The first peaceful day
"Ah, you need knowledge." Moore says. He straightens up only to offer a bow. "My name is Moore, Duke of Songs, servant of Erathaol and leader of Hopes Landing. I imagine, since you do not know who I am, that this station you hold is one that you do not leave?" He asks. "May I inquire where, precisely I am? You said Mertion, so I know that much."
"You speak truth," The solar says, as the other three turn your back on you, back to guarding the spring. "This is the Dawnspring, where age can be taken away, even from the mortal body, as well as heal almost any injury. Entrance to this spring is only given by the Hebdomad themselves."
"Do you know of the source?" Moore asks. "I witnessed it below but did not think it my place to study it. It seemed the waters there spread out to many other places..." he turns back to the fountain itself. "Eternal Well... it's rather close to that, but I don't think this is it."
"Then I request you return whence you came, Duke," The solar gestures, "Both return to your quest and seek what you will. I see no condemnation of you coming, nor any rebuke from the light above."
"That... would mean I go back in there." Moore says. "Which I don't object to... but I don't want to sully it any further."
"Your concern is admirable, but one with a pure spirit will not mar this spring." Is the answer you get.
"I won't share knowledge of this location." Moore says, not that he needs to anyway... they probably knew that. He flies over and then dives in, knowing he has a much harder time ahead of him than he did before.
...that is, if he didn't remember magic helps!
He is casting Freedom of Movement on himself to make this easier.
Done. You take the time to swim back to the room with the golden shore, the waters still warm here and rejuvenating you ever moment you swim in them.
Your arcane knowledges also tell you that it's lucky you're not a mortal creature, or at best you would be but a babe now.
Moore looks around at the other caves where the water goes.
He didn't want to do this last time, but perhaps he should...
Detect magic, Take 10 on Spellcraft for 86 and on K:A for 106. Is it the gold stuff itself that seems to give the water it's power? What IS the gold stuff, or is it just gold?
The gold stuff isn't magical, and by all indications looks like gold.
The water's magical - you can tell it heals and rejuvenates, just as the solar said.
None of the passages radiate any more magic than the others.
"This definitely has to be the source... but maybe it changes further depending..." Moore murmurs.
Very well — another cave shall be explored!
[blockquote]Rolled 1d9 : 7, total 7[/blockquote]
This tunnel proceeds dead ahead.
...yet after a few moments, the current becomes fearsomely powerful, pulling you ahead, abruptly changing strength and direction. You are protected by freedom of movement however, giving you the ability to ignore it if you wish.
There's a reason he's being show this, so he will ride the current! He can get back when he needs to.
A deep current carries you along, deeper and deeper in. The waters become cooler now as you're moved forward, on and slightly upward - until you see a sharp U slope, the waters cascading into a small cavern above - no air, fully filled - and then heading downwards.
He decides to stop to take a look at the cave. It might lead up further and simply can't see it... and he can breathe fine anyway, so it's no issue.
