunately it's not so thick around you do be truly blinding, but visibility is bad.
"Okay, so far so good, but they'll likely know we're coming. Stealth and speed will help, but... assume this place is going to be heavily defended. If we're not gaining ground and begin to stall, it may be best to decide to fall back before losses turn heavy for no reason."
Everyone's setting up, Jarem flying over to you. "We don't have to make this a hill to die on. If they're stronger or just resilient, we fall back and fight another day."
Alyssa nods.
"Everyone here knows their jobs and is competent. Let's get this done fast and get out of here. We want the slaves and the building. Anyone we avoid and leave here will likely be killed by patrons of this place, so don't lose sight of our objective for a fight."
Okay, so two teams right? When will you split up and what's your marching order here?
