A new order
Started by Anastasia, July 22, 2019, 11:42:20 PM
Latha and Anty could use a little, no one's critical though.
Alicia: 945/1014
Active spells: Many moments of prescience (CL 33), extended mind blank (CL 34), extended nondetection (CL 34), sensual blessing (CL 33), epic mage armour (CL 33), recitation (CL 33), many moments of prescience (CL 33), greater heroism (CL 33), repelling shield (CL 33), spell turning (CL 33), dance of the unicorn (CL 33), foresight (CL 33), vision of the omniscient eye (CL 33), extended ray deflection (CL 34), greater visage of the deity (CL 33), extended greater anticipate teleportation (CL 34)
Defences: AC 113, CMD 136, spell resistance 48, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear, dazzled & blinded), nondetection (DC 49), ray deflection, freedom of movement
Stat buffs/penalties: +25 competence perception, doubled crit range, +10 armour AC, +3 luck attack/saves, +9 shield AC, +4 morale attack/saves/skills, +2 insight AC/reflex, +10 insight perception, +15 natural armour, +4 saves vs poison, +40 str, -2 dex, +20 con, +2 int, +4 wis, +4 cha, -8 size, +17 sacred all rolls/AC
Perceptions: Darkvision, tremorsense, blindsight 3 miles, scent, arcane sight, perception +108
Sorcerer spell slots: 6/16/16/14/3/9/13/8/7/5/8/5/4/1/3
Duskblade spell slots: 6/23/21/21/10/7/7
Marie: 627/627
Active spells: Extended mind blank (CL 33), extended nondetection (CL 33), sensual blessing (CL 33), epic mage armour (CL 33), recitation (CL 33), greater heroism (CL 33), repelling shield (CL 33), extended ray deflection (CL 33), greater arcane sight (CL 33), bibliotheca arcana (CL 33)
Defences: AC 109 (CMD 105), spell resistance 48, energy immunity (electricity), status immunity (petrification, polymorph, form-altering, energy drain, ability drain, ability damage, mind-affecting), nondetection (DC 48), ray deflection, freedom of movement
Stat buffs/penalties: +25 competence perception, +3 luck attack/saves, +9 shield AC, +4 morale attack/saves/skills, +15 insight knowledge, +17  sacred all rolls/AC
Perceptions: Darkvision, tremorsense, blindsight 60, scent, greater arcane sight, perception +94
Sorcerer spell slots: 6/7/10/9/8/8/8/8/7/8/6/4/0/4
Antenora will top up Latha and Alicia by +100 HP. She'll also drop opal protection.
Opal Protection
Abjuration/Enchantment (Compulsion) [Good, Mind-Affecting]
Level: Pal 8
Targets: Allies in a 40ft radius burst
This spell is identical to divine protection, except as noted here. Allies gain a +3 morale bonus to armor class and saves. They are treating as being under a mind blank spell, but only against spells with the evil descriptor or by spells cast by evil outsiders.
'Do either of you want my sunmantle?' Latha asks as you all fly forward.
Antenora
HP: 708/768
Bonuses: Attack+24 (+17 sacred, +4 morale, +3 luck), Damage+17 (+17 sacred) AC+23 (+3 morale +17 sacred, +3 luck), Saves+24 (+17 sacred, +4 morale, +3 luck), Skills+21 (+17 sacred, +4 morale), Checks+17 (+17 sacred)
Resources: Holy Fury 19/36 (enc) Divine Retribution 1/1 Smite Evil 9/12 Channel Energy 17/17 Lay On Hands 167/448 Remove Disease 9/9 (week), Spiritual Connection 3/3 Blinding Speed 25/25
Spells Used: Opal Protection
SLAs Used:
Spells Active: Recitation (CL33), Greater Heroism (CL33), Death Ward (CL33), Life's Grace (CL33), Neutralize Poison (CL33), Opal Protection (CL34)
Latha
HP: 549/660
Aura: Holy Light 30ft (7d6 damage vs evil/round) Protective 20ft (+4 deflection/+4 resistance vs evil)
Bonuses: Attack+24 (+17 sacred, +4 morale, +3 luck), Damage+17 (+17 sacred) AC+34 (+17 sacred, +14 armor, +3 luck), Saves+24 (+17 sacred, +4 morale, +3 luck), Skills+21 (+17 sacred, +4 morale), Checks+17 (+17 sacred)
Resources: Channel Energy 14/14 Sun Devotion 3/4
Spells Used: Heal, Burst of Glory, Radiant Storm
SLAs Used:
Spells Active: Recitation (CL33), Greater Heroism (CL33), Death Ward (CL33), Life's Grace (CL33), Neutralize Poison (CL33), Epic Mage Armor (CL33), Opal Protection (CL34)
Notes: Level + 7 (39) extra damage per hit vs undead during sun devotion.
