A new order
Started by Anastasia, July 22, 2019, 11:42:20 PM
This time all of you are ready, defending against the swarm of them, holding them at bay. As they do, the shadows again strike, ever hungering for you.
> roll 1d20+80 (+19 ???, +3 ???, +10 ???, +1 ???) touch AC.
<Penuche> Kotono invokes Penuche's magic: < 84 > [d20=4]
> roll 10d6
<Penuche> Kotono invokes Penuche's magic: < 32 > [d6=2,5,3,3,2,4,2,4,5,2]
Amid this Latha sends to you, 'Is there any way to make them more reliable to hit?'
Antenora
HP: 639/768
Bonuses: Attack+24 (+17 sacred, +4 morale, +3 luck), Damage+17 (+17 sacred) AC+23 (+3 morale +17 sacred, +3 luck), Saves+24 (+17 sacred, +4 morale, +3 luck), Skills+21 (+17 sacred, +4 morale), Checks+17 (+17 sacred)
Resources: Holy Fury 19/36 (enc) Divine Retribution 1/1 Smite Evil 9/12 Channel Energy 17/17 Lay On Hands 167/448 Remove Disease 9/9 (week), Spiritual Connection 3/3 Blinding Speed 25/25
Spells Used: Opal Protection
SLAs Used:
Spells Active: Recitation (CL33), Greater Heroism (CL33), Death Ward (CL33), Life's Grace (CL33), Neutralize Poison (CL33), Opal Protection (CL34)
Latha
HP: 480/660
Aura: Holy Light 30ft (7d6 damage vs evil/round) Protective 20ft (+4 deflection/+4 resistance vs evil)
Bonuses: Attack+24 (+17 sacred, +4 morale, +3 luck), Damage+17 (+17 sacred) AC+34 (+17 sacred, +14 armor, +3 luck), Saves+24 (+17 sacred, +4 morale, +3 luck), Skills+21 (+17 sacred, +4 morale), Checks+17 (+17 sacred)
Resources: Channel Energy 14/14 Sun Devotion 3/4
Spells Used: Heal, Latha's Sunmantle, Burst of Glory, Radiant Storm
SLAs Used:
Spells Active: Recitation (CL33), Greater Heroism (CL33), Death Ward (CL33), Life's Grace (CL33), Neutralize Poison (CL33), Epic Mage Armor (CL33), Opal Protection (CL34)
Notes: Level + 7 (39) extra damage per hit vs undead during sun devotion.
Silver Fire heal on Anty, +150 HP. Latha gets made my familiar, main benefit is her base fort save will be +5 higher and she gets +17 natural armour and 2 uses of limited wish as a spell like ability. As she's my familiar I can cast personal range spells on her and cast Many Moments of Prescience, quickened. That's CL 33 and gives her a +30 insight bonus to an attack/save/AC/opposed skill check up to 4 times before being expended.
Also as my familiar we have an empathic bond so she'll feel Alicia's positive emotions which might help her?[/b]
If it was just one orb I'd think using space compression would be reasonable for getting around the space-twisty defence that comprises their miss chance, but would it work on an army?
Alicia: 982/1014
Active spells: Many moments of prescience (CL 33), extended mind blank (CL 34), extended nondetection (CL 34), sensual blessing (CL 33), epic mage armour (CL 33), recitation (CL 33), many moments of prescience (CL 33), greater heroism (CL 33), repelling shield (CL 33), spell turning (CL 33), dance of the unicorn (CL 33), foresight (CL 33), vision of the omniscient eye (CL 33), extended ray deflection (CL 34), greater visage of the deity (CL 33), extended greater anticipate teleportation (CL 34), opal protection (CL 33)
Defences: AC 116, CMD 139, spell resistance 48, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear, dazzled & blinded), nondetection (DC 49), ray deflection, freedom of movement
Stat buffs/penalties: +25 competence perception, doubled crit range, +10 armour AC, +3 luck attack/saves, +9 shield AC, +4 morale attack/saves/skills, +2 insight AC/reflex, +10 insight perception, +15 natural armour, +4 saves vs poison, +40 str, -2 dex, +20 con, +2 int, +4 wis, +4 cha, -8 size, +17 sacred all rolls/AC, +3 morale AC
Perceptions: Darkvision, tremorsense, blindsight 3 miles, scent, arcane sight, perception +108
Sorcerer spell slots: 6/16/16/14/3/9/13/8/7/5/7/5/4/1/2
Duskblade spell slots: 6/23/21/21/10/7/7
Marie: 595/627
Active spells: Extended mind blank (CL 33), extended nondetection (CL 33), sensual blessing (CL 33), epic mage armour (CL 33), recitation (CL 33), greater heroism (CL 33), repelling shield (CL 33), extended ray deflection (CL 33), greater arcane sight (CL 33), bibliotheca arcana (CL 33), opal protection (CL 33), Latha's sunmantle (CL 33)
Defences: AC 112 (CMD 108), spell resistance 48, energy immunity (electricity), status immunity (petrification, polymorph, form-altering, energy drain, ability drain, ability damage, mind-affecting), nondetection (DC 48), ray deflection, freedom of movement
Stat buffs/penalties: +25 competence perception, +3 luck attack/saves, +9 shield AC, +4 morale attack/saves/skills, +15 insight knowledge, +17  sacred all rolls/AC, +3 morale AC
Perceptions: Darkvision, tremorsense, blindsight 60, scent, greater arcane sight, perception +94
Sorcerer spell slots: 6/7/10/9/8/8/8/8/7/8/6/4/0/2
Honestly, it's DM judgment territory. I'd allow a chance, but with some sort of opposed check involved.
'If it were one I could, but against an army I can't guarantee it,' Alicia replies.
