Forest breeze
Started by Anastasia, June 11, 2019, 01:08:50 PM
'So, telepathic communication. My last important question: would you object to our building a gate system at the entry of the realm?'
Here a warm laugh travels in the wind, "Alyssa, return and walk a path normally, and you will understand."
Alyssa let's herself drop to the surface of the the ocean with a grin and uses her flight to mimic walking across it.
The feeling of someone listening is gone, as you walk across the waters or close to it.
Alyssa heads back!
I can wander or plane shift, up to you if you want to move this on or do some more random stuff.
Getting back isn't hard - you turn back and you're there, on the dusty paths leading to your home.
Alyssa takes the time to walk, considering...
'Interesting. A unique property of the plane, a step takes you where you're meant to be?'
Going to investigate this at all?
Sure, it's worth understanding.
How are you going to investigate, then?
Focus on a location and take a blind step to start off with. After that, I straight up don't have any ideas.
Umm... I'd say.. The Fleshknowers for the hell of it, but I think Jarem and the others would throw a hissy fit if it worked and I went solo, so I guess at least mention it to them.
Getting to Jarem proves to be wise, "Right, but don't go alone," he says, "I'll go with you. We're just testing this. These Fleshknowers, what plane are they on?"
"Earth, somewhere. I don't know, and that's part of the experiment. I think it may work best at the entrance to the demi-plane."