Silver Fire heal on Anty, +150 HP. Latha gets made my familiar, main benefit is her base fort save will be +5 higher and she gets +17 natural armour and 2 uses of limited wish as a spell like ability. As she's my familiar I can cast personal range spells on her and cast Many Moments of Prescience, quickened. That's CL 33 and gives her a +30 insight bonus to an attack/save/AC/opposed skill check up to 4 times before being expended.
Also as my familiar we have an empathic bond so she'll feel Alicia's positive emotions which might help her?[/b]
"Marie needs it more right now," Alicia says, expecting the eyes to try and focus on Marie and Latha after she and Antenora engage them, simply as a matter of maximising their ability to do harm in the face of the two's defences.
Alicia: 1014/1014
Active spells: Many moments of prescience (CL 33), extended mind blank (CL 34), extended nondetection (CL 34), sensual blessing (CL 33), epic mage armour (CL 33), recitation (CL 33), many moments of prescience (CL 33), greater heroism (CL 33), repelling shield (CL 33), spell turning (CL 33), dance of the unicorn (CL 33), foresight (CL 33), vision of the omniscient eye (CL 33), extended ray deflection (CL 34), greater visage of the deity (CL 33), extended greater anticipate teleportation (CL 34), opal protection (CL 33)
Defences: AC 116, CMD 139, spell resistance 48, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear, dazzled & blinded), nondetection (DC 49), ray deflection, freedom of movement
Stat buffs/penalties: +25 competence perception, doubled crit range, +10 armour AC, +3 luck attack/saves, +9 shield AC, +4 morale attack/saves/skills, +2 insight AC/reflex, +10 insight perception, +15 natural armour, +4 saves vs poison, +40 str, -2 dex, +20 con, +2 int, +4 wis, +4 cha, -8 size, +17 sacred all rolls/AC, +3 morale AC
Marie: 627/627
Active spells: Extended mind blank (CL 33), extended nondetection (CL 33), sensual blessing (CL 33), epic mage armour (CL 33), recitation (CL 33), greater heroism (CL 33), repelling shield (CL 33), extended ray deflection (CL 33), greater arcane sight (CL 33), bibliotheca arcana (CL 33), opal protection (CL 33)
Defences: AC 112 (CMD 108), spell resistance 48, energy immunity (electricity), status immunity (petrification, polymorph, form-altering, energy drain, ability drain, ability damage, mind-affecting), nondetection (DC 48), ray deflection, freedom of movement
Stat buffs/penalties: +25 competence perception, +3 luck attack/saves, +9 shield AC, +4 morale attack/saves/skills, +15 insight knowledge, +17  sacred all rolls/AC, +3 morale AC
Then it's on Marie. More as soon as Seira catches up for tower, I'll resolve shadow hell at the same time for you.
Antenora
HP: 708/768
SLAs Used:
Latha
HP: 549/660
Spells Used: Heal, Latha's Sunmantle, Burst of Glory, Radiant Storm
SLAs Used:
Alicia: 1014/1014
Marie: 627/627
Active spells: Extended mind blank (CL 33), extended nondetection (CL 33), sensual blessing (CL 33), epic mage armour (CL 33), recitation (CL 33), greater heroism (CL 33), repelling shield (CL 33), extended ray deflection (CL 33), greater arcane sight (CL 33), bibliotheca arcana (CL 33), opal protection (CL 33), Latha's sunmantle (CL 33)
In the sky Shar and Selune still do war - but darkness is gathering around Shar, slowly pushing back against the light of the moon.
Above, a figure rises up on a platform of solid stone. A dwarf clad in gold and bronze colored armor, decorated with smooth red gemstones. His gray beard is long and full, a great warhammer in hand as the stone platform grows up from the ground, a SHINK of shifting stone, almost like metal, as it becomes a solid iron anvil. He stands right between Shar and Selune, "SHAR!" Moradin roars, in a voice that covers the battlefield. "Too long have you profaned caves and taken the earth. No more!"
Come and die, Soul Forger.
Amid this the shadow hell strikes, no mercy for you, not even now.
> roll 1d20+80 (+19 ???, +3 ???, +10 ???, +1 ???) touch AC.
<Penuche> Kotono invokes Penuche's magic: < 89 > [d20=9]
> roll 10d6
<Penuche> Kotono invokes Penuche's magic: < 37 > [d6=6,4,4,3,3,2,5,5,1,4]
Not that you have long to suffer, for it's coming again. The Tower glows, pulses with the emptiness, the void, nothingness. It is like seeing a hole in Creation, reaching out across all the battlefield.
