The first peaceful day
It's cold mountain water, clean and refreshing. You feel better after drinking.
Moore laughs a little bit after he drinks the water. "All right. Let's find this Eternal Well."
To this, Wood goes to the rocks where the spring emerges and paws at them several times.
"A well would have water that comes from underground, wouldn't it?" Moore reasons. Well, he's not going to go digging himself, but a little magic can help!
ideally he can just use Stone Shape to make a hole / tunnel or whatever to open this up to get there. Otherwise he can summon a something to dig for him!
With a bit of magic, you peek beneath the rocks. A rather large hole in the ground is where the water comes out from.
Big enough for a pixie, really.
"What a coincidence." Moore says. "I don't want you hurting yourself, so if you can't make it down I'll meet you." He adds to Wood before he gives him a pat and then will proceed down!
Swim check, and I believe you have that necklace of adaptation to safeguard your breathing?
Correct.
[blockquote]Rolled 1d20+28 : 10 + 28, total 38[/blockquote]
The current is strong but you're stronger. You swim upstream, a steady path as you quickly find yourself chilled to the bone. The waters are cold - but you're protected enough to shake that right off. On and on and on you swim, until you notice the little passage is widening ahead, coming to some sort of opening. As much as you can tell, even with darkvision seeing in pitch darkness and underwater's no easy feat.
I believe you have some innate cold res or a spell active to help as routine. If I'm wrong, say so and I'll revise since that'll change things.
Cold Res is 30 from a ring.
Moore has no choice but to proceed forward!
You swim and into what looks to be an underground reservoir. Several underground streams and waterflows seem to feed into it, the water clear and pure. There's over a dozen paths here on a glance - you'd have to examine them all closer and more carefully.
Moore doesn't need to explore them— he simply takes a breath and proceeds... that way!
[blockquote]Rolled 1d12 : 12, total 12[/blockquote]
Hes Just randomly picking a source, trusting that he will be guided accordingly depending on what he is meant to find.
Interesting luck.
You approach one - and as you do, you feel a current pulling you towards it? As you get close, you can see water flows down this particular one instead of out of it.
Moore will proceed down and follow it!
It's easy when the current is working with you. You shoot down the waterway like a pixie arrow shot from Amaryl's bow, zooming along. It's a fairly wide passage that's erratically sloping upwards here and there, never downwards.
After some time of this, your sharp eyes notice something. The faintest glow is beginning to come from rocks on the side and ceiling of this place.
