The first peaceful day
"I'm sure I'll find it if I need to." Moore says. "Thank you for the wisdom."
"The mists will guide you to the truth," Is the answer you get to that, as...
Moving on?
Thus you go out and you face one question: Now what?
If it's on the border, then it seems like he should go up -- or follow Solania's paths upwards and see where they lead!
[22:02] <Nephrite> roll 1d12
[22:02] <Penuche2> Nephrite invokes Penuche's magic: < 6 > [d12=6]
You head on up. You wander the cliffs above the valley, meandering along. Wood follows, the two of you passing time in your journey.
It feels quiet here - few sounds, few animals and no sign of other intelligent creatures. Just you, the mountain and the light above.
"If I was a well, where would I be?" Moore muses aloud. He continues on, nonetheless. "You don't happen to be a water-sniffing dog, huh, Wood?"
This, he ponders.
Wood barks a few times at your question.
"Well, by all means, then." Moore says.
Wood sniffs the ground several times then takes off at a steady trot.
Moore simply follows along!
Just because it's a journey to find his true name, he should take advantage of help offered along the way.
Even if someone is One, they have help in getting there.
This, he ponders.
Wood trots along...and soon leads you to a little creek bubbling up from under some rocks, slowly trickling down the cliffside. Wood turns and barks several times, before turning and getting a drink of water.
Moore leans down to cup his hands and drink himself. It's probably not going to immediately impart wisdom to him, but it's going to be refreshing, if nothing else.