Fort save, -19 penalty, all.
Antenora
HP: 671/768
SLAs Used:
Latha
HP: 512/660
SLAs Used:
Stand fast used, eats up a swift from next round. +15 to saves for 1 round for everyone nearby.
[20:08] <@Ebiris> roll 1d20+77 Alicia, mettle
[20:08] <Penuche> Ebiris invokes Penuche's magic: < 78 > [d20=1]
[20:08] <@Ebiris> roll 1d20+68 Marie
[20:08] <Penuche> Ebiris invokes Penuche's magic: < 74 > [d20=6]
Alicia: 1014/1014
Marie: 627/627
> roll 1d20+74 Antenora
<Penuche> Kotono invokes Penuche's magic: < 76 > [d20=2]
> roll 1d20+63 Latha
<Penuche> Kotono invokes Penuche's magic: < 76 > [d20=13]
Yet this time you all stand against it, enduring the vile magic. Nothing bows you this time, nothing stops you. You all stand forward as the Eyes yet gather and...
Go Alicia, supreme init.
Stand fast only boosts fort saves right now, lasts until the Tower goes again.
Space compresses again, Alicia steps forward to end up in the middle of all those eyes. Then she grows, once more bestriding the plane of shadow like a colossus, her sword scything through those fell orbs and leaving a rain of darkened hemispheres in her wake!
Free action to compress space, five foot step through, swift to go from colossal to colossal+ max size for better army killing potential, then whirlwind attack.
[20:37] <@Ebiris> roll 1d20+71 blinding speed, 10th level arcane strike, channelled maximised/vivacious flux grasp, whirlwind attack, -33 power attack
[20:37] <Penuche> Ebiris invokes Penuche's magic: < 80 > [d20=9]
[20:37] <@Ebiris> roll 6d6+140+14+3d6+10d4+396
[20:37] <Penuche> Ebiris invokes Penuche's magic: < 605 > [d6=6,3,6,5,4,3,3,1,1][d4=3,2,1,2,3,2,3,3,1,3]
DC 38 fort save or take a -10 penalty to armour/natural armour, it affects constructs.
[20:41] <@Ebiris> roll 1d20+96 Alicia fort for hitting the orbs, mettle
[20:41] <Penuche> Ebiris invokes Penuche's magic: < 114 > [d20=18]
Following after Alicia, Marie releases her amazing barrage once more to try and clear down these orbs before they can be a danger to anyone!
[20:39] <@Ebiris> roll 1d3+31 twinned/repeat/entangling/enlarge/fell drain amazing barrage
[20:39] <Penuche> Ebiris invokes Penuche's magic: < 34 > [d3=3]
[20:39] <@Ebiris> roll 1d3+31 quickened/twinned/repeat/entangling/enlarge/fell drain amazing barrage
136 damage to everything bad within 6800 feet of Marie (the compressed space should let her hit stuff even further back the way we came). Living things that are vulnerable get 4 negative levels, and they're all entangled too.
Alicia: 1014/1014
Sorcerer spell slots: 6/16/16/14/3/9/13/8/7/5/7/5/4/1/2
Marie: 627/627
Sorcerer spell slots: 6/7/10/9/8/8/8/8/7/8/6/4/0/2
Need miss chances on all of those unless you have something to overcome it, Alicia and Marie.
#265
[17:26] <@Ebiris> roll 1d100 Alicia miss chance
[17:26] <Penuche> Ebiris invokes Penuche's magic: < 32 > [d100=32]
[17:26] <@Ebiris> roll 1d100 Marie miss chance weird the unerring projectile doesn't have the same language as magic missile for obviating that
[17:26] <Penuche> Ebiris invokes Penuche's magic: < 73 > [d100=73]
[17:42] <@Ebiris> roll 1d100 Marie needs 2 miss chance rolls
[17:42] <Penuche> Ebiris invokes Penuche's magic: < 49 > [d100=49]
Yet space twists around the Eyes of Shar, blows going errant. Reality itself seems to rebel against your blade and Marie's magic, some striking but many lost. You manage some shots to land as...
Init is Alicia (Supreme Init) > Marie (68) > The Chasms (67) > Latha = Shadow Hell (43) > Antenora (42) > Eyes of Shar (41) > The Tower (28)
Going to AoO the Chasms?
They're still here? Nah.
> roll 1d20+72 (+19 ???, +3 ???)
<Penuche> Kotono invokes Penuche's magic: < 81 > [d20=9]
ACs?
Alicia 116, Marie 113.
Alicia: 1014/1014
Marie: 627/627
