Onwards
Started by Anastasia, March 18, 2019, 01:05:31 PM
'Investigate, but carefully.'
"What we saw was the aftermath of Lixer and Orcus." Moore says to the others. "We've been asked to investigate -- carefully. Which means We'll prepare for whatever horrors we find there -- but I'd also like us to try and remove the darkness there if we can. I'm familiar with spells like Hallow and the like, but this will likely require something a bit stronger. I think if we can get to the center of it and use things like Miracle, we can do it. But let's not worry about that just yet -- I'd like to make sure we're prepared before we go, so raise your hand if you can see in darkness."
All four hands go up.
Darkvision 120 for Cresiel and Xandra, 60ft for th eother two.
"...So I'm the odd man out, huh." Moore says. "It's fine, we can make that up with magic. Okay. Everyone can fly... mmm... anything else? We'll ward ourselves against the common things..." A tap of his chin and a look to them. "Unless you all can think of anything I'm missing?"
"One top notch escape plan," Cresiel says, "In case this goes terribly wrong. Again."
"Oh! That reminds me, I need to go pick up our Teleport Blocker. That may come in handy." Moore says with a nod. "As for escape plans... well, obviously just using magic is preferable, but if we run into anything that seems to be too strong, we'll use Time Stop and get away from it."
"Let's also appear much farther away and approach slowly," Kaja says, "As well as test our teleportation as we approach so that we know when we reach a forbidden zone."
Moore nods. "That's fine. Anyone have anything else?" He asks.
"We err on the side of retreating," That's Xandra, speaking up here, "I foresee possible dangers here, and it may well be something we need be wary of. I stress that we use the utmost caution and restraint here."
Moore nods. "Agreed. If we have to return later then we will." He affirms.
Plan here will be to get the Teleport Blocker back, then Moore will compile all of the notes he has gained since Seira last met him and give them to Grias in case she comes by while he is out.
Doing spells will be a little cumbersome via phone but I'll make it work.
Okay, getting the blocker back is uneventful. Are there any notes of relevance here that I need to deal with?
I don't think so, just ones found by the realm folks and by Moore re analyzing the ones he had now that he had a clearer picture. I think it was like 20 more than what we had then.
Okay, go ahead and get spells together then.
Okay.
Jetina casts Celestial Valor:
+8 sacred vs fear and emotion effects that would sap the will to fight, +4 sacred to attack rolls, weapon damage rolls, armor class and saving throws, weapons count as holy (30m)
Mass Death Ward:
Immune to negative energy and ability/level drain.
Mass Energy Immunity (Cold, Acid)
Moore will handle:
Songs (Inspire Courage, Heroics, Greatness):
+18 morale bonus on saving throws against charm and fear effects and a +18 morale bonus on attack and weapon damage rolls
+8 Attack rolls, +3 fort 8d10+8 HD worth of HP
+12 morale bonus to saves and +12 dodge to AC
Life's Grace (I feel like Jetina ought to be able to get this.) on everyone, CL21
Immune to negative energy effects + poison and disease from undead + treat armor as ghost touch.
Fortunate Fate
If reduced to 0 hp heal for 150
In total:
Attack: +31
Weapon damage: +22
AC: +16 (4 sacred, 12 dodge)
Saving throws: +16 (4 sacred, 12 morale)
Everyone also gets the extra HP, this roll is added to 8 HD which I will add in the next post.
[blockquote]Rolled 8d10 : 5, 2, 10, 5, 1, 4, 5, 7, total 39[/blockquote]
Cool, waiting on that next post then, go ahead and do that.
