A book and many things to do
Started by Anastasia, July 09, 2019, 11:04:47 PM
Thus you descend down. Down into the darkness, not a shred of light, only supernatural senses letting you feel the way ahead. Down and down the stairs you go, your footsteps echoing on the hard stone steps. Down and down and down and down, continuing on. A good several minutes of walking until you can 'see' it below and ahead - a side ledge, a door as the stairs continue deeper on.
'Door. Let's check it for traps and alarms.'
Refresh me, having an idiot moment. Is Alyssa trained for that?
She is. Factotum. She won't mind help though.
'How well do you see here, Alyssa?' Dolmaya asks as you consider.
I dunno? How does greater Blindsight stack up?
As long as you don't have to read or discern color it should be workable.
'Should be fine unless color is involved. Let's see here...'
Detect Magic here for traps.
You don't detect any magic on the door.
Alyssa pulls out her Skeleton Key and taps it to the door, waiting for a reaction.
Skeleton Key: This brass key can unlock any locked, sealed or barred door or object as if by a knock spell (caster level 25th). At the user's option, objects or doors unlocked with this ring automatically re-lock in one minute's time. No lock needs to be present, the key merely needs to be pressed against the door or object to be opened.
Alyssa opens it slowly and quietly, peeking around it to per inside.
Light. Pale purple light spills out from the crack in the door, momentarily dazzling your eyes.
You see Jarem squint against it while Emily shields her eyes with one hand.
Blinking your eyes clear, you can see some sort of chamber - the angle's not good for it, unfortnately.
