Victorious advance
Started by Anastasia, March 25, 2019, 01:12:59 PM
Very well, I will descend after clearing the immediate threat.
"Stones, stones!" The dao call, even as they're beginning to be pushed back, the assault stopped cold by you taking the field. Behind you, you note Antenora and Syala in the thick of it now, leading your forces as you stride ahead.
Not that this stops an even greater rain of stones, desperately trying to drown you in rock, trying to do something, anything against you - at least those who aren't falling back, seeing an unwinnable battle.
They at least try. Ref.
[18:48] <@Ebiris> roll 1d20+60 ref
[18:48] <Penuche> Ebiris invokes Penuche's magic: < 65 > [d20=5]
Alicia: 915+60/915
Active spells: Many moments of prescience (CL 33), extended mind blank (CL 33), extended nondetection (CL 33), sensual blessing (CL 33), epic mage armour (CL 33), recitation (CL 33), greater heroism (CL 33), repelling shield (CL 33), spell turning (CL 33), dance of the unicorn (CL 33), foresight (CL 33), vision of the omniscient eye (CL 33), opal protection (CL 33), celestial valor (CL 33), greater anticipate teleportation (CL 33)
Defences: AC 95, CMD 122 (139 vs grapple), spell resistance 48, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear, dazzled & blinded), nondetection (DC 48)
Stat buffs/penalties: +25 competence perception, doubled crit range, +10 armour AC, +3 luck attack/saves, +9 shield AC, +4 attack/saves/skills, +2 insight AC/reflex, +3 morale armour, +4 sacred attack/damage/ac/saves, +32 str, -4 dex, +16 con, +14 natural armour AC, -8 size attack/AC
Perceptions: Darkvision, tremorsense, blindsight 2 miles, scent, arcane sight, perception +83
Sorcerer spell slots: 6/16/16/14/9/9/14/6/7/7/7/5/3/6/4
Duskblade spell slots: 6/22/22/22/10/8/6
> roll 30d8
<Penuche> Kotono invokes Penuche's magic: < 156 > [d8=4,6,3,4,7,8,6,4,6,8,8,7,6,4,8,3,6,6,5,5,3,5,7,7,7,4,1,5,2,1]
Halve this and DR applies.
The rain of stones is heavier and heavier - yet only so many can pelt you, a barrage as others try and hold - but with a giant in their midst, you can see the attack has simply stalled.
You also feel a louder, stronger vibration, something rushing up to the surface.
Go.
3 damage actually got through!
Does my 2 mile tremorsense tell me anything more about what's coming up? Size/shape/exepcted time of arrival?
Alicia: 912/915
It's big and moving fast - in two rounds, you think. It's shaped like a great worm, but with odd, long ridges, almost horn like, all over it. It also constantly drips something from all over its body.
She has a moment so another lightning leap carries Alicia to more of the dao, her feet not touching the ground now so the worm won't be able to identify her location via tremorsense.
It may figure it out from all the dao who fall to the ground in chunky giblets however. Hopefully the snake will be more interesting to fight, this is just like reaping wheat.
[19:28] <@Ebiris> roll 1d20+35 lightning leap SR
[19:28] <Penuche> Ebiris invokes Penuche's magic: < 52 > [d20=17]
[19:28] <@Ebiris> roll 15d6 lightning leap damage
[19:28] <Penuche> Ebiris invokes Penuche's magic: < 51 > [d6=1,6,1,1,4,5,2,4,6,2,1,6,4,5,3]
DC 30 ref half on that.
[19:28] <@Ebiris> roll 1d20+50 whirlwind attack, -24pa
[19:28] <Penuche> Ebiris invokes Penuche's magic: < 59 > [d20=9]
[19:28] <@Ebiris> roll 1d20+39 vampiric touch SR
[19:28] <Penuche> Ebiris invokes Penuche's magic: < 44 > [d20=5]
[19:28] <@Ebiris> roll 6d6+97+6d6 and 1 negative level assuming all are evil
[19:28] <Penuche> Ebiris invokes Penuche's magic: < 133 > [d6=4,3,1,5,3,5,1,1,5,2,2,4]
[19:28] <@Ebiris> roll 2d6 damage for evil outsiders
[19:28] <Penuche> Ebiris invokes Penuche's magic: < 12 > [d6=6,6]
Alicia: 912+60/915
Sorcerer spell slots: 6/16/16/14/9/9/14/5/7/7/7/5/3/6/4
Duskblade spell slots: 6/22/22/22/9/8/6
Indeed it is - and as you scythe them, the genies take the hint. They begin to flee into the ground, fleeing rapidly, breaking off.