'Will you try?' Latha asks quickly.
Latha holds then. Antenora will charge in and try and break them, or otherwise just take the brunt of it as needed.
"Repent of this path or be destroyed," Antenora cries, flying ahead into them, a spear aimed right at the vanguard of the gathering masses, as the tower ahead continues to radiate un-reality.
> roll 1d20+79 (+24 various, +4 charge, +16 holy fury, +14 smite evil, -33 PA)
<Penuche> Kotono invokes Penuche's magic: < 99 > [d20=20]
> roll 1d100 vs 50
<Penuche> Kotono invokes Penuche's magic: < 31 > [d100=31]
Well, it wasn't a crit threat even if it hit, at least.
Yet the dimensions twist and turn around Antenora, her spear failing to find everything as space warps.
Init is Alicia (Supreme Init) > Marie (68) > The Chasms (67) > Latha = Shadow Hell (43) > Antenora (42) > Eyes of Shar (41) > The Tower (28)
They come. They come silently, flying ahead, black balls of absolute nothing and unholy energy swarming. They come closer and closer, each threatening obliteration with a mere graze of its body.
Fort saves all, note if immune to disintegration.
Antenora
HP: 639/768
Resources: Holy Fury 18/36 (enc) Divine Retribution 1/1 Smite Evil 8/12 Channel Energy 17/17 Lay On Hands 167/448 Remove Disease 9/9 (week), Spiritual Connection 3/3 Blinding Speed 25/25
SLAs Used:
Latha
HP: 480/660
SLAs Used:
[23:45] <@Ebiris> roll 1d20+96 Alicia, mettle, immune to disintegration
[23:45] <Penuche> Ebiris invokes Penuche's magic: < 110 > [d20=14]
[23:45] <@Ebiris> roll 1d20+72 Marie
[23:45] <Penuche> Ebiris invokes Penuche's magic: < 87 > [d20=15]
Alicia: 982/1014
Marie: 595/627
Antenora is likewise immune to disintegration.
> roll 1d20+81 Latha
<Penuche2> Kotono invokes Penuche's magic: < 92 > [d20=11]
> roll 40d6 as an army even a passed save is nothing to fuck with
<Penuche2> Kotono invokes Penuche's magic: < 138 > [d6=3,3,4,4,5,1,4,6,1,6,4,4,2,2,6,6,2,1,4,5,1,2,6,4,2,6,3,6,2,1,1,2,4,2,3,3,4,6,2,5]
The horde is silent. They move, the barest touches enough to destroy boulders. Yet Alicia and Antenora stand unharmed, beyond such things now, shining bright even in this darkness. Latha and Marie withstand as well, parts of them gone even as they endure. They stand as well as...
Seira needs to catch up for Tower, so just go ahead and react.
Antenora
HP: 639/768
SLAs Used:
Latha
HP: 342/660
SLAs Used:
Although hurt, Marie keeps up her song with a desperate intensity, knowing what's about to come from that tower.
Alicia: 982/1014
Marie: 457/627
This time the Tower's silent, no immediate attack - but dozens of dark, twisted souls fly up around Alicia, just as they did against Seira a little while ago.
'Your turn,' Antenora thinks grimly, '...look!'
Up in the sky Shar and Selune clash - and Selune shifts. Her light continues as she becomes humanoid, a mature battle maiden with mace in hand. The two glare at each other across the battle - only for a dwarf to be there. Moradin attacks Shar headlong, Selune rushing in to press the advantage. Yet farther ahead, past even the army of Eye sof Shar, another wave of darkness is coming. This one is vastly larger, vastly bigger, the only thing it doesn't blot out is the Tower.
'We need to smash through and destroy that tower,' Antenora's mental voice is grim, 'Do something that matters here besides slaying minions and holding the line!'
Init is Alicia (Supreme Init) > Marie (68) > The Chasms (67) > Latha = Shadow Hell (43) > Antenora (42) > Eyes of Shar (41) > The Tower (28) > Wave.
Go.
#281
"I'm killing these anyway," Alicia says grimly, attempting to use space compression to cancel out at least some of the twisting the orbs are doing so as to help Latha and Marie. She herself has a far more expedient solution of casting true strike before her titanic blades sweep through the swarm.
Free action to try something with space compression to help the others, however it works. Quickened true strike and whirlwind attack.
[18:07] <@Ebiris> roll 1d20+91 blinding speed, 10th level arcane strike, channelled maximised/vivacious flux grasp, whirlwind attack, -33 power attack, true strike
[18:07] <Penuche2> Ebiris invokes Penuche's magic: < 97 > [d20=6]
[18:08] <@Ebiris> roll 6d6+140+14+3d6+10d4+396
[18:08] <Penuche2> Ebiris invokes Penuche's magic: < 609 > [d6=4,2,3,2,5,4,4,6,1][d4=1,4,4,2,2,2,4,4,3,2]
DC 38 fort save or take a -10 penalty to armour/natural armour, it affects constructs.
Alicia: 982/1014
Sorcerer spell slots: 6/16/16/14/3/9/13/8/7/5/6/5/4/1/1
Duskblade spell slots: 6/23/21/20/10/7/7
Marie: 457/627
Give me CL on space compression.
[18:21] <@Ebiris> roll 1d20+36+17 CL
[18:21] <Penuche2> Ebiris invokes Penuche's magic: < 59 > [d20=6]
With a loud CRACK space recoils, leaving you a moment to slice your sword through them all. Swathes of them are cut and forced back, a moment of space twisting in your favor as...
Marie.
> roll 1d20+28 fort
<Penuche2> Kotono invokes Penuche's magic: < 35 > [d20=7]
They failed the save.
