Going down
Started by Anastasia, August 16, 2019, 03:30:24 PM
'Bracing. And loud. Expect company.' Tryll warns.
"All the more reason to get moving," Miranda says, "Before we get even more problems."
Dana just smiles at that, "It won't be fuckin' boring now!"
"You expected Pandemonium to be boring?" Calleigh asks as the group moves on.
"Not now," Dana grins, Benyen smiling as well.
The path ahead is long and tight, winding. As you go, the echos of the wind growing louder? You notice the hilt of a blade is stuck into the wall as you past, as if a blade was thrust in there.
"ITSASWORD!" Calleigh points. Tryll investigates with Detect Psionics.
The sword radiates magic. It's minorly enchanted, nothing special, just...stuck in the wall, apparently?
Tryll also checks the wall around it to see if it's some sort of trap.
Do you have trapfinding or the like?
I don't, but I can pass through walls so I can see inside! We'll do that.
It looks like the sword is intact - no rust, either. No sign of any mechanical traps or hollows in the wall.
No apparent magical traps?
Tryll telekinetically yanks the sword from the wall.
A loud tearing sound as the sword is removed, pulled out cleanly.
"So...sword?" Benyen asks, "Random swords are the best swords."
'Did you know that swords are very effective when launched at high velocity at a target?' Tryll says as the sword levels out over the group.
