A book and many things to do
Started by Anastasia, July 09, 2019, 11:04:47 PM
As everyone gathers, you can feel it. It's a steady, gentle shaking, almost imperceptible. It repeats once a second or so.
Alyssa motions out the timing to the others and looks at them questioningly.
Ianvasah turns big and earthy, then points down where you are and makes a digging gesture with both hands.
Ianvasah begins to tear at the earth again. Yet the same thing happens. In spite of her efforts, progress fails to occur. Ianvasah slams her hand down hard, rattling the ground silently.
At this Jarem goes over and stabs into the ground again and again, adamantine longsword slicing into the stone. After a moment Emily joins him, Ianvasah resumbling as Bastian comes, slamming his foot down regularly, cracking the stones.
Alyssa taps them on the shoulders and motions for them to move out of the way and focuses all of her telekinetic power into striking the ground.
I figure my 1,650lbs of force can do more than they can.
Cool. Any particular usage here?
I would say Violent Thrust is probably the most applicable?
Mmm, we'll call this a CL check. Make one on TK.
Correction, it's 1900lbs of force.
CL Check:
[blockquote]Rolled 1d20+38 : 14 + 38, total 52[/blockquote]
Fort/Cunning Insight:
[blockquote]Rolled 1d20+33 : 12 + 33, total 45[/blockquote]
You stagger back from the impact.
You lose track of everything for several seconds.
When you shake your head clear, you can see there's a great cobweb of cracks all along the ground where it hit. The ground's sagging inwards there.
What was that supposed to be? Pressure wave?
Alyssa shakes her head and takes a moment to gather herself, looking at the others.
Yes.
The others are knocked back - and they are being pulled back. Chains grasp for Jarem, blades seek Emily. Dolmaya tries to escape a rack, while Bastian is pummeling against manacles.
Meanwhile the ground is starting to recover itself, cracks and impact deep but ever so slowly starting to repair.
