Ahead lies...?
"I think it was the grumpy one." Moore says. "But we can get these fixed easily enough. Did you get ahold of him?"
"He'll see to it," Cresiel says simply. "Leaving these sitting around is not strictly Celestia's problem, but there is value in taking them."
"Well, they can surely use the anvil anyway." Moore says. "Let's see here..."
Limited Wish to emulate a mass Shrink Object on all of the stuff, then Moore's Quick Gather to fit all of it into his portable hole. There's got to be a ton of shit but if it's all shrunk down it should be fine.
There's just more than even a single mass shrink object could handle, realistically. Are you willing to try casting this multiple times?
How about if I use Wish instead for a much larger area? Will that work? I don't even think we ever established any actual radii for the mass version anyway, so I'm not sure how much space I have to work with.
Sure, if you want to commit to that.
Done. You gather it all together with a mighty display of magic, reality changing in a moment to bring it all to you.
"All right." Moore says. "Let's keep looking around for the time being. If this was in here, it stands to reason this place hasn't seen a lot of disturbance."
"Stable you mean," Jetina agrees as on checking, there's a pair of passages leading on from this place - one roughly north and one west, and you came from what you reckon to be the east/south east.
"Let's go north." Moore says as he heads in that direction!
Give me a new Perception check real quick.
The passage meanders downwards slow and steady, a rough tunnel bored out from the rock around it. After some time following this path, you begin to hear the sound of water crashing down ahead.
"Be careful." Moore warns the others as he proceeds!