For the moment at least you've held the line as cheers go up, even as the ground itself begins to shake and...
You have a round, use it as you wish.
"Rally with my soldiers and rebuild the defensive line!" Alicia calls to the elementals as she summons up some help of her own.
Swift for quickened Summon Monster X for 1d3 elder earth elementals
Swift to designate one of them as my familiar.
Standard to have my new familiar hold the charge on a black ice touch spell
[19:43] <@Ebiris> roll 1d3 elder earth elementals
[19:43] <Penuche> Ebiris invokes Penuche's magic: < 3 > [d3=3]
[19:43] <@Ebiris> roll 3d10 damage for being on fire
[19:43] <Penuche> Ebiris invokes Penuche's magic: < 15 > [d10=6,5,4]
Three elementals appear at her command, barely bothered by the extreme heat especially as one of them is blessed by her. "Go and intercept the worm below!" she commands, the three mutely earth gliding downwards on a straight path to intercept the ascending worm!
Elementals 2 & 3: 213/228 hp, AC 22, attack +27/+27 (2d10+11 19-20/x2), DR 10/-, +1 attack/damage when it and foe are touching ground
Elemental 1: 442/457 hp, AC 39, attack +42/+42 (2d10+11 19-20/x2), DR 10/-, +1 attack/damage when it and foe are touching ground, 2/day limited wish, improved evasion, spell resistance 38, deliver touch spells, holding a black ice touch (SR +35, 15d6 cold and 1d4 negative levels)
Alicia: 912+60/915
Duskblade spell slots: 6/22/22/22/9/8/5
Quick question, did that change their movement speed on them at all?
Down they go. Down, down, down and down. As they do, the heat suddenly rises even hotter around them an abruptly - !
Gimme Fort saves by them.
[18:03] <@Ebiris> roll 1d20+26 familiar elemental fort
[18:03] <Penuche> Ebiris invokes Penuche's magic: < 42 > [d20=16]
[18:04] <@Ebiris> roll 2#1d20+19  other two fort
[18:04] <Penuche> Ebiris invokes Penuche's magic: < 34, 37 >
> roll 20d10
<Penuche> Kotono invokes Penuche's magic: < 109 > [d10=5,4,10,10,3,4,2,2,4,10,4,1,5,10,3,10,10,5,5,2]
The elementals race down, melting, burning. Everything becomes an inferno closer - but they break through and see it. A vast open maw, the worm rising up mouth first, a dreadful thing of burning magma within. It's coming up at them as...
Are they attacking?
Yes.
The elementals glide down relentlessly, two slamming that maw with huge rocky fists, the other delivering a touch of ice!
[18:39] <@Ebiris> roll 1d20+28 elemental 2
[18:39] <Penuche> Ebiris invokes Penuche's magic: < 39 > [d20=11]
[18:39] <@Ebiris> roll 1d20+28 elemental 3
[18:39] <Penuche> Ebiris invokes Penuche's magic: < 44 > [d20=16]
[18:39] <@Ebiris> roll 2d10+12 elemental 2
[18:39] <Penuche> Ebiris invokes Penuche's magic: < 19 > [d10=3,4]
[18:39] <@Ebiris> roll 2d10+12 elemental 3
[18:39] <Penuche> Ebiris invokes Penuche's magic: < 29 > [d10=9,8]
[18:40] <@Ebiris> roll 1d20+43 elemental 1 melee touch
[18:40] <Penuche> Ebiris invokes Penuche's magic: < 56 > [d20=13]
[18:40] <@Ebiris> roll 1d20+35 SR if needed
[18:40] <Penuche> Ebiris invokes Penuche's magic: < 46 > [d20=11]
[18:40] <@Ebiris> roll 15d6 cold damage
[18:40] <Penuche> Ebiris invokes Penuche's magic: < 41 > [d6=2,1,6,1,4,4,2,6,1,1,4,3,1,4,1]
[18:40] <@Ebiris> roll 1d4 negative levels
[18:40] <Penuche> Ebiris invokes Penuche's magic: < 1 > [d4=1]
Alicia: 912+60/915
